Question about Water Heaters
I have a rheem water heater model 89VP30S... How do I reset manually... The heat automatically safety cut when the water was shut off... The tank is full, just not heating...??
MODEL 89VP30S
SOURCE: Rheem water heater with powerglow ignition wont re-light
I have fixed mine. The problem part is the Ignition Control module. It is made by Robert Shaw part # SP10758. I paid $93 plus shipping.
Works great now. A repairman wanted to sell me a gas valve for $488.
Watch out for these people.....
Posted on Jan 10, 2009
  • 14 Answers
SOURCE: Rheem water heater, will start but flame lasts 10 seconds
Is the vent fan working well and can you feel unobstructed air out the termination fitting outside?
Posted on Apr 05, 2009
  • 25 Answers
SOURCE: rheem 71 40d elecrtic water heater not heating
If it is an electric water heater, there is no pilot light. You could have bad elements or bad thermostats. Be careful working on an electric water heater, as most use 208-220 volts!
If it is a gas water heater, it could be a bad thermocouple, ignitor, gas valve.
My advice to you is to call a qualified service company to come repair your water heater.
Posted on Jul 10, 2009
mrhotandcold
  • 248 Answers
SOURCE: Rheem RTG-74PVN-1 Water heats for abot 2 minutes
overheat stat or fan, on fan check for small pinhole in rubber tube best of luck
Posted on Oct 29, 2009
heatman101
  • 43501 Answers
SOURCE: rheem electic water heater model 81v52s. switch
It may or may not... if not then check the reset...
Check out this tip...
http://www.fixya.com/support/r4654730-electric_water_heater_not_working
heatman101
Posted on Apr 29, 2010
Year model by serial number
So.........it's a GSW 50 gallon which you either bought in Canada or smuggled in.
Even if you have a model with a shutter damper without a fan this is NOT a Power Venter and will need standard through roof flue pipe/chimney to establish draft and vent CO and exhaust gases atmospherically AKA Natural Draft. It will NOT vent sidewall without a fan induced draft
Sep 07, 2014 | Water Heaters
How long will it take Rheem solar hot water to heat up
read manual:
http://www.rheem.com.au/Assets/1294/1/Rheemsolarlolineelectric511series.pdf
Usually electric element heats about 20 gallons per hour.
It appears the element is controlled by thermostat and automatically kicks ON when tank falls below thermostat set point..
This will be handy since element will continually heat the circulating water when outside temperatures turn cool... of course it will also be wasteful if thermostat is set high.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Jul 11, 2013 | Water Heaters
Temperature
Pull the thermostat loose from the wall so you can see the model number located on the back of device.
Google search model: xxxxcy .pdf
Or search for british gas thermostat .pdf
This will give you access to product manual.
Also check batteries located on back of unit. Install fresh batteries. Memories should be retained on the chip during battery change.
Add a comment with model number, and I will try to locate thermostat manual.
May 20, 2013 | Water Heaters
How to unlock screen
Change battery located on back of thermostat??
Go to google
Search for your model number 1234XX .pdf
Add .pdf in search parameter.
Honeywell posts most their thermostat manuals.
Open pdf file, and then Use Ctrl+F for search feature
Word-Search manual
To find model number on thermostat, remove from wall.
Model number appears on back.
Don't forget to replace battery while you have back exposed.
Dead battery can also cause lockout and malfunction
Apr 18, 2013 | Honeywell TB8220U1003 Commercial Vision...
Richmond 5v40-36f
1) My search does not show that product exists, or existed before the internet.
Maybe that product only exists on fixya.
Or the water heater is older model number from Rheem., aka Richmond, Ruud etc.
Or fixya picked up a model number from a question, and the person asking question did not copy model number correctly from label on side of tank.
It might also be older manufactured home gas water heater.
Feb 07, 2013 | Audiovox Water Heaters
Junkers water geyser pilot is on but main burner will not start
http://documents.junkers.com/download/pdf/file/7181465057.pdf Sometimes there are several parts on this model to find buit beware on some marketing technical made differences inbetween one year of build there can be some modifications inside.
Succes
May 31, 2017 | Water Heaters
Where is the combustion shutoff system on a Rheem 30 gal moble home hot water heater
Disproportionate number of water heater problems are Rheem-related, yet Rheem is just 1 of 3 major water heater manufacturers.
If you have Rheem tank-type gas water heater, and the combustion shut off has tripped the FV system, then there is a broken glass vial located under the burner.
Rheem does not post service manuals, and they may or may not send the glass vial for replacement. Depending on model which appears on label on side of tank. Year of manufacture are 3rd and 4th digits in serial number.
And they may want you to contact a qualified service technician (plumber)
You will have to replace glass vial, and clean the arrestor screen and clean the combustion parts, check gas pressure, and check venting.
Other companies post service manuals and do not rely on the glass vial.
Copy following links:
http://waterheatertimer.org/How-to-repair-Rheem-TRD.html
http://waterheatertimer.org/How-to-replace-thermocouple.html
http://waterheatertimer.org/How-to-troubleshoot-gas-water-heater.html#intellivent
Sep 09, 2012 | Rheem 40 Gallon FVR NATGAS Low WATER...
Light stays on
Question posted under Honeywell thermostat.
If you have honeywell thermostat, then model number is located on back of device.
Google that model number in following format: Honeywell xxxxx4 .pdf
That will give you on-line pdf manual that is downloadable and searchable.
Then re-post question with exact model number and include what you are operating so expert can access and read manual alongside you.
If you have some other device, then post the brand and model number, and include what voltage, and what you are controlling for best possible solution.
If you have a timer or a switch, it is possible that more information is available on following links:
http://waterheatertimer.org/How-to-wire-switches.html
http://waterheatertimer.org/How-to-wire-timers.html
Aug 27, 2012 | Honeywell T6360b1028 Room Thermostat
Water Heaters Logo
47 people viewed this question
Top Water Heaters Experts
Paul Carew
Gil Shultz
Are you a Water Heater Expert? Answer questions, earn points and help others
