Question about Tylo COMBI-U8 Heater
Where is the reset button on tylo combi-u8 - Tylo COMBI-U8 Heater
My ideal logic combi 30+ is saying ignition lockout and my radiatiors arent heating up as well as my water not turning hot. How can i fix this please?
Lockout is a safety feature. Usually a latching condition and needs to be investigated rather than blindly reset. (The Combi has a bit more intelligence.) With the ignition locked out, you can't hi-fire the boiler, so no hot water of either type. The 'L' should also show a code number - check your user manual (google) for more guidance.
I've had a lockout on a non-combi: it was caused by lack of circulation of central heating water through the boiler.... The system boiled and the trip tripped. The pump WAS running, but wear in a valve actuator resulted in the valve feedback saying valve open while it was physically shut.
Dec 31, 2016 | Water Water Heaters
Hvac package unit the heat is not working
Is it gas or electric. Have you checked the fuses
Mar 17, 2014 | Tylo COMBI-U7 Heater
Heat is not working on hvac package unit
The unit you state is a Sauna heater/humidifier. I do not understand how or why it is connected to a heating ventalting air conditioning (HVAC) system, please explain.
Flashing red light on Worcester 24i junior combi boiler
Pressure is ok? at 1 bar or above
I think on this one there should be a reset button [red] on the left hand top of the casing - or lower the control panel [ phillips screw on each side] and the button is on the left of the base plate. Press this and try the heating.or hot tap
P.S. if you're on a prepayment meter check you have gas.
Nov 08, 2009 | Water Heaters
Where can i get 2 replacement elements?
google for it , reseller wil and can order for replace ment parts from factorry
look a near by resseler and try to order it by the internet or look manuall for factory places and try to connect them it are expencif boiler they wil have repair parts
Nov 08, 2009 | Tylo DELUXE 7 Heater 7 kW
Britony Combi se 80 boiler
Steel wool is the way to clean. Hope this helps
Oct 18, 2009 | Water Heaters
The steamer does not work in my tylo combi 8 Do you have any solution to have it fixed
When was the last time you removed the rocks and cleaned out the deposits? Replace stones if they are in bad condition. This should be done once a year. also, a limit switch could have tripped and you need a service tech to reset the switch. Hope this helps and if it doesn't, call a dealer in your area. Tylo is a swedish company but there is a N. American handler http://www.airmist.com/.
Mar 21, 2009 | Tylo COMBI-U8 Heater
Boiler problems
heres a copy of the serviceing manuel for the unit. just click on the link and download the manual. http://www.ariston.co.uk/uploads/doc482c2cada6e71.pdf good luck
Jan 11, 2009 | Water Heaters
Tylo COMBI-U8  Heater Logo
56 people viewed this question
Top Tylo Water Heaters Experts
Donni Steen
Gil Shultz
Gene Haynes
Are you a Tylo Water Heater Expert? Answer questions, earn points and help others
