Question about Sharper Image (CT411) Consumer Headphones
AA001-RX not connecting
Computer says that it found device, added drivers, and now can not get a connection. Is there a certain step i'm missing in synchronizing headset?
Xbox360 can't connect to wireless ad hoc wifi network
You will have to open up your network connections Click start control panel network connections this may vary depending on your operating system look for local area connection if you see a red x or a yellow exclamation or question mark ! ? you will need to update or install the driver or it could be firewalled, If you are trying to connect through a modem/router you it should have come with a disk then you might have to connect the usb lead to your modem to get a connection then Click start control panel administration tools computer management device manager scroll to network adapters should see a yellow question ? exclamation mark ! or a red X right click install drivers. The driver might be on the disc supplied by your ISP internet service provider or the motherboard disc Click start type cmd press enter you will be in DOS mode type in ipconfig press enter you will see all o fyour internet connection details type in your default gateway adress into your internet search should read something like 10.0.0.138 Make sure you Ethernet/internet is enabled in bios restart your computer during the boot up process you will see on your screen a certain key to press to enter set up (BIOS) press and hold that key to enter bios using arrow keys navigate to integrated peripherals look for SiS On Chip Pci Device press enter scroll to SiS 10/100m press enter make sure its "Enabled"imake sure its enabledPci device arrows key scroll to nstalled. Hope this helps.
Dec 10, 2012 | Computers & Internet
Sir i havnt got any CD with my GT E2652 champ model. i wanna connect internet mobile with laptop. bt my downloaded pc suite is responsing. it doesnt show any mobile connect to it. i m using pc studio...
For connecting your cellphone with the Laptop or PC you need driver with PC suite.
But as you specify that you don't have the driver CD then you may download the driver from the internet by following the simple steps:
But for this you need Internet Connection:
* Install the PC Suite and connect your cellphone with your PC or Laptop using data cable or Bluetooth.
* Now on your PC desktop right click on My computer icon and Select Properties and then Device Manager (You can also access Device Manager from Control Panel).
* Now in the Device manager you found some YELLOW Exclamatory icons search for your mobile device name and right click on it and then select UPDATE DRIVER SOFTWARE...
It will automatically download the driver now just restart the PC and again connect the Cellphone with the pc it will work now.
Note: Please Post your Review that this solution work for you or not so that I can provide more solution if this one won't work for you.
Sep 10, 2011 | Samsung Modem Configuration Software...
Brother MFC-7840w wireless printer won't connect to network. I have searched a ton of solutions on the web and have had no luck. I have several devices connected to my wireless network, but just...
Improve the Fixya.com experience for everyone by voting!
The solution I'm suggesting works in my business (LAN installations) about 95% of the time. I trust that it will work for you.
Let's see if I can help you.
Begin by turning on your computer and your router
Make certain that you have the latest drivers from Brother by clicking on the following link: Brother Driver Downloads
Open Control Panel and click on 'Diagnose Connection Problems' and follow the instructions.
The last choice is to use the Setup Wizard. It seldom works for me but you might more luck than poor me. Here are the instructions:
The Connect to the Internet wizard will guide you through the steps of setting up an Internet connection.
Open the Connect to the Internet wizard by:
• Clicking the Start button Picture of the Start button
• Click on Control Panel.
• In the search box, type network,
• Click "Network and Sharing Center"
• Click Set up a new connection or network
• Then double-click "Connect to the Internet".
This should have you up and running.
All the best
Ben
Jun 18, 2011 | Brother MFC 7840W Printer
I have a Dell Inspiron Laptop. I recently reformatted it. Now It does not recognize wireless connections. I cant connect to the net Can anyone help?
When you reinstalled Windows, Windows probably did not include a driver for your wireless adapter. A driver tells Windows how to interface with a certain device, such as a wireless adapter. You can easily download the driver online and install it. Once installed, restart the computer and you should again have the ability to connect to wireless networks.
