Question about Brother MFC-3360C All-In-One InkJet Printer
Brother MFC-3360C print head cleaning - Brother MFC-3360C All-In-One InkJet Printer
cene765
  • 787 Answers
SOURCE: unable to clean print heads
Unplug the printer from power cord.Press and hold the "menu" button, then plug the device.You'll see on the LCD screen a "machine error" code.If this code is 40,41,49 or 4F the print head is defective.If the error is 48 - defective print head cable or circuit board.If the error is 50 or 51 there is error in Purge unit and printer require service.If the error is 46 the waste ink tank is full.Follow this:
Enter 80, then scroll down with the arrow down (round) key. You'll find an entry listed as purge count. If number is over 6000, enter 2 7 8 3.This will reset the purge count value. Then restart the printer, hopefully without the annoying cannot clean message.
Posted on Nov 24, 2009
SOURCE: brother mfc-215c unable to clean?
What is machine error 26?
Posted on Dec 13, 2007
SOURCE: Brother MFC-620CN print head clogged
Open up amd release blue stay at bottom by pressing edges inward and pulling slightly forward. Remove the 4 screws, 2 small plastic covers and the earth screw. Pull out the ribbon connector near the USB plug. Unplug the 2 white and one red connectors, noting how the cables fit in. Fully open the lid and pop the scanner part off. Remove all the ink cartridges. Now using a flat screwdriver unclip the top of the base all the way round and lift off. The print head is now accessible. Rotate the white paper feed cogs to release the print head. Slide it all the way to the right and remove it by tilting the back edge upwards. You mow have access to the print head!!!!
Posted on Jun 02, 2009
pineworks
  • 4041 Answers
SOURCE: Brother MFC-3360C error message ''PRINT UNABLE 4F .....''
Hi there
Brother 4F is this have a go it could work for you.
Access the internal maintenance mode by pressing the Menu/Set button, then press * 2 8 6 4 within 2 seconds. This should put you in the maintenance mode menu. Enter 80, then scroll down with the arrow down (round) key. You'll find an entry listed as purge count. If number is over 6000, enter 2 7 8 3.
This will reset the purge count value. Then the printer will restart, hopefully without the annoying cannot clean message.
All I ask is please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
All files on my website are only there for a limited time
Posted on Apr 25, 2010
jay767
  • 386 Answers
SOURCE: brother MFC 465CN won't print due to "Unable to
Hi Good day!! try this method
1.pull out the AC plug
2.put back the AC plug while holding down the "menu" button and keep holding it (15 sec)
3.now you are entering the MAINTENANCE mode and "error 46" pops up in the display
4.select 8 by using the arrow buttons ,push OK and select 0 and push OK
5.00:00 00:01 OK (the display is showing this message)
6.now push the MONO button 25 times until you see PURGE: xxxxx
7.Select 2, push ok, select 7,push ok,select 8,push ok, select 3,push ok
8.the purge counter indicates now: purge: 00000
9.switch off the printer ,switch it on
ready to print
Posted on Nov 20, 2010
I have a Brother MFC-3360C printer and have an error. Clean Unable 51
Error 51 normally indicates a paper jam or a sensor problem. Check the paper path and the printer head movement zones (far left and right) for any foreign objects (even small pieces of paper). If there has been a paper jam, was the paper forcibly removed? If so, possibly one of the sensors has been knocked out of position or damaged. Dust, dirt, grease or spilled ink may also be contaminating a sensor. This is maybe one of the most elusive problems to solve..!
Apr 10, 2015 | Brother MFC-3360C All-In-One InkJet...
Majenta is not printing, all cartridges changed and cleaned still no majenta
Blocked print head nozzles
You may have blocked print head nozzles.
Try the printer maintenance to clear the printer nozzles.
After several deep cleaning attempts and there is no improvements in the print then a new print head is required.
A new print head maybe expensive and it maybe more cost effective to purchase a new printer.
Aug 21, 2012 | Brother MFC-3360C InkJet Printer
Fax will not print: I connected the fax machine and plugged it in. It sends faxes OK. When a fax is sent to it, nothing comes out. The sending fax doesn't receive an error message, seems like all went...
Does the machine print anything? such as a directory or print when making a copy? I rather suspect it does not. When an incoming fax is recvd does the paper get pulled in and come out blank? If so your problem is with printing (or lack of it). Perform head cleaning. Also make sure the black cartridge still does not have its deal stuck on it. Post again if you still have problem.
May 05, 2011 | Brother Multi-Function Center MFC-3360c...
Cleaned printer head 12 times still can't get full black test . And still getting horizontal lines when printing .
Sound familiar. Sometimes you just have to let it sit for a day or two once you have cleaned it a few times. Then clean again and see if its cleared up. Could also be getting empty even if it doesn't show it is. In the worst cases some of the print heads are majorly clogged. There are also cleaning kits you can get off the web. It's like an ink cartridge but it has cleaning fluid in it instead.
Jul 02, 2010 | Brother Multi-Function Center MFC-3360c...
Printed page do not match screen colors on a MFC-3360c brother all-in-one printer
Clean print head it may work properly. else
find out which color not working. replace the color ink cartridge
LC51BK Black color
LC51C Cyan
LC51M Megenta
LC51Y Yellow
Aug 25, 2009 | Office Equipment & Supplies
Black cartiage is not working
Sir,
Check the black cartridge it will refill or not? open the black cartridge and shake it and reinsert. Check with printer options, if any option selected with color only uncheck it and select the best quality option.
Thanks
Good Luck
Aug 05, 2009 | Brother MFC-3360C All-In-One InkJet...
Print only black and white for brother mfc 3360c
Power off the printer.press menu and power on .do'nt release menu button until maintenance appear and flashes fax, scan and copy . type 10 . then next type 49. you will see 00000000.just change last 0 to 1. 00000001. press 99 to exit. you will find the printer only prints B/W only.
Feb 10, 2009 | Brother MFC-5440CN All-In-One InkJet...
How do I remove paper tray on Brother MFC-3360C
you just pull the black tray you look doen infront of mfc-3360c
Jan 01, 2009 | Brother MFC-3360C All-In-One InkJet...
Black ink does not dispense-cleaning cycle has no effect
Try using a dry cloth & if it doesnt work, contact the people who sold the printer to u
Jul 05, 2008 | Brother Multi-Function Center MFC-3360c...
Brother MFC-3360C All-In-One InkJet Printer Logo
439 people viewed this question
CheckitRight
CheckitRight
Ron Dufek
Ron Dufek
James Cagle
James Cagle
