Question about Tylo COMBI-U7 Sauna Heater
Where is the temprature reset button on the tylo combi u8 sauna heater
3 Suggested Answers
  • 9 Answers
SOURCE: heater only gets mild warm Tylo sport 4 heater
more than likley installation problem not enough voltage top operate heating element
Posted on Feb 01, 2010
SOURCE: My tylo supersport 8 sauna
Remove the unit bottom panel (2 small screws) and look at the quick disconnect terminals on the heater rods ( 6 heating rods - 3 on each side of the unit). If you have any corrosion on these terminals, the wires will overheat and fail, preventing the heating rods from working. If the wires did overheat, you should see melted wire insulation. Replace bad wire and quick disconnect terminals with new. Should cost less than $20.
Posted on May 29, 2011
Tylo super sport 2/4 sauna heater. Unit will not heat.
check fuses to ignitor if blown check ignitor if ok check pressure switch
Sep 27, 2015 | Pool & Spa
Wiring diagram for tylo ts30 single phase
Swell... Anonamous,
Take your "patience" issues to the
company (Tylo)
where they might be considered constructive...
It's just a 'TUDE here ...!!
(not helpful)
Control Panel TS (USA)
Carnac the Magnificent
Aug 23, 2014 | Tylo Deluxe 11kW Sauna Heater, w/ TS30-01...
Heat is not working on hvac package unit
The unit you state is a Sauna heater/humidifier. I do not understand how or why it is connected to a heating ventalting air conditioning (HVAC) system, please explain.
Mar 17, 2014 | Tylo COMBI-U7 Heater
Where is the safety shutoff on a Tylo super sport 7
On top of the unit/sauna, you will need to remove the roof or wood covering. It is held down with screws, usually. If your unit in fact does have a reset it will be located on the side of the control box which is located on top of the sauna.
Jan 15, 2013 | Tylo Super Sport 7 Sauna Heater
My tylo supersport 8 sauna no longer produces heat. The timer works but there is no heat. I have checked the circuit breaker but that doesn't appear to be the problem. Any thoughts??
Nov 23, 2010 | Tylo SUPER SPORT-U8 Sauna Heater 8 kW
My name is Andy Smith i am Electrical Engineer on
Hi Andy, I am Kelly and wish to at least make an attempt to help you out. I have done quite a bit of research and like you have come up with little nothing positive.
You may have to buy your own 3 phase 24DC controlled contactor and control that with a yet another relay.
At this point you may want to call Tylo direct or email them and explain your needs to see if they can help you.
Page 8 of their installtion manual shows several 3 Phase connections
http://superiorsaunas.com/storeimages/products/heaters/tylo/tylo_elec_install.pdf
Tylo contct info:
TYLö AB, Svarvaregatan 6, S-30250 Halmstad, Sweden.
Tel +46 35 10 00 80, Fax +46 35 102580. E-mail: info@tylo.se Internet: www.tylo.se
Here is the controller you may need with a 5 meter capillary tube. it does not say if it is 3 Phase and it is mecanical.
Seriously I would contact Typo directly via the contact info above and solve your problem quickly.
The link.... for the TS-30-012
http://www.saunahaus.com/Sauna-Control-Units/Sauna-control-TYLOe/TYLOe-Control-panel-TS-30-012::218.html
I do wish you the best.
Jan 26, 2010 | Tylo TS30-01 Control Panel
Heater only gets mild warm Tylo sport 4 heater
Jan 23, 2010 | Tylo SPORT-U2 Sauna Heater 2 kW
The shaft broke on my timer. I need to replace the timer. Where do I go to order one of these. Thanks Sonny
Call Saunatec Inc. at 888-780-4427 and ask for tech support. We have these in stock.
Dan
Technical Support Supervisor
Oct 11, 2009 | Tylo SUPER SPORT-U8 Heater 8 kW
The steamer does not work in my tylo combi 8 Do you have any solution to have it fixed
When was the last time you removed the rocks and cleaned out the deposits? Replace stones if they are in bad condition. This should be done once a year. also, a limit switch could have tripped and you need a service tech to reset the switch. Hope this helps and if it doesn't, call a dealer in your area. Tylo is a swedish company but there is a N. American handler http://www.airmist.com/.
Mar 21, 2009 | Tylo COMBI-U8 Heater
Tylo COMBI-U7  Sauna Heater Logo
53 people viewed this question
Top Tylo Pool & Spa Experts
Jay Finke
Jay Finke
Bill Jordan
David Spradling
David Spradling
Are you a Tylo Pool and Spa Expert? Answer questions, earn points and help others