I've gone to the Dell website for you and found the correct driver. Please visit this link: http://support.dell.com/support/downloads/driverslist.aspx?os=WLH&catid=5&dateid=-1&impid=-1&osl=EN&typeid=-1&formatid=-1&servicetag=&SystemID=INS_PNT_PM_1525&hidos=WLH&hidlang=en&TabIndex=&scanSupported=False&scanConsent=False
On that website, I would first try downloading the first driver on the list. If that doesn't enable your wireless after a reboot, try the other ones. After the correct driver is installed, your wireless will be working again.
Jun 01, 2011 | Dell Inspiron 1525 Notebook
Disk drive won't work cannot install driver
IF YOU HAVE NO INSTALL DRIVER GO TO MY COMPUTER, MANAGE, DEVICE MANAGER, UPDATE DRIVER SELECT DRIVER PATH AD INSTALL IT
IF YOU HAVE NO DRIVER, GO TO MY COMPUTER, MANAGE, DEVICE MANAGER, PROPERTY ON DEVICE WHOSE DRIVER ARE NOT FOUND, COPY DEVICE ID CODE ON DRIVER DETAILS OPEN http://devid.info SITE AND DOWNLOAD SUITABLE DRIVER AND INSTALL TO USE ABOVE STEPS
May 18, 2011 | Computers & Internet
My Onyx 1620 will not connect to my PC. It did connect previously to this very computer. I have tried it on 2 PC's, neither worked. I have tried a different cable. I have taken out, cleaned, and...
I am assuming a Windows operating system for this solution.
This sounds like it could be a driver problem (not with the FireWire port, but for the sound card itself).
When you connect the card with the FireWire cable, do you hear a sound from your computer registering the new hardware (assuming this isn't your primary sound card)? Head to the Device Manager (go to Start/Run and enter devmgmt.msc) after plugging in the card and look for any "Unknown Device"s with Yellow "!" triangles next to them (or anything else with a "!" or "?" for that matter). If you find one, try reinstalling the drivers for the corresponding device.
Even if the problem you find seems unrelated, take steps to resolve it anyway. Computers, being as twisted as they are, tend to mess up all kinds of things when certain drivers are out of place.
Also, even if you can't find any problems in the Device Manager, try reinstalling the drivers anyway, and be sure to visit your product manufacturer's website for updated drivers.
May 04, 2011 | Bob Mackie Onyx FireWire Sound Card
Cdrom is unfunctional i cant install the printer, what can i do?
connect to the internet and go to the following page: http://www.epson.com/cgi-bin/Store/support/supDetail.jsp?oid=41661&prodoid=46048263&BV_UseBVCookie=yes&infoType=Downloads&platform=Windows32&x=24&y=9
This is the driver for the Epson Stylus Printer.
So after downloading this driver.
Step 1 Turn on computer. Step 2 Connect Printer to computer Step 3 Walk throught the Windows found hardware menu Step 4 When asked about driver point to the newly downloaded driver.
Viola your printer is setup.
Please don't forget to rate this answer.
Apr 11, 2011 | Epson Stylus C86 InkJet Printer
Yamaha Receiver RX-V367. Connected a WII to the audio/video jacks in front. Sound but no audio Do I need to select a certain device from input menu?
I am trying to connect my Wii with the component cables to my yamaha rx-v367. No video but sound. What am I doing wrong?
Jun 19, 2010 | Audio Players & Recorders
Bluetooth not working in lenovo y410
please check your bluetooth driver in your system.
Jan 11, 2010 | Lenovo 3000 Y410 Laptop
Windows 7 is not recognizing me Epson RX595
The following steps may help:
  1. Remove all the drivers and software installed for this printer.
  2. Restart your computer.
  3. Click here to go to the driver download page. Download the driver for Win 7 and install.
  4. Connect the printer to your PC, the installation will continue.
  5. After installation, you should be able to use your printer.
Nov 03, 2009 | Epson RX595 Photo All-In-One Printer
Sharper Image (CT411) Consumer Headphones Logo
208 people viewed this question
Top Sharper Image Audio Players & Recorders Experts
Tom Chichester
woodzowl307
Are you a Sharper Image Audio Player and Recorder Expert? Answer questions, earn points and help others
