Question about Sony Cyber-Shot DSC-P92 Digital Camera
Colors off For some reason all of my pictures have either a green or pink tint to them. I've changed all of the settings I could think of, but all they do is change the shade of the tint. Has anyone else had this problem?
  • 89 Answers
The CCD that senses the picture is faulty. If you are not highly skilled,may be you can change the whole PCB with CCD. If need be we can send this part to you. Pl.let us know.
Posted on Aug 14, 2006
SOURCE:
My sister took my camera out with her to a convention, then when I was about to take a picture last night, the screen was strongly tinted bright pink and when I take a picture, it's tinted green and pink....
If the camera was exposed to very bright light it is possible to have the CCD/imager damaged , There can be a resetting, remove battery off for few hours and set.
If the fault stays it will be better to seek an opinion than to open the camera.
Sep 26, 2010 | Kodak EasyShare C633 Digital Camera
The picture has a green tint to it on all channels
The color signal consists of Red, Green and Blue. Those three colors, at various degrees, make all the other colors on your screen.
If you have a BRIGHT green screen it's best you don't operate your set.
If it's just tinted green then there is a problem on the CRT (Cathode Ray Tube) drive board. Do check your "tint" setting and see if someone misadjusted it. If that isn't it then you need to have your set on an electronics bench and get an estimate for repair.
Apr 17, 2010 | Sony FD Trinitron WEGA KV-27FS100 27" TV
I just replaced the bulb in my Sony 55'' Grand Wega. the picture looked fantastic the first day. turned on the TV the next day and everything that should have a ''white color'' looked pink. the blues...
Please adjust TINT control of Video Settings in Menu that will adjust color tone of TV. I do not think this problem is related with Lamp because TV screen does not have any color blobs or spots.
Above solution is for Sony KDF-55WF655 model TV, if your model number is different, let me know.
Thanks.
Nov 29, 2009 | Sony Grand WEGA KDF-55WF655 36" Rear...
Picture has lots of green
i think that your TV picture tube has a problem..tnx
Sep 09, 2009 | Hitachi 42V710 42" Rear Projection HDTV
My colors are off. Grey/Silver looks pink. I've been playing around with colors/contrast and still can't get good results.
Have you checked the connections to the computer?? They usually become loose after a while, Try spyaying Switch cleaner into the socket. If the picture is still pink there could be a number of reasons, one major one where the green gun in the tube is tired, Another less serious problem which I`ve had quite a few times are the pots (Controls) on the CRT base assembley, they sometimes become dirty which if the green pot is dirty, you will recieve the above mentioned problem. You can easily tell if it`s a dirty pot, try tapping the set, if the green comes on, it`ll either be a dirty pot or a dry joint on the CRT base assy. Ian
Aug 09, 2009 | Dell Computers & Internet
I have a 60" SONY VIDEOSCOPE KP-53V15 the person that i received it from said that the picture sometimes turns pink tinted (the best wasy I can explain this) ... Where things on the screen should be white...
In the back of set you have a red green and blue gun.
two or three problems with sony on this.
sum times the green gun will go intermit.
by gentely taping the neck of green gun while set is on, and you see corection, you need to replace green gun.
in others we have found bad soldier in the HV section of the flyback.
and sumtimes its due to louse conectors going to the HD input in back of the set.
hope this is of help to you.
regards,
daniel.
Jan 15, 2009 | Televison & Video
White colors come out pink and the wth bal is auto
I replied your question about pink tint noise in picture.
Jan 06, 2009 | Sony Cyber-Shot DSC-F717 Digital Camera
My television has a green tint to the picture...help
go into the tv picture settings and there should be an option for colors and try turning the green down, sorry its not an exact solution but i dont own one so just trying to help
Dec 30, 2008 | Pioneer SD-533HD5 53" Rear Projection HDTV
Green tint and psychedelic color swirls in picture
I have a good but with green tint on a polaroid tv model number 64SX505Y-DC02
Dec 28, 2008 | Polaroid FLM-3232 Television
Pink tint when usig the RGB component cable
Check the green signal lead - if one of the RGB leads doesn't make good contact, the picture will take on an odd tint that doesn't always look like it's missing one of those colours. For some reason, the green is always the most common one to fail.
Feb 28, 2008 | NEC MultiSync VT540 Multimedia Projector
Sony Cyber-Shot DSC-P92 Digital Camera Logo
80 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
JonSnell Electronic
JonSnell Electronic
 Russ Hill
Russ Hill
Are you a Sony Camera Expert? Answer questions, earn points and help others
