Question about Garmin GPS
Won"t pick up satellite - Garmin GPS
  • robertcole Oct 24, 2008
    nuvi 360 will not pick up satellite
  • Garmin Master
  • 13,433 Answers
Go to a open area and walk around for a moment, it should pick up. make sure noting is on the way of the gps and the sky, clouds don't matter.
Posted on Oct 24, 2008
    Genius:
  • 1,550 Answers
Try hard reset .
Also go for firmware update .
You need to provide correct model details for further help.
Posted on Oct 23, 2008
  • SAM ANDERSON Oct 24, 2008
    Have you tried master reset and firmware update ?
    After firmware update you need to wait around an hour to get satellite signal .
    If you are not able to acquire signal have a check over the antenna connection .
    Chance of antenna being damaged .
    Genius:
  • 1,847 Answers
Can you describe the issue in more detail.
  • Legin Varghese
    Legin Varghese Oct 23, 2008
    I believe you need to go to the garmin website and download the latest
    updates for Garmin XT. I had the same problem with an older version of
    the software but downloading the update fixed it.
Toshiba satellite l25-s119 internet won't work.
Wired or Wireless? Try a Ethernet Cable to verify the ISP is sending a signal. Try another broswer.
May 04, 2013 | Computers & Internet
I am moving tomorrow and won't be able to afford cable or satellite for awhile. I have a newer model Sanyo tv. Will I need a converter box or can I hook an antenna directly into the tv to pick u
If your TV has the screw-on coaxial cable connection on the back, then you will not need a converter box. You can attach an internal or external antenna and have your TV scan for digital channels. The converter boxes are mostly for old CRT TVs with analog tuners or newer home theater "monitor" TVs which are being produced without built in tuners.
Dec 21, 2012 | Sanyo DP32746 32 in. LCD Television
Pc game neverwnter nights won't show cursor during game
it's a problem of your OS bit version.. install 64bit version
Dec 04, 2017 | Atari Video Game Consoles & Games
TV won't pick up channels 7-13
These are what once were VHF channels and are still mostly assigned to local stations.
You didn't mention the source for your received signals, if antenna, cable or satellite and it does make a difference as to the possible source of the problem.
If you are receiving via antenna, then the problem is within the set itself. If from one of the other two sources requiring a 'box,' then the problem is likely within the cable or satellite box that is between your incoming signal and the set.
Jul 29, 2012 | Magnavox 39" LCD 1080p HDTV 39MF412B -...
Why can't i optimize image?
Go to the CMS Setup menu. There are three options; Simple, Full and My Menu. You need to set the Full option to have access to all of the menu options. I think your camera is set to the Simple option which limits the available menu functions.
Nov 17, 2011 | Nikon D80 Digital Camera with 18-55mm Lens
My Toshiba Satellite L300-D won;t get poast Startup Repair page. Keeps defaulting to Startup Repair and then says "Windows cannot automatically repair your computer". It all started with a folder...
Your Hard drive is faulty which means it wont go any further and loops back trying to fix a problem it cant do. you can either replace the hard drive and install everything from scratch or send it in to a computer repair shop to do it for you. Kronoguy
Aug 02, 2011 | Toshiba Satellite Pro L300 Notebook
I have a Nuvi 200w that I received last December as a gift. This unit takes forever to aquire a satellite. The "DIFFICULY AQUIRING SATELLITES" message comes on 90% of the times I try to use it....
While under warranty.... yes.... Make sure it's been registered on their site before calling them and requesting an RMA number.
- Jim
Sep 17, 2008 | Garmin GPS
Usb connection on sirius stiletto 2 to pc
I had a sync problem with the Stiletto 2 (SL2) and was able to resolve it by the following procedure:
Click "Start"
Click "Run" > Type "devmgmt.msc"
Click "+" next to "Other Devices"
Note: You should see a question mark and exclamation point next to "Stiletto 2"
Right click on "Stilleto 2" (to see menu); then, left Click "Update Driver."
Follow the steps in the windows hardware update wizard.
Apr 07, 2008 | Sirius Stiletto 2 Satellite Radio Receiver
GPS Logo
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
