Question about Lexmark Office Equipment & Supplies
I am trying to put my printer into my computer
    Genius:
  • 1,124 Answers
Do u need to install the printer?
Posted on Oct 24, 2008
Your printer won't fit inside your computer unless you build your own case.
My X3400 will not accept a scan from my printer
Did you reinstall the printer on your PC? Did you install the correct version of the printer software? If your old computer and new computer has different versions of windows, then make sure you put the correct version on the new computer.
Also, you should be able to start the scan from the computer if you have the software loaded correctly and both are communicating. If you are doing it from the Printer, it might be trying to find a folder to put the scans that were on the old computer and not the new one.
Apr 10, 2012 | Acer Aspire X3400 PC Desktop
Printer is printing foreign looking characters all on its own. No print jobs are being sent to the printer. Printer is set to DEC mode and the macro has been reloaded several times. As soon as you put the...
It sounds like data is being received by the printer from an outside source.
Try disconnecting the printer from the computer system so it is a free standing printer. Power the printer ON and put in ONLINE if you do not get strange characters printing the print job is definitely from the computer system some place.
If you do not get the print jobs printing when the printer is disconnected from the computer system, it could be that the print jobs are being sent from the wrong driver or print queue on the system, you may need to try to identify who is sending the rogue print jobs.
Feb 10, 2010 | TallyGenicom LA800+ Matrix Printer
I have a dell with windows vista and it will not except a printer.we tryed two printer put new usb cable to computer and printer it says not communicating with printer. printers work my daughter put them...
You may need to update windows
and the chipset software
if you have a thumb drive try it to see if it works on the computer
if not update windows and all drivers
Good Luck
Happy Computing
Jan 09, 2010 | Dell Inspiron 530 Desktop Computer
I try to install my dell 924 printer.i put installed put it is not reconginzed by the computer
Have you tried searching for new hardware?
Try restarting the computer to see if it sees the printer.
I am sure the printer is on and plugged IN.
Have you installed the drivers and software yet?
Have you tried going through "add a printer"?
Dec 09, 2009 | Dell 924 All-in-One InkJet Printer
Cannot print from computer. printer will print test pages, though
How the printer is connected to PC Via USB or using Network Cable. If it is connected Netwrok cable than printer configuration page and on netwrok configuration there will be IP Address if this is valid IP Address than reinstall drivers and upgrade the Firmware of the printer.
If Printer is connected USB than try different USB Cable and try different USB Port on the computer
If USB port on the computer is working fine and check in Device Manager if the printer has detected as unknown device or not detected at all.
If detected as unknown device than reinstall printer driver if not detected at all than USB Port on the printer is faulty you need to set up hardware repair of the printer.
Oct 16, 2009 | HP Color LaserJet 3500 Printer
I had computer problems today and had to swop my hard disk into another computer box. After doing that my Brother MFC8460N faxed and copied but does not want to print from my computer at all. I uninstalled...
Trying connecting the USB printer to some other computer,
to see if the other computer recognizes the printer.
Try a different USB port on your computer.
Try a different USB-device (memory-stick? camera?) into your USB port, to confirm that the USB-port is working.
Jul 16, 2009 | Brother MFC-8460N All-In-One Printer
Ran ink out of resevoir tank how do I refill
  • Unplug the printer cable from the computer.
  • Unistall the printer drivers from Device manager and also unistall the all the printer appications
  • restart the computer
  • try to download dell printer software from the website
  • after installing drivers and software it will ask you to connect the printer.
  • then you can connect the printer and and try to Print the test page.
Hope this help. Please Rate My Response! Thanks!
PREM
May 24, 2009 | Dell A920 InkJet Printer
Wont print from the computer
Try to reboot your computer and print it again.
Feb 27, 2009 | Lexmark X5470 All-In-One InkJet Printer
Communitcate/test sheet
You didn't mention installing the 920c on your computer. You should have received an HP Deskjet 920c series printer software CD which installs the printer on your computer. You may need to check the HP web site to see if your computer is equipped with the appropriate driver. The 920c is an older HP printer. One of my printers is a 920c and I had no problem installing it a computer with Windows XP.
Sep 08, 2008 | HP DeskJet 920c InkJet Printer
20 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
