Question about Husqvarna Riding Lawn Mower 42 Inch Cut Yth2042
Yth-2042-v belt installation
The clutch locator needs to be removed so I can slide the V-belt on the engine pulley.Where is that screw on the clutch locator that needs to be removed ?
5 Suggested Answers
youcandoit2
  • 11 Answers
SOURCE: Husqavarna engine pulley?
Do you have a manual for the tractor?
Posted on Jul 17, 2009
  • 146 Answers
SOURCE: Husqvarna YTH 2042 lawn tractor
If it really 'lugs', meaning the engine gradually chugs slower and slower as if it's struggling, then it could be a belt problem, but I'm going to guess it just quits, which suggests a problem with the seat safety switch. Look under the seat, take out the safety switch, and tape it in the pushed-in position. See if the tractor runs now. If so, the switch is the culprit - either it failed, or the mounting is wonky so it doesn't activate when you're in the seat.
Posted on Jun 05, 2010
  • 5370 Answers
SOURCE: Mower blades will not engage
Start by checking to see if you have pulled one of the electric wires loose that acts as a safety to disengage the clutch. Check all wires to make sure none are pulled loose. Then check all wires to see that none are bare and contacting metal (grounding out) causing the mower deck to not operate. This happens often.
1- the clutch mechanism may be obstructed - check above mower assembly and clear obstructions;
2- mower clutch engagement switch may be faulty - replace if needed;
3- the mower drive belt may be loose, damaged or disengaged - repair, adjust or replace belt;
4- the idler pulley could be frozen - replace;
5- the blade mandrel may be frozen - replace.
Check the wiring at the clutch itself. There should be a quick connector right near the clutch itself. You can test these wires to see if you have 12 volts coming out of them when the PTO switch is pulled out. You can also check the clutch by using jumper wires and running them directly to the clutch. Once connected you should hear an audible click of the clutch engaging. If you get nothing then the clutch has gone bad on you.
If you hear a click while you run down 12v from battery down to clutch lead.Then there is a confirm break or cut in the wirings.
There is something between the battery and the clutch that is not allowing power to come through to the clutch. USe a test light or meter and trace the wiring back from the clutch to the switch, then from the switch back to the battery.
Most likely, the problem is a safety switch. Sometimes its a "seat switch" which prevents the blades from engaging if the operator isn't sitting down.
to get manual for your mower please click the link below
http://technoanswers.blogspot.com/2011/05/husqvarna-lgt-2564-mower-manual-and.html
This should help.Thanks.Helpmech.
Posted on May 25, 2011
philwalker78
  • 608 Answers
SOURCE: Hi, i have a yth
Hi, have you re-engaged the manual release rod? Regards Phil.
Posted on Jul 20, 2011
Looking for belt drive 2042 rail sprockets
Notes on replacing drive sprocket on Genie 2042 belt drive garage door opener.
The unit originally came with a cast metal sprocket disk with a plastic sleeve insert that formed the sprockets themselves. The plastic insert's sprockets shattered when I tried opening the garage door that had frozen shut with ice. Genie's service assistant was of no help, as she suggested that I remove the entire rail then call them back. Removal of the rail was totally unnecessary. I purchased an all metal sprocket designed for the 2042 from an on-line supplier. Neither the owner's manual nor on-line instructions were available to assist me. I followed these steps:
    1.With the door open, loosen the tension on the belt by turning the bolt in the tension assembly located on the rail opposite side of the motor. Slide the belt off the pulley and let the belt hang.
    2.The sprocket housing is located on top of the motor. Unscrew the two Phillips screws that hold the sprocket housing onto the motor assembly.
    3.Using a screwdriver, force the cover up. The cover is on a hinge-like appendage that is riveted onto the rail frame. With the housing pried up, the belt and sprocket can be seen.
    4.Pull the belt out of the housing to allow the old sprocket to be removed. Be careful to locate the black plastic bushing/spacer on top of the old sprocket and save it for the new sprocket.
    5.Install the new sprocket and bushing/spacer into the motor shaft along with the belt.
    6.Replace the two Phillips screws on the sprocket cover.
    7.Place the belt back on the tension assembly and tighten to manufacturer's specifications.
    8.If the motor won't run from the wall switch, the up/down limits need to be reset. The motor will move the garage door up and down using the control buttons on the bottom of the motor unit. Follow the manufacturer's instructions on setting the up/down limits, which include holding the "set" buttons for over 5 seconds once the garage door is in the desired up and down locations.
Mar 29, 2013 | Home Security
I've got a 2005 husqvarna yth 2042 riding mower,i broke one of the belt guides,(on order)-the spring extension for the clutch,where does it hook to?
