Ntvdm.exe keeps running a cmd promt on my dest top and wont let the desk top come up and run normal
  • 108 Answers
Boot to safe-mode - goto start then run and type msconfig -
Within Msconfig you should see a startup tab. Look in there and remove or uncheck all that appear to be using ntvdm.exe
Also check in start, programs, startup, remove anything there as well.
Let me know if that does not help.
G'luck
Posted on Oct 24, 2008
How do i unlock my dell computer home screen with out a disk
1. windows DVD installer
2. Boot from DVD and choice repair
3. Choice command promt menu
4. Type it: copy c:\windows\system32\sethc.exe[space]c:\ and hit enter
5. Type it: copy c:\windows\system32\cmd.exe[spasi]c:\windows\system32\sethac.exe and hit enter. Type exit and hit enter
6. Press CTRL+ALT+DEL to reboot from hard disk
7. On windows home screen, press Shift keys 5 times. It will activate command promt.
8. Type it: net user [your account] [your new password] and hit enter. Type exit and hit enter.
9. Now you can log in to your windows using your new password.
10. Don't forget to replacing back the sethc.exe or just leave it.
Sep 19, 2014 | Dell Latitude E6530
My laptop is 2 years old. The recycle bin icon is still on my desk top but it is not working. Can you help?
  • Click the start button.
  • Type CMD then right click on cmd.exe and select run as administrator
  • type rd /S /Q C:\$Recycle.bin and press enter
Sep 22, 2011 | Dell Inspiron 1525 1526 24x CDRW/DVD Combo...
Black window keeps popping up on my computer. It's quick and I cannot read it. It happens every 15 to 20 seconds. Any suggestions? It is a dell inspiron lap top. It has been going on for about a week
  • Start -> Run -> cmd.exe
  • Then type the following "net stop messenger" after which you'll see "messenger service is stopping".
To start it again for any reason open the command prompt again (Start -> Run -> cmd.exe) and type "net start messenger"
Now you can be assured that your world will become silent. No more pop-up black screens.
Jun 22, 2010 | Dell Inspiron 1525 Notebook
NTVDM CPU fix
Hello there:
Something is amiss with your system.
That error message is associated with problems involving 16 bit
applications (Windows 3.x or MS-DOS) and both cmd.exe and regedit.exe
are full 32 bit Windows apps.
This sounds like it may be caused by an incomplete removal of one of
the trojans that blocks the use of Regedit.
You did not mention the specific products that you have tried. If you
have not previously used any of these you should try them:
Kaspersky Online Scanner http://www.kaspersky.com/virusscanner
Panda ActiveScan http://www.pandasoftware.com/activescan
Webroot http://www.webroot.com/
I highly recommend avg antivirus free version this is totally free and worked wonders for me
I hope that this is very helpful for you
best regards michael
Nov 16, 2009 | Dell Dimension 3100 PC Desktop
When i plug in the entranet in the laptop...its is not reading it it ssaying unidentifed network...but wen i plug it in the desk top it is working fine..I check the setting and everything n its working...
There are a few ways to handle this you can go to start accessories command promt or start run and type cmd , at the command promt type ipconfig /all just like i typed it press enter and you should see the address there it chould be somthing like 192.168.2.1and so on it will tell you your card type and where youare connected too . if you see169.000.0.0 this is and example you are not connected .make sure that your cable is connected or your wifi card is settup .if this is ethernet make sure you have autherization to access with you laptop ethernet is used for companys and the admin can set up your connection if that is the problem .if you are talking about internet the solution above should solve your problem.let me know what happens
Mar 30, 2009 | Toshiba Satellite Pro L300 Notebook
Cmd is not working
CMD Might not working because of any of the following reasons.
