Question about Sharp EL-1197PIII Calculator
Loading paper paper will not load into printing area
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Sharp Master
  • 102,366 Answers
See the illustrated instructions on the first page of this manual.
Posted on Apr 07, 2013
Gympac 1600 manual
Device error An internal error occurred in the device. Press (Select) to resume the job. - Door open The printer door is open. The door must be closed before printing can continue. - Engine comm. error The device experienced an internal communication error. This is a warning message only. Job output might be affected. - Invalid driver You are using the incorrect printer driver. Reselect the printer driver appropriate for your device. - Invalid entry Invalid data or response. Correct the entry. - Jam in Cartridge area A paper jam has occurred in the print path. Open the door and clear the jam. Then press the (Select) button on the control panel - Jam in Output bin A paper jam has occurred in the output area. Clear the jam, and then press the (Select) button on the control panel. - Jam in print paper path. A paper jam has occurred in the print path. Open the door and clear the jam. Then press the (Select) button on the control panel. - Jam in tray 2 A paper jam has occurred in Tray 2. Clear the jam, and then press the (Select) button on the control panel. - Jam in tray 3 A paper jam has occurred in Tray 3. Clear the jam, and then press the (Select) button on the control panel - Load paper The HP Color LaserJet 1600 printer is out of paper. Please load specified paper type into the tray indicated. - Load Tray X [TYPE] [SIZE] The printer is processing job, but the tray indicated is empty. Please load specified paper type and size into the tray indicated. - Manual feed The printer is waiting for paper in the tray indicated Load the paper as indicated. - Memory is low The device memory has been almost completely filled. Allow the device to finish the job, or press (Select) to cancel the job. Break the job into smaller jobs that contain fewer pages. - Misprint The printed pages have been incorrectly placed on the paper. To continue, press the (Select) button on the control panel.
Dec 31, 2014 | Office Equipment & Supplies
I have an imagerunner 2800 and it only seems to jam in the tray loading area, just bends the long side of the paper randomly. It changes it's performance just like the weather, sometimes I can get multiple...
A couple of things to consider:
Do not load the following types of paper in the paper drawer. Doing so may cause a paper jam.
- Severely curled or wrinkled paper
- Heavyweight paper
- Transparencies
- Paper on which color images have been copied.
- Paper which has been copied on using a digital full color copier (do not copy on the reverse side
either).
- Paper which has been printed on using a thermal transfer printer (do not copy on the reverse side
either).
Also, what # paper are you using?
Oct 12, 2013 | Canon (6981A002AA) for imagerunner 2200,...
I have a Dell 3000cn printer it is saying load paper but the paper is loaded but wont print
check whether the cartage is fix well or the paper is far from the area from where the printer starts printing.
Jan 27, 2011 | Dell 3000cn Laser Printer
Paper sensor faulty - printer doesn't recognise when paper is loaded
Cannot print from the glass top. The top load area keeps running and then the message says to reload the original. Push OK and go in circles. Maybe the paper sensor is missing?
May 15, 2010 | HP Officejet Pro L7680 All-In-One Printer
Hp photosmart D7560 printer i'm haveing a problem with loading paper in very bottom load tray.the printer sceen says to load paper into tray or there is no paper in the tray. i"am using 8 1/2 x 11 inch...
Make sure the paper tray sensor flag has not been dislodged. Look up inside the tray area and also if the back door area opens up, check in there. The flag should move freely>
Dec 30, 2009 | HP Photosmart D7560 InkJet Printer
How topaper load cannon mp 160 pixma
Loading Paper into your Canon MP 160 Pixma.
A) Loading Paper :
Follow this procedure:
1) Open the Paper Support, then pull out the Paper Support Extension.
2) Place a stack of paper (print side up) in the Auto Sheet Feeder, pinch the Paper Guide and adjust it to the left side of the stack.
* Set the Paper ThicknessLever to the correct position for the paper.
Note : Set the Lever to the left for most paper. When the Lever is set to the right, the confirmation message appears before the machine starts printing.
Important : Make sure the stack does not exceed the Load Limit Mark.
B) Loading Envelopes
Follow the following steps:
2) Prepare the envelopes for loading.
Important : * Press down firmly on the edges of the envelopes to make the folds crisp. Also, press firmly on the area that corresponds to the edges of the back flap.
* Remove any curling by holding the edges diagonally and bending them gently.
* If the edges of the envelopes are inflated or curled, place the envelope on a flat surface. With a pen, press down while moving it from the center toward the edges of the envelope.
* Ensure that no curl or puff exceeds 1/8 in. (3mm).
3) Place the stack of envelopes (print side up) in the Auto Sheet Feeder, pinch the Paper Guide and adjust it to the left side of the stack.
* Load the envelopes in the Auto Sheet Feeder with the short side down.
* Set the Paper Thickness Lever to the right.
Important : Make sure that the stack does not exceed the Load Limit Mark.
Hope this helps. PLease rate my response.
Thanks
Have a good day.
Dec 01, 2009 | Canon PIXMA MP160 All-In-One InkJet...
How do I realign my hp photosmart c4480 printer?
To align the print cartridges from the HP Photosmart Software
1. Load letter or A4 unused plain white paper into the input tray.
NOTE: If you have colored paper loaded in the input tray when you align the print
cartridges, the alignment will fail. Load unused plain white paper into the input
tray, and then try the alignment again.
2. In the HP Solution Center, click Settings.
3. In the Print Settings area, click Printer Toolbox.
NOTE: You can also open the Printer Toolbox from the Print Properties dialog
box. In the Print Properties dialog box, click the Features tab, and then click
Printer Services.
box. In the Print Properties dialog box, click the Features tab, and then click the
Printer Services button.
The Printer Toolbox appears.
4. Click the Device Services tab.
5. Click Align the Print Cartridges.
When prompted, ensure plain white letter or A4 paper is loaded in the input tray, then
press the button next to OK.
The product prints a print cartridge alignment sheet.
7. Load the page print side down on the right front corner of the glass, and then press
the button next to OK to scan the page.
When the On button stops flashing, the alignment is complete and the page can be
removed. Recycle or discard the page.
Jul 18, 2009 | HP PhotoSmart C4480 All-in-One Printer ...
Will not recognize loaded paper, keeps saying no
There 's a torn piece of paper blocking the paper level sensor. Re check all areas where the paper feeds. the try re insert the paper, if its clear . turn printer off for 5 mins then turn on and try again
Jul 08, 2009 | Canon PIXMA iP1800 InkJet Photo Printer
Loading paper
Cut paper at an angle and insert and push into back slot with tip of angle (apex) to the right of machine when facing it. It should engage number wheel when you hit addition sign, You may need tweezers to pull it thru if it doesn't advance.
Jun 20, 2008 | Canon P23-DHV Calculator
Paper won't load
first this to do is turn it off unplug, take paper tray out and remove paper and clean the tray, take the printer and put it on it's side (the side where the paper tray goes and see if you get any paper dust to come out. other wise blow air into that area you will see a roller on top need to clean that.
Feb 08, 2008 | HP Photosmart C6180 All-In-One InkJet...
Sharp EL-1197PIII Calculator Logo
62 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
jasbo
jasbo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