Not too sure which guide you are refering too, the only keeper at the clutch is the anti rotation bracket for the clutch itself, it bolts to the side of the chassis and the other end sits into a cut a way in the side of the clutch assembly.
Apr 24, 2012 | Husqvarna Riding Lawn Mower 42 Inch Cut...
How to remove alternator on a 2005 range rover
Hi
Click here
the link above should tell you all you need to know if you get stuck or have any problems give me a shout back ok
Oct 26, 2010 | Land Rover Range Rover Cars & Trucks
The belt dry rotted and flew off without me being able to remove it myself, now I need to know how to install the new drive belt.
To install the drive belt you will have to remove the drive belt first.
Follow the procedure: ---
Park the tractor on a level surface. Set the parking brake and remove the key from the ignition. Study the belt replacement guide decal located underneath the left foot board for proper belt routing instructions.
Remove the mowing deck by first moving the attachment clutch lever to the disengaged position (toward you). Move the attachment lift lever all the way forward to lower the mower housing to its down position.
Crawl beneath the tractor and roll the drive belt off engine pulley (it hangs directly beneath the engine). Remove small retainer clip that holds the clutch spring to the pulley bolt located at the center of the mowing deck. Remove the large retainer springs (two of them), then slide the belt collar away from the mower housing and off the housing bracket.
Disconnect the anti-sway bar rods from the chassis brackets by removing the retaining cotter pins. Disconnect front links from the mower deck by removing retaining cotter pins. Disconnect the suspension arms from the rear mower deck brackets by removing the two cotter pins.
Move the attachment lift lever all the way to the forward position to raise the mower suspension arms to the full up position. Slide the mower deck out from beneath the tractor.
Crawl beneath the tractor and roll the drive belt off of the stationary idler pulley and the clutching idler pulley. They are both located immediately adjacent to the engine pulley. Be sure the belt is already away from the engine pulley, as well.
Push the drive belt slack toward the rear of tractor. Remove the drive belt from the Trans axle pulley by taking it over the trans axle pulley while compressing the movable belt keepers surrounding it. Remove the old belt from the tractor by pushing it clear of the center span keeper (located beneath the Trans axle pulley).
Install a new drive belt by following the reverse of the instructions for removal. Test the tractor and mower for normal operation.
 Thanks. Keep updated for any more query. You can rate this solution and show your appreciation.
Jul 19, 2010 | Garden
I need to remove the cooling fan shroud from my 1995 Lincoln Continental. How is the easiest way to go about this?
Engine Fan REMOVAL & INSTALLATION 3.8L Engines
  1. Disconnect the negative battery cable.
  2. Remove the radiator upper sight shield.
  3. Disengage the electrical connector, then remove the integrated relay control/constant control relay module assembly located on the radiator support.
  4. Disconnect the fan electrical connector. Fig. 1: Disengage the fan electrical connector 86873115.jpg
  5. If necessary, remove the air bag crash sensor.
  6. Unbolt the fan/shroud assembly from the radiator and remove. Fig. 2: Unbolt the fan assembly from the radiator 86873116.jpg
    Fig. 3: Remove the fan from the engine 86873117.jpg
    Fig. 4: Slide the fan as an assembly up and away from the radiator. Be careful not to dislodge the mounting stud on the left side. 93143p56.jpg
  7. Remove the retainer and the fan from the motor shaft and unbolt the fan motor from the shroud.
  8. Installation is the reverse of the removal procedures. Tighten the fan shroud retaining bolt to 23–33 inch lbs. (2.6–3.7 Nm). Tighten the fan shroud retaining nut to 71–106 inch lbs. (8–12 Nm). Fig. 5: Constant control relay module location — 3.8L engines 86873118.gif
4.6L Engine
  1. Loosen the fan clutch-mounting shaft from the water pump hub.
  2. Loosen the fan shroud from its radiator mounting and remove the lower hose from the shroud.
  3. Lift the fan and clutch assembly and the fan shroud from the vehicle.
  4. If necessary, remove the fan-to-fan clutch retaining bolts and separate the fan from the fan clutch. CAUTION
    Closely examine the fan for cracks or separation, to avoid the possibility of personal injury or vehicle damage. To install:
  5. Assemble the fan and fan clutch. Tighten the retaining bolts to 15–20 ft. lbs. (20–27 Nm).
  6. Install the fan and clutch assembly and the fan shroud. Mount the fan clutch shaft to the water pump hub and tighten to 37–46 ft. lbs. (50–62 Nm).
