Question about RTO Massey-Ferguson Tractor TE20, TO20, TO30, ITFE2
TO-30 quit running, puff of smoke from electrical? Won't turn over
Burried the tractor in the yard. Was using the Jeep to pull it out, about 20 min of work, then when almost there, in reverse, tractor quit, little puff of smoke at rear of engine, below battery that smelled electrical. Now won't even crank, but batter at 12 volts and can hear clicking. First thought is solenoid but that wouldn't stop engine from running, would it? I think I have a short somewhere. Didn't seem like something mechanical let loose, but was working it hard. What else could I check electrically? How can I test solenoid? What else could I look for? Thanks!
  • 1,057 Answers
It is possible to have the solenoid go bad but not while the tractor is running as it is only used to engage the starter. It sounds like the wires to the starter is shorted out. I would run a hot wire to the solenoid from the battery to the solenoid and see if it will start. Just be sure everything is grounded. If the ground cable on the battery is ok you should not have a problem with running a hot wire to the solenoid. Just touch the hot wire to the starter and then release it when the starter engages. Hope this helps.
Posted on Apr 16, 2017
  • 16 Answers
SOURCE: ATV will pull start but won't electric start?
sounds like a dead battery, if not than its probably the rectifire. if you need me to help i can.
Posted on Jul 24, 2009
SOURCE: My Artic cat 650 will pull start, but will not
My artic cat 90 4 wheeler eletric start wont engage???Has new battery and NOTHING????
Posted on Mar 06, 2010
  • 24 Answers
SOURCE: 12 volt or 6 volt?
should be 12v
Posted on Jun 29, 2010
SOURCE: 2007 Arctic Cat LCD Speedometer, gas gage, also 4
did you figure out the problem because mine just did the same thing.
Posted on Jun 30, 2010
roniecon
  • 6927 Answers
SOURCE: I have a TO-35 Massey
The only thing left to check is the timing,and the fuel,make sure there is no contamination in the fuel ,and no water,try a cleaner,and a dryer for the fuel.It does sound more like the fuel.
Posted on Aug 17, 2010
83 ford ranger carb backfire
Which engine and what type ignition system? How many miles on it? Timing chain or belt? don-ohio
Mar 24, 2017 | Ford Ranger Cars & Trucks
My mtd yard machine (leaf blower) started billowing white smoke. I shut it off and now it won't start again.
First check the oil level. If its overfilled correct it. Then remove the spark plug and turn the engine over. Replace the spark plug.
Start the engine. Use a prime ( squirt carb cleaner into carb) if you need to. It may start smoking again. Thats OK as long as you know there is oil in it and you dont hear any strange noises. Let the unit run for about 5-10 minutes and see if the smoke clears up. Once it quits smoking stop it and check the oil.
Nov 11, 2012 | Garden
Model 917.370410 won't start
Sounds to me like this model is a POS. I also have this same model, purchased last August have used only 5 or 6 times , has the same symptoms: hard pull, puff of smoke, won't run , etc. Even brought this to an authorized dealer to get it to run, but then it only ran a couple more times, dead again. Does anyone know of any recalls fro this lemon? I can appreciate everyone troubleshooting , but you shouldn't have to tear apart a 5 month old lawnmower which will only result in your warranty being voided.
Oct 04, 2012 | Craftsman 675 Torque 190cc 21" Briggs ...
Will not start
there is usually a 20 amp fuse next to battery check to see if that is blown
Jun 28, 2010 | Husqvarna 24HP 54" Yard Tractor ()
I have a 21.5 HP 42in. deck mower that I just bought (used), having a little trouble with. Mower starts fine, and runs great... until it heats up, then it starts spitting and sputtering, blows out black...
The black smoke is too much fuel, it is flooding out. Carb issue, I would pull the float bowl and clean carb, the needle in carb is stuck open pumping too much gas in.
Mar 19, 2010 | Craftsman 21 hp 42 in. Deck Yard Tractor -...
Smoking Craftsman Riding Mower
1st thing, check your dipstick up inside the cap part of it and make sure the O'ring is there and in good condition.
2nd, make certain when you put it back on that you get it on straight and firmly seated. They will only seat one way properly the other way creates a leak into the crankcase and causes oil consumption and smoking. You should be able to tell if it has been improperly installed by an excessive amount of oily dirt accumulated around the threaded area of the cap
Sep 15, 2009 | Craftsman 20 hp 42 in. Deck Yard Tractor
Husqvarna yth1848xpt with a kawaskie 20 hp puffs black smoke
I had the same problem with my YTH1848XPT . Believe it or not it is simply a dirty air filter....you must remove the filter and blow it out with an air compressor...or better yet replace it. you can not clean it well enough without the force of the air compressor. Mine works great now.
Jun 08, 2009 | Husqvarna Lawn Tractor 48" Deck, 23 Hp,...
RTO Massey-Ferguson Tractor TE20, TO20, TO30, ITFE2 Logo
69 people viewed this question
Top RTO Toys Experts
The Scrivener
Pete Bruk
rostit
Are you a RTO Toy Expert? Answer questions, earn points and help others
