Question about Admiral Washing Machines
Manual for model LNC6760B71 - Admiral Washing Machines
It won't turn on
Admiral, Whirlpool, Maytag - Washer Repair - Not ... - YouTube
? 5:51
www.youtube.com/watch?v=oBihToN6dxs
Sep 6, 2013 - Uploaded by ApplianceVideo.com Troubleshoot your Admiral Top Load Washer that has these following ... The machine will not complete cycle (fills but won'twash or agitate) I recalibrate it and it ... my washer will not startbecause of lid latch it is an admiral.
Sep 29, 2015 | Admiral Washer Control Panel Frame 35-5733...
Admiral washer model AW20N2V making a clicking sound...
call manufacturer. heard there was a recall... for dangers of fire.
Oct 02, 2012 | Admiral Washer Control Panel Frame 35-5733...
Admiral Capacity plus, 2 speed, model# LNC6760B71 stopped in mid cycle, found motor pulley burned right off, belt on floor. How do you find out what caused this ?
possible the belt had stretched and the pulley was turning but the belt wasnt moving causing it to get hot and break
make sure the electric motor is turning and also the pulley that turns the wash tub, fit the new belt and make sure you tension the belt or it will slip again and ruin the new belt
Jun 13, 2010 | Washing Machines
Are Admiral washers poor quality/
MY KENMORE IS 15 YEARS OLD AND GOING STRONG STILL. PERSONALLY DON'T CARE FOR ALL THIS FANCY SCHMANCY DIGITAL COMPUTERIZED WASHER TECHNO. IT'S YOUR CHOICE IN THE END. GOOD LUCK
Apr 24, 2009 | Admiral AW22 Top Load Washer
WON'T SPIN DRY
You need to check if there is power to the motor. If so the motor is defective.If not, the timer may be the problem. There should be a wiring diagram on the back of the unit. Using a voltmeter, trace the power.
Ray
Dec 17, 2008 | Admiral AW22 Top Load Washer
Admiral Washer Model Number lnc6760b71
Dear Friend,
ngfam1 here for you!
I am happy to be of assistance!
It needs a belt replacement!!!!!!!!!!!!!!
Here is a good service that I recommend to my customers,
in our 65 year old appliance business!
A&E Factory Service
1-800-905-9505 -(IN U.S.A.)
They are open to make appointments 7days/24hours
A&E is factory authorized service for most brands!
Including warranty work!!!
They will help you, and all will be well!
You will be fine now!
Thank You
Bless you,ngfam1
PS. Please give me a good rating here in fixya.com before you sign out!
Aug 24, 2008 | Admiral AW22 Top Load Washer
Admiral LNC6760B71
Probably the pump or filter is blocked, remove the pump and filter and remove any debris
Jun 05, 2008 | Admiral AW22 Top Load Washer
Admiral mod#lnc6760b71
Water runs out, but does not spin, nor dry the clothes. Motor is good.
Dec 08, 2007 | Admiral AW22 Top Load Washer
Washer spins agitates, but will not drain
Possible your outlet filter is blocked; find out where it is from your manual, clean it out and re-fit. Also try the spin only function to see if it drains.
Jun 13, 2007 | Admiral AW22 Top Load Washer
Washing Machines Logo
66 people viewed this question
Top Admiral Washing Machines Experts
Dan Webster
Dan Webster
Sal DeAngelo
Are you an Admiral Washing Machine Expert? Answer questions, earn points and help others