  7. Slip the shroud into the lower mounting clips and install the shroud retaining screws. Fig. 6: Fan and fan clutch assembly — 4.6L engine 84173064.jpg
5.0L Engines
  1. Loosen the fan clutch-to-water pump hub retaining bolts.
  2. If necessary, remove the drive belt from the water pump pulley.
  3. Remove the fan shroud upper retaining screws. Lift the shroud to disengage it from the lower retaining clips.
  4. Remove the fan clutch-to-water pump hub bolts and remove the fan and clutch assembly and the fan shroud.
  5. If necessary, remove the fan-to-fan clutch retaining bolts and separate the fan from the fan clutch. CAUTION
  6. Assemble the fan and fan clutch. Tighten the retaining bolts evenly and alternately to 12–18 ft. lbs. (16–24 Nm).
  7. Install the fan and clutch assembly and the fan shroud.
  8. Install the fan clutch-to-water pump hub bolts.
  9. Slip the shroud into the lower mounting clips and install the shroud retaining screws.
  10. If removed, install the water pump drive pulley and adjust the belt tension; refer to Section 1.
  11. Tighten the fan clutch-to-water pump hub bolts evenly and alternately to 15–22 ft. lbs. (20–27 Nm). Recheck the belt tension.
Jul 14, 2010 | 1995 Lincoln Continental
Removing power steering pump from v8 windsor
Section 11-02A: Steering Pump, Power, C-II 1996 Aerostar, Ranger and Explorer Vehicles Workshop Manual REMOVAL AND INSTALLATION Pump and Pulley SPECIAL SERVICE TOOL(S) REQUIRED Description Tool Number Steering Pump Pulley Remover T69L-10300-B Steering Pump Pulley Replacer T65P-3A733-C
Removal
  1. Disconnect the power steering return hose (3A713) at the pump and drain fluid.
  1. Remove the power steering pressure hose (3A719) by unscrewing connector from the pump.
  1. On the Aerostar 3.0L V-6 engine (6007), loosen the drive belt tensioner (6B209) and adjustment bolts.
    Item Part Number Description 1 10346 Generator 2 8501 Water Pump 3 8678 Belt Idler Pulley 4 3A733 Power Steering Pump Pulley 5 6303 Crankshaft 6 2884 A/C Clutch 7 — Without A/C On the 2.3L I-4 and 4.0L V-6 engines, slacken belt tension by lifting drive belt tensioner in a counterclockwise direction. On Ranger 3.0L V-6 engines, slacken belt tension by lifting drive belt tensioner in a clockwise direction. Remove drive belt (8620) from under drive belt tensioner and slowly lower pulley to stop. Remove the drive belt from the power steering pump pulley (3A733).
    Item Part Number Description 1 10346 Generator 2 2884 A/C Clutch 3 3A733 Power Steering Pump Pulley 4 8501 Water Pump 5 6303 Crankshaft 6 8678 Belt Idler Pulley 7 6B209 Drive Belt Tensioner
  1. NOTE: If the drive belt requires servicing, refer to Section 03-05 .
    Remove the drive belt from the power steering pump pulley.
  1. Remove the oil dipstick tube.
  1. Remove the power steering pump support (3C511).
  1. Install Steering Pump Pulley Remover T69L-10300-B on the pulley.
  1. NOTE: Do not apply pressure on the power steering pump rotor shaft (3B559). Pressure will damage internal thrust areas of the power steering pump (3A674).
    While holding the remover tool nut stationary with a wrench, rotate the inner spindle of the remover tool clockwise until the pulley is pulled off the power steering pump rotor shaft.
  1. Remove the bolts attaching the power steering pump to the A/C compressor mounting bracket (2882).
Installation
  1. Install the power steering pump on the A/C compressor mounting bracket. Install and tighten attaching bolts to 41-61 Nm (30-45 lb-ft). On 4.0L engine, tighten to 47-64 Nm (35-47 lb-ft).
  1. Position the support on the A/C compressor mounting bracket. Install mounting bolts and tighten to 47-64 Nm (35-47 lb-ft).
  1. NOTE: Fore/aft location of power steering pump pulley on power steering pump rotor shaft is critical. Incorrect belt alignment may cause drive belt squeal or chirp. Make sure pull-off groove on power steering pump pulley is facing front and flush with end of shaft ± 0.254mm (± 0.010 inch).
    Install the Steering Pump Pulley Replacer T65P-3A733-C and install the power steering pump pulley.
  1. Install the drive belt on the power steering pump pulley.
  1. On the 2.3L I-4, Ranger 3.0L V-6, and 4.0L V-6 engines, position and rotate drive belt on engine. While lifting drive belt tensioner in a counterclockwise direction (clockwise on Ranger 3.0L V-6), slide drive belt under drive belt tensioner and lower drive belt tensioner to drive belt.
