Question about RCA RT2500 System
Rca rt2500 rec
When ever i turn the stereo up, it totally cuts out and shuts off the unit. i am using 6ohm speakers like the back of the unit suggests. why does it do this? is it a easy fix? thanks mdubz
I'd suspect your power supply capacitors are on their last leg. replace them.  - This was posted by videoguy1742. :   this problem is CURED simply by replacing 2 capacitors inside on the main board. They are easily identified by a bulge on the top end of the capacitors. The capacitors are located between the heat sinks. The size is 6800uf/16v.
I am a RadioShack dealer and sold a few of these in 2000/2001. I bought one for myself. I have repaired only 2 that had the same problem as listed by HAGUC above. They both are working great and for the record. . .are NOT peices of JUNK,. . .hehe. . .they just need a little TLC. Parts available from larger electronics parts houses, not at RadioShack
Posted on Oct 28, 2007
HELLO: KENWOOD MARINE STEREO WHEN TURNING UP THE VOLUME ABOUT HALF WAY THE RADIO CUTTS OUT TILL YOU TURN IT BACK DOWN THEN IT COMES BACK ON.
You have a grounded out speaker wire or blown speaker. Disconnect speaker wires at the unit. Make sure the wires are not touching, turn the unit on, then turn the volume back up. If it stays on, it is a wire or speaker. Re-connect one speaker at a time and test. once you find the bad wire/speaker, disconnect the wire at the speaker and test again. This will determine if it's the speaker or wire.
If after disconnecting the speaker wires it still cuts out, check your ground and meter the DC voltage at the power wire. If you do not have enough current at the radio, it will shut off as well. Usually this will happen at about 9.8v dc.
If you still need further help, post a reply/comment and I can help you dig further.
Jul 11, 2011 | Kenwood Car Audio & Video
I have Cerwin-Vega speakers that are 4 ohms, what do I set the impedance at?
You can set the speaker impedance in the Advanced menu. See page 45 of english manual (it can be on different page in other language manual).
In standby mode, on the receiver (not on remote!) press STANDBY/ON while pressing and holding STRAIGHT button. THe "ADVANCED SETUP" should show in the LCD display. Now use PROGRAM +/- buttons to navigate the menu. Select "SP IMP." which is speaker impedance setting. Press STRAIGHT to select the correct value. Options are 6ohm and 8ohm. 6ohm setting means 6 and less, so select this option. Now you can turn the unit off by using STANDBY/ON. Now when you turn it on again, it will use these new settings.
Feb 08, 2011 | Yamaha Rx-v465/rxv465 Home Theater...
Sony CDX-CA810X / CD-playback drops aux amplifier
Do you have the remote turn on lead hooked up to solid blue wire from the back of the deck? Your amp shoild be hooked up to Bluw w/ white strip as the solid blue wire shuts off when the tuner is off, its used only for the power antenna.
Use Blu w/ Wht strip for amps
Jun 03, 2009 | Sony CDX-CA810X CD Player
Head Unit of boat stereo cutting out at higher volume
check your ground wire ..
then check battery has enough charge..
usually fault is in where your stereo is connected to your ground source.. good luck ,if no luck try your checking your speaker wires for a short..
May 14, 2009 | Kenwood Car Audio & Video
Pioneer stereo receiver has sound and power problems.
i would suggest checking the wires on the speaker switch board, thats usually the main cause of this problem..but i dont recommend buying pioneers newer stuff
May 04, 2009 | Pioneer Audio Players & Recorders
I have a jvc home stereo model number CA-HXC6 i have had it for a few years its on protect mode and i cant get it off dont know how it cuts off
Turn off power, unplugg unit, very carefully check speaker wire connections making sure no wires are touching each other or the back of the unit same at speakers connections. Also check speakers. Blown drivers can short terminals internally. This is the most likely problem. Remove the short, unit will come back on
Dec 21, 2008 | Bose 901 VI Main / Stereo Speaker
I have a new RX V661 7.1, shuts down when I turn it up.
How much loudness are you trying for. Also, the program material and bass/treble settings factor in when asking a system for increased power...accordianman
Jun 19, 2008 | Yamaha RX-V661 Receiver
Str-D590
This is not a reset. Most likely one or more transistors have shorted and need to be replaced. Does the front display come on OK?
Dan
Apr 29, 2008 | Audio Players & Recorders
Interior speakers cut out when the volume is turned up
You may have speakers of an incorrect impedance attached to the unit since the problem occurs when audio signal level is increased and the current goes up.The unit is shutting down to prevent damage. I would check the speaker connections and make sure that the speakers impedance are matched for the unit you are using.
Sep 03, 2007 | Eclipse EA3422 Car Audio Amplifier
RCA RT2500 System Logo
139 people viewed this question
Top RCA Audio Players & Recorders Experts
Gyula Lacz
Are you a RCA Audio Player and Recorder Expert? Answer questions, earn points and help others