1. cmd.exe not available in Windows\System32 folder
2. cmd.exe might be hidden in Windows\System32
3. current user might not be having permissions to execute cmd.exe
Solution:
1. search cmd.exe from local disk or installation disk and copy to windows\system32 folder
2. Right click cmd.exe and remove system and hidden attribute
3. Change the permission for cmd.exe to read and execute
Hope it will work, if not please call me 9899780221
Thanks
Zulfikar Ali
Jan 27, 2009 | Computers & Internet
The ntvdm cpu has encountered an illegal instruction
I took this from another web site:
Michael Chiew said:
What did you do before this happened? What were your last deeds on the machine before the pop-up appeared?
I think what you're referring to is NTVDM CPU, not NTDVM CPU. Am I correct?
What do you know about 16-bit and 32-bit applications? Well, 16-bit applications are those that must work within the DOS (Disk Operating System) environment, a real-mode arena. NTVDM stands for NT Virtual Dos Machine.
In Windows XP, as in Windows 2000, or Windows 98, there are 16-bit and 32-bit environments (real mode and protected mode respectively).
Windows XP can only operate in 32-bit mode. All 16-bit applications must work within its own theatre of operation, typically, the first MB of physical memory (ram). Conversely, 32-bit applications must function above the first MB memory line. If either of these applications happens to slip into "alien" territory, you get an error message like "something" has encounter an illegal instruction. In other words, the wayward application is trying to slip by the immigration checkpoint.
In your case, updatemgr.exe (I suspect updatemgr.exe is a 32-bit application) has in all likelihood wondered into the 16-bit arena. Hence, NTVDM CPU issues that warning.
Why do you continue to get the message. It's because updatemgr.exe incessantly misbehaves itself on start-up, always trying to load itself into a particular memory address where it is not welcome. Why the persistence? Updatemgr.exe has gone bonkers. It is either corrupted or damaged.
On the other hand, one cannot discount the possibility that NTVDM (NTVDM.EXE) is corrupted or damaged. So your problem lies with either updatemgr.exe or NTVDM.EXE, or both.
There are 2 things you could do.
First, establish who owns updatemgr.exe, Microsoft or some third-party owner. Second, rename updatemgr.exe and see whether the message goes away.
To establish ownership (and the function of updatemgr.exe), do a search for the file.
Click START, select FIND. In the FIND dialog box, type: updatemgr.exe. See the directory in which the file has lodged. In Windows Explorer, get to the file, right-click on it, select PROPERTIES. Who owns it? Is there an indication of its function.
Next, rename the file. Right-click it, select RENAME and rename it to, say, updatemgr.old. RESTART your computer. Do you still get the error message. Not likely.
To clean things up a bit, perhaps it is a good idea for you to replace the current NTVDM.EXE with a new copy. Find out where NTVDM.EXE is. Then, click START, select RUN. Type in the RUN dialog box SFC to run the System File Checker. Insert your OS CD, follow the prompts, extract a copy of NTVDM.EXE and send it to its place of residence. Of course, you should also replace a copy of updatemgr.exe.
That should eliminate your problem for good.
Dec 25, 2008 | Microsoft Windows XP Home Edition
Can't install super soho pack keep getting NTVDM:exe a problem has caused the software from running. (this comes up right when you click the startup exe file to install)
http://www.file.net/process/ntvdm.exe.html GO HERE YOUR PROBLEM AND SOLUTION ARE EXPLAINED.DO NOT FORGET TO RETURN HERE AND VOTE FOR THIS IF IT HELPS SOLVE YOUR PROBLEM.TY RICHARDM69
Dec 01, 2008 | Computers & Internet
VISTA:The NTVDM CPU has encountered an illegal instruction
The link below is a step-by-step troubleshooter from the Microsoft website. You'll just need to follow all the instructions on the site and you should be able to fix it all by yourself. This seems to be a common error with windows.
Troubleshooting NTVDM and WOW Startup Errors
Sep 10, 2008 | Computers & Internet
ACAD 12 Problem
this is normally an issue with the licensing utility that runs in the background for ACAD. try troubleshooting that.
Dec 28, 2007 | Computers & Internet
Computers & Internet Logo
123 people viewed this question
David Payne
David Payne