    On Aerostar 3.0L V-6 engine, position the belt idler pulley (8678) assembly to give the drive belt the tension specified. Refer to belt tension check in Section 03-05 . Tighten the drive belt tensioner and adjustment bolts to 47-64 Nm (35-47 lb-ft).
  1. Install the power steering pump support, if removed.
  1. Install the oil dipstick tube.
  1. Install the pressure hose tube nut and new Teflon® wagner into power steering pump valve outlet fitting (3D654) and tighten to 41-54 Nm (30-40 lb-ft).
  1. Connect the power steering return hose to the power steering pump, and reposition the clamp.
  1. Fill the power steering oil reservoir (3A697) with Premium Power Steering Fluid E6AZ-19582-AA or equivalent fluid meeting specification ESW-M2C33-F. Start the engine and turn the steering wheel (3600) from left to right without hitting stops to remove air from the system.
  1. Check for leaks and recheck the fluid level. Add fluid if necessary to proper level as specified in Section 11-00 .
    Power Steering Pump and Power Steering Pulley, 2.3L TPH Engine, Ranger Only
    Item Part Number Description 1 2882 A/C Compressor Mounting Bracket 2 N606543-S2 Bolt (2 Req'd) 3 N606069-S2 Bolt (2 Req'd) 4 N605803-S2 Bolt 5 N800199-S8M Screw 6 3D673 Power Steering Pump Pulley 7 3F671 Power Steering Belt Idler Support 8 N806020-S2 Bolt 9 3A674 Power Steering Pump 10 19703 A/C Compressor A — Tighten to 21.2-29 Nm (16-21 Lb-Ft) B — Tighten to 40.3-55 Nm (30-41 Lb-Ft) C — Tighten to 44-51 Nm
    (32-38 Lb-Ft)
    Power Steering Pump and Power Steering Pulley, 3.0L Engine, Aerostar
    Item Part Number Description 1 3A674 Power Steering Pump 2 3C511 Power Steering Pump Support 3 6007 Engine 4 N803564 Stud 5 N802827-S2 Nut 6 N800199-S8M Screw (3 Req'd) 7 N8011179-S2 Screw (3 Req'd) 8
Jun 09, 2010 | 1996 Ford Explorer
Husqvarna YTH 2042 lawn tractor It starts OK, but as soon as I take my foot off the clutch, it lugs and quits. Same thing happens if I start to engage the clutch lever, even with my foot still on the...
Jun 05, 2010 | Husqvarna Lawn Tractor - 54in. Deck, 26...
Where can i fine manual for engine replacement
TO REMOVE THE PULLEY FROM THE CRANKSHAFT END:
Remove the blade belt and, if needed, the deck to give yourself more room to work. Apply your brake pedal and lock it down, this will relieve the tension on the ground drive belt.
If you have an electric blade clutch, find the plug where the wire goes over from the clutch to the frame and unplug it.(Electric clutch will be heavy when unbolted so be ready for it.)
In the center of the pulley or blade clutch you will find a long bolt (most likely a 5/8 head on it) You may need a deep socket to reach it depending upon the type of stack pulley on it, remove this bolt and the pulley should slide freely on the crankshaft. slide it downward and slip off the belt on the top of the pulley then remove the pulley the rest of the way
Oct 05, 2009 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
How do you detention the serpentine belt on ford 4.2l
you did not specify engine (4.2l, 4.6l, 5.4l) or if a/c. here's with a/c
Component Locations — 4.6L & 5.4L with A/C
Item Part Number Description 1 8678 Belt idler pulley 2 10344 Generator pulley 3 8620 Drive belt 4 3A733 Power steering pump pulley 5 8509 Water pump pulley 6 6312 Crankshaft pulley 7 6B209 Drive belt tensioner 8 2E884 A/C clutch pulley
303-05: Accessory Drive 2000 F-150 Workshop Manual
REMOVAL AND INSTALLATION Belt —4.6L, 5.4L With A/C Removal and Installation
  1. Rotate the tensioner clockwise and remove the drive belt.
  1. NOTE: Refer to Component Locations— 4.6L, 5.4L with A/C for correct drive belt routing.
    To install, reverse the removal procedure.
please rate as fixya if this is what you needed.
Mar 21, 2009 | 2000 Ford F150 Flareside SuperCab
Husqvarna Riding Lawn Mower 42 Inch Cut Yth2042 Logo
50 people viewed this question
Top Husqvarna Garden Experts
Phil Walker
Phil Walker
Roland W VanLue
Roland W VanLue
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
