Question about Black & Decker 7 - 1/4" Heavy Duty Circular Saw Kit, 120V, 2300 Mwo, 580
Change blade on a black and decker circular saw, model 7390
  • 17 Answers
SOURCE: I have a 2hp black and decker circular saw. Went
If the motor is 3 phase (which it may be if it is 2 HP) , it will run backwards if 2 of the wires are traded position. You may have changed the wires in the plug if you replaced a plug.
Posted on Jun 12, 2009
rowdy45176
  • 2176 Answers
SOURCE: I need an Owners Instruction Manual for a Black
you might want to try Dewaltservicenet.com with the exact model number of this tool for that manual
Posted on Jul 25, 2009
rowdy45176
  • 2176 Answers
SOURCE: I can't tighten the blade on the saw.
are both flanges in place and on correctly?? That would be the first thing that I would look for.
Posted on Dec 30, 2009
  • 5603 Answers
SOURCE: My black and decker, circular saw, blade moves
Some things like this we have to improvise. Possibly a filler washer can be used. It is not clear if the shaft end play is what you have, or the blade clamping washers allow the movement. If it is the blade clamping, possibly there is a burr on the washer that prevents the proper mating of the clamping washers.
If it is shaft end play, then try to use a fiber type washer to fill the gap.
Posted on Feb 10, 2010
al_kupchella
  • 843 Answers
SOURCE: How can I change the circular saw in my Back &
Unplug it and loosen the bolt in the middle of the blade. It's a standard thread, so turn it lefty-loosey. But you need to hold the blade from turning. That's easy by putting a screwdriver in front of a blade tooth, under the sole plate. Let the sole plate prevent the screwdriver from rising up with the blade as you turn the bolt. If your current blade has small teeth (like a plywood blade) then you can raise the sole plate as for a maximum depth of cut, then push the saw against the front edge of a workbench (or block of wood somehow held still) as if you were going to cut it. Before you remove the bolt, take note of the exact orientation of the washer (or washers)so you can replace them the same way.
Posted on Jun 18, 2010
Testimonial: "Thank you very much; more or less what husband had tried to do, but none the less he's going to try again, according to your instructions. Will let you know the result later. J"
How to use the kerf plate on black and decker cs108b
I am bit confused, what's a kerf plate? What blade are you using? I use blades from saw blade.com .
Dec 07, 2013 | Black & Decker Black Decker Firestorm 18...
I have a Black and Decker KS555 circular saw and
It appears that you have adaptors for the blades that are the same thickness as the blades Place the adaptor in the centre and then put on the spindle and tighten up the plates onto the blade.
Sep 05, 2013 | Black & Decker Tools & Hardware - Others
Need parts for Black and Decker circular saw model 7390
Go to
http://www.ereplacementparts.com/black-and-decker-7390-type-circular-saw-parts-c-4167_4252_12157.html
Jan 24, 2013 | BLACK and DECKER POWER TOOLS Black And...
How to change the blade
first look for small button in the opositive side of blade, smash on it, move the blade till stops and then remove nut......
Jun 21, 2011 | Black & Decker 7 - 1/4" Heavy Duty...
How can I change the circular saw in my Back & Decker Circular Saw, model: P3703 (1100 watts)
Jun 18, 2010 | Black & Decker Saws
Dec 30, 2009 | Black & Decker Saws
Change blade on old model Black & Decker circular saw
I drp a screwdriver through one of holes in the blade; that "locks the blade" when the screwdriver comes up against the sole plate. Works great for tightening as well.
Oct 25, 2007 | Black & Decker S500 ScumBuster Handheld...
Black & Decker 7 - 1/4" Heavy Duty Circular Saw Kit, 120V, 2300 Mwo, 580 Logo
352 people viewed this question
Top Black & Decker Saws Experts
Jason
Mike Carew
Are you a Black & Decker Saw Expert? Answer questions, earn points and help others
