Question about Exercise & Fitness
E4400 trips circuit breaker
When I turn the switch on in the back of the tread mill it trips off right away.
    Top Expert:
  • 12,223 Answers
Dear Sir:
You have a Short-circuite in your treadmill.
You must use your VOM, for test.
1) See your outlet in the wall if some wires is touching, repair.
2) Test the power cord , and see if some cables are touching.
3) See inside from your equipment, if some wires are touching the carcase.
4) The main motor board or transformer, or power supply + or main motor are Faulty. See the block diagram
e4400 trips circuit breaker - 2_17_2012_11_55_32_am.gifsincerely GOD BLESS YOU.
ernesto cuadra
managua, nicaragua. c.a
Posted on Feb 17, 2012
5 Suggested Answers
  • 6 Answers
SOURCE: Tread Mill Skips Jerks Every So Often
Your treadmill is trying to tell you its due for a tune-up!
Posted on Mar 17, 2009
  • 1126 Answers
SOURCE: NO I WOULD LIKE A OPERATOR'S MANUAL FOR A
Here is a link to ProForm for 293250 manual download.
http://www.iconservice.com/cgi-bin/ncommerce3/ExecMacro/proform/manuals.d2w/report?name=293250&match=exact&lan=
Just right click on the file and select 'save as'. You will need Adobe Reader to view once downloaded, and it's at no charge.
Posted on Nov 08, 2009
maxtreadmill
  • 832 Answers
SOURCE: my tread mill looses speed during my workout. the
If you haven't adjusted the belt refer to your owners manual for the proper procedure if you still have the same results then it could be caused by a lack of lubrication under belt or a worn belt.
Posted on Apr 11, 2010
maxtreadmill
  • 832 Answers
SOURCE: will not power on
The lower board has a serious short and what possible happen is that the treadmill breaker fried and open up will properly need replacing also.
Posted on May 06, 2010
Why does the breaker keep tripping on this 2.0hp exhaust fan motor
Christopher, motors starter/capacitor could be faulty, wire circuit/breaker could be insufficient. motor could be faulty or wired incorrectly. Have motor checked out and ensure you are wiring correctly.
Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
LEESON Electric Motor Trouble Shooting Chart
Motor trips breaker Why
http://www.garagejournal.com/forum/showthread.php?t=256105
Jun 03, 2016 | Heating & Cooling
How to reset a cutler hammer HMCP E Breaker
Well, you should first - stand off to the side (not in front of any electrical panel, or device) when re-energizing a circuit breaker/switch, etc... Use your off hand, not your dominant hand when doing this. Reason is, if the breaker/switch blows up or out - and it happens to burn your hand (hopefully not...) - you will still have your good hand to work and get around with. Also, look away when doing this too - which will protect your eyes and face. This is why you DON'T stand in front of these electrical devices when turning them ON. Now, stand off to the side of this breaker/switch - look away, and using your less dominant hand - first turn the breaker/switch OFF (listen and feel for it to click in the OFF position)...then, turn the breaker/switch back ON. This should re-energize the breaker! If it trips again, then leave it in the TRIP position - and ask for further help. You'll need an experienced electrician to troubleshoot the problem. On this particular breaker - the two 40amp breakers are together, and the two 30amp breakers on the outside are together. When turning these OFF, and back ON...turn the two 40amp breakers OFF together, then back ON - and do the same to the two outside 30amp breakers as well. What you have here is what they call a Quad Breaker (4poles/circuits - which take up two spots in your electrical panel). So, you have a 2 pole/circuit...240 volt/40amp breaker - inside of a; 2 pole/circuit...240 volt/30amp breaker. This is most likely running a dryer and a range. Either way, SAFETY FIRST! I hope your problem is just a tripped circuit breaker! Also, make sure whatever you are trying to re-energize again - is ALL OFF!!! If your breaker trips again, disconnect ALL appliances involved - and then try it one more time! If it trips again, then call a licensed/certified electrician! Best of Luck to You...:)
Jul 13, 2014 | Cutler Hammer Bq Circuit Breaker Bq230240...
New Treadmill blows ciruit breaker when turned on.
have the new tread mill checked under warranty as it should not blow breakers from new
Feb 13, 2018 | Weslo Exercise & Fitness
PRECOR C956 power switch wont stay on
The power switch on Precor treads is also a circuit breaker. If it trips when plugged in, you have a dead short in the machine.
Feb 06, 2014 | Precor Exercise & Fitness
I just put my tread mill together Nordic Track A2550 and the belt wont move
1) test your circuit breaker home,reset
2)test the outlet for 115 vac
3)test the power cord if some wires is loose or cutting
4)reset your circuit breaker insider from your equipment
5)Eliminate any extension cord from your treadmill.
6)Be shure if the receptacle have ground cable with your divided TRSS.
sincerely.
ERNESTO CUADRA
MANAGUA,NICARAGUA. C.A.
Dec 11, 2011 | Nordic Track NordicTrack A2550 PRO...
Tread mill wont turn on. it was on then while in use the screen flashed on and off then treadmill shut down and has not turned back on. tried reset button then unpluging for a while but still does not turn...
Dear Sir:
Thank you by your problem, I will help you inmediately.
Make sure that the power cord is plugged into a surge suppressor, and that the surge suppressor
is plugged into a properly grounded outlet . Use only a single-outlet surge suppressor
that is UL 1449 listed as a transient voltage surge suppressor (TVSS). The surge suppressor
must have a UL suppressed voltage rating of 400 volts or less and a minimum surge dissipation
of 450 joules. The surge suppressor must be electrically rated for 120 volts AC and 15 amps.
Important: The treadmill is not compatible with GFCI-equipped outlets.
2)After the power cord has been plugged in, make sure that the key is fully inserted into the console.
3)Check the circuit breaker located on the treadmill
near the power cord. If the switch protrudes as
shown, the circuit breaker has tripped. To reset the
circuit breaker, wait for five minutes and then press
the switch back in.
4)Check the on/off switch located on the treadmill
near the power cord. The switch must be in the on
position.
I hope you resolve this. Otherwise, try to reach me. Inmediately.
sincerely.
E.Cuadra
Sep 13, 2011 | Nordic Track NordicTrack Elite zi...
I have a Bosch b52l iron, when i turn on the steam button, it cuts off the power, what could it be
It could be the iron itself (it may have a short circuit in it) and the circuit breaker trips when the steam switch is turned on.
Option 1)
Another option is that the entire circuit that that circuit breaker is controlling is overloaded. What other outlets / applicances / lights are disabled when that circuit breaker trips? You may have to iron only when those other applicances on that circuit are not being used.
Option 2a) Your outlet may be damaged and causing your circuit breaker to trip when the high current STEAM setting is set.
- OR -
Option 2b) the circuit breaker is damaged and is tripping too easily. Only replace with a similarly sized circuit breaker (15 amp lis likely but is says right on the breaker).
Try the solutions in that order.
-Mark
Please rate me..
May 07, 2011 | Bosch Irons
I have a ruud achiever uaka outdoor central air system, the first time i ran it this summer it tripped the breaker. It stayed on for a good hour as it cooled the house to the desired temp. then it turned...
start components are likely bad causing comp to pull high amps tripping breaker careful resetting the breaker they can explode stand off to the side
you need service all so have preventive maintenance done on the unit
Jun 19, 2009 | Ruud UAKA037 Air Conditioner
Exercise & Fitness Logo
51 people viewed this question
Top Exercise & Fitness Experts
Howard
Howard
Sportsmith LLC
Sportsmith LLC
Tom Chichester
Are you an Exercise and Fitnes Expert? Answer questions, earn points and help others
