How can I fix my laptop
I have a broad com problem thats keeps coming up I tried to shut it of in the boot up list it says pci lan: MBA v11.0.11 slot 0700 thats what it says in the boot prioity list trying to install windows on it but thats all i keep getting :(
  • 4 more comments
  • George McDonald Feb 11, 2012
    also says pxe- e61: medai test failure, check cable, what caable would that be.
    pxe m0f exiting broadcom pxe: rom
    thats
    I am trying to install windows but that same broadcom comes and it is not leting me install because thats all it is doing. **** IT :o
    the broadcom thing is in the boot list and how do I turn it of
  • George McDonald Feb 12, 2012
    Is there a way to bios flash vista using dos and floppy diskI still can't get in and I have to flash the bios in dos because I still cant get on just the broadcom things thats it
    I had a 32 bit instaed of a 64bit duh!!
    I got to make sure of the network drivers / network controller driver and the wireless drivers for the lenovo g550 2958 so if ya know let me know please and thanks
  • 56 Answers
  • You are right, your computer cannot find a harddisk to boot from as your device option to boot is from the dvd drive or from lan (network). Your harddisk might have failed, the cable has come loose or infected with a virus.
    BIOS is basic input output system, the program a PC's microprocessor uses to get the computer system started after you turn it on. When bios is shadowed, It means this program is copied from ROM to RAM during bootup for faster access. Source(s): http://wickedwebdesign.com.au
Posted on Feb 11, 2012
3 Suggested Answers
biglala
  • 50 Answers
SOURCE: what mean of Network:MBA v 9.1.1 slot 0200?
Here is some great source to solve any kinds of laptop's problem.
» Hp Laptop's Solution
» Compaq Laptop's Solution
» Acer Laptop's Solution
» Dell Laptop's Solution
» Toshiba Laptop's Solution
» Asus Laptop's Solution
Here is some another Great source to download any kinds of laptop Drivers.
» Hp Driver's Download
» Compaq Driver's Download
» Acer Driver's Download
» Dell Driver's Download
» Toshiba Driver's Download
» Asus Driver's Download
>24
Posted on Dec 25, 2008
the_fire
  • 432 Answers
SOURCE: pci card drivers
you would need to get all the drivers for your laptop from the IBM website and install all of them. If you cant find them or need further help please post back and let me know.
Posted on Apr 10, 2009
Now this is what i see on my gateway in the utility setup menu under the option boot it sais or gives option network boot mba v12.2.2 slot 0300 wondering if this will help me or if i should push this ??
Hi Tammy,
I have never liked boot/startup menus for windows. I use to use them in DOS modes way back in the day but windows today, my opinion, does not need one. The only time would be if the computer is host to two different OS's.
My opinion is to not use it at all. I have my HP laptop's connected to my network by using the router and windows hooking it up.
Did the gateway come with the MBA installed?
Is there any option that allows you to disable the MBA menu?
[do not disable it until you have fully looked into the situation that doing that will not stop you from accessing your computer]
HTH, post back with what you find out.
Wayne
Nov 02, 2013 | Gateway Computers & Internet
M3N78-VM LAN PORT& PCI PROBLEM
1) How do you know that PCI slot is not working? Tried another PCI expansion card in it? Perhaps another LAN adapter card?
(Ethernet Card)
A LAN adapter card will go bad before a PCI slot will.
2) PCI expansion slot is bad? No other PCI slot to use?
Then here is a suggestion,
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=3504463&csid=_61
Plug it into any available USB port on the computer.
It is a GigaByte Ethernet solution, also. (10/100/1000)
Regards,
joecoolvette
Aug 08, 2012 | ASUS Computers & Internet
HOW TO INSTALL DYNEX DESKTOP 10/100 MBPS PCI NETWORK CARD
Remove the case cover from your desktop computer.
Remove a cover strip from a PCI expansion slot.
Insert the Dynex network card into this PCI slot and secure it with a screw.
Replace the cover on the desktop computer.
Boot up the computer and when Windows has booted up then insert the Dynex installation CD into the CD drive then install the LAN driver.
Connect a LAN cable from the Dynex LAN card to your modem or router etc.
Mar 11, 2012 | Computers & Internet
In built lan in pci bus is not working. Which lan card i can insert in pci slot?
Any brand that is made to fit in in a PCI slot. Try Best buy or Tigerdirect.com. Also, go into your bios settings when computer 1st starts and shut off the built in lan on your motherboard (see computer manual or online support for your brand)
May 06, 2010 | Asrock 775i65GV Motherboard
LAN is not recognizing Internet port
Then you have reinstall *********** boards drivers from its cd.
Oct 25, 2009 | Intel DG31PR Motherboard
Pci slot error
I have the same problem with an Aspire 5100.
I can eliminate any problems with the software, as the problem exist with the hard drive renoved.
It appears after the 'Acer' splash screen and fails as part of the POST.
After reading through various posts I suspect the broadcom wirless card or LAN has failed at board level.
I will try removing them and try again.
Will post back with results.
Jun 10, 2009 | Acer Aspire 5100 Notebook
Booting problems with acer laptop - no operating system found??
PXE (pronounce Pixie) is an agent used to boot on to the network.
It's using the DHCP protocol to localise a server where the image of the OS is located
If, for any reason, the hard drive is not seen the computer will attempt to boot on the network controller.
This can be caused if the hard drive is missing, unplugged or corrupt, or simply by not having the boot order configured correctly.
When you start your laptops, press F2 repeatedly until you enter the bios set up, navigate to the boot order and make sure that the hard drive (sometimes listed as HDD....) at the top of the list.
Hope this helps, let me know if you need anymore help.
Jan 27, 2009 | HP Pavilion dv6000z Notebook
I disabled the lan and when i enabled it again it won't work
Hi, well now you have windows registry confused. The PCI card may have come with software & you installed it. (See if its listed in add/remove programs & uninstall it), than go to this link & download the free software to clean your registry. (Keep the onboard lan disabled in the bios).
http://www.pctuneuptips.com/recommends/clean/?gclid=CL2RiIrTmpICFSFMGgodODIPzg
When the program finishes close the program & shut down the system. Than boot the system & enter the bios. Enable the onboard lan. Save & exit. With any luck windows will see your lan & ask for the software. You can use the CD to guide windows to the lad driver software or you can download it from ECS. The online lan may be a bit newer or may not be. Click here to go to ECS web site:
http://www.ecs.com.tw/ECSWebSite/Downloads/ProductsDetail_Download.aspx?detailid=474&DetailName=New&DetailDesc=915G-M%20%20(V1.0)&CategoryID=1&MenuID=82&LanID=0
If you are running XP install through windows device manager.
Run into trouble, just let me know what the trouble is & we'll go from there.
Mike
Sep 28, 2008 | EliteGroup 915G-M Motherboard
IBM Netvista PCI/PNP Slot 3 Error
I had to remove the old network card and replace it with a new one to resolve the issue.
Jun 18, 2008 | IBM NetVista A40 PC Desktop
Built in wireless internet card not found
a number of possible fixes come to mind. First access hardware list in control panel under system, then click on device manager, then device manager, then look down the list to network adaptors. Opening list should indicate network (wireless card). If not refresh list. If no luck, or unknown card shows up, hit update driver. If no listing at all, try shutting machine down, removing card from under cover from base of machine, restarting machine without it. After waiting for machine to settle, shut down again, re-instate card and restart. The card should be seen and seek driver under windows new device setup screen. If still no good, card or slot (PCI) or both could be crook. PCI slot failure will mean a new mother board, unless you alternate to a PCMCIA card (wireless) or the same in a USB device. All else fails take it to a tech, or more to the point, if under warranty from HP (or extended) as its a relatively new machine, DONT TOUCH and ring HP or take to a service centre.
Feb 21, 2007 | HP Compaq Presario V2000 Notebook
Computers & Internet Logo
151 people viewed this question
David Payne
David Payne
