Question about Craftsman Garden
I have a craftsman lawn tractor #917. 272912, the bolt to starter is missing, I do not see any place for this bolt to attach to the motor housing. Could you show a diagram of motor showing how starter
Briggs &Stratton engine-model number 4077777, Type number 0174-E1. Bolt parts #691263 is missing from starter. I cannot find any place to reattach this bolt to motor housing .Could you direct me to a diagram that would show me how to attach starter to motor housing?
Techjoel
  • 79 Answers
SOURCE: Diagram for Lawn tractor instalation belt
managemyhome.com has many manuals for yard machines/mtg lawn tractors.
The information you need may be generic and therefore almost any manual may help re-install the belt. This manual is for the 660-679 series. Once at the site you can check different model numbers for one that may be closer to the machine you have.
http://www.managemyhome.com/mmh/lis_pdf/OWNM/L0403122.pdf
Good luck,
Techjoel
Posted on Jun 05, 2009
  • 138 Answers
SOURCE: Craftsman LT 1000 with Briggs and Stratton 20 OHV
lift your seat and look at the label that you got your model number from. to the right of the model number is the serial number. the first six digits of the serial number is the date your tractor was made - for example: serial no. 060802D002756 would make the unit made June 8, 2002
Posted on Aug 18, 2009
  • 17 Answers
SOURCE: craftsman 19.5 lawn tractor w/briggs & stratton keeps flooding
This could be a number or items from no spark to a faulty carburetor, a plugged up air filter, valves out of adjustment, poor gas, faulty spark plug.
First, see if your getting spark, how about taking the wire off a plug(s) and holding it about 1/8" or so away from the plug with some masking tape while you crank the engine. You should be able to see the spark jumping the gap, it helps if it is not too light outside. If you attempt to do this with your hands, you will get a spark jolt, it hurts, so use the tape and remember, the engine could start so proceed with caution.
If you have no spark there, then you ignition or magneto is faulty. This would be unlikely in the broader scope of things. You will likely get spark. Make sure the plug is clean, take it out and inspect. If it is covered in gunk well clean it. It will smell like raw gas but you already know that. Change the plug if in doubt.
Remove and clean and replace the air filter.
If you have spark, and a clean filter it is likely a carburetor problem, Depending on the carb, it could be the choke is faulty or, as per the below.
Depending on what model you have there is a float assembly in the carburetor that stops the fuel from flooding the carb and air intake. The gas tank is higher then the carb right, so if you dont have a mechanism for stopping the fuel from leaking out the hole that goes into the engine, it will all leak out right, as into the fresh air intake because its easier than going into the engine. So, there is a miniature float assembly, sort of like your bathroom toilet float to stop the water. Well there is a small wedge type needle that seats into a hole and it is attached to a float. As the gas rises in the bowl, it pushes up the float, sealing the gas into a chamber, as you use more gas, the float lowers and more gas goes in. So ,there is dirt jammed into the float bowl sealing needle, just a little, thats all it takes. So, shut off the gas somehow, hopefully you have a valve, or squeeze the rubber line, then undo the float chamber, its one nut on the bottom. Clean carefully. The needle, little spring and float assembly are delicate. Also, the needle could be worn from engine vibration, so it may need a new needle. It would help if you described the engine and carb though.
I posted that as a solution to another problem, but yours may also be the valves need adjusting. Depending on the amount of hours, say over 200, then the valves timing will likely be off a bit. Check the clearances with a feeler gauge, it is not as difficult as it seems. Check your Owners manual for the clearance at top dead center. TDC is when you take the plug out and watch the piston arrive at the top of the cylinder through the spark plug hole when you are turning the engine over (do this by hand, battery off. Make the adjustments with the valve cover off. Follow the instructions.
Hope some of this helps.
Posted on Sep 21, 2009
rwvanlue
  • 486 Answers
SOURCE: Craftsman lawn mower. Briggs & Stratton 6.75
1) check plug for being carbon fouled or fuel fouled. Even though it fires, it may not be firing correctly
2) make sure you have compression 75-100 psi. since the compression release so you can pull the rope works off of the exhaust valve, you may not get anymore than that.
3) Is there water or debris in the float bowl
Fuel Starvation - Float Bowl Carburetor
1) remove air filter assembly
*be cautious of tearing the mounting gasket. If it does tear, you HAVE to replace it. It is part of the priming system
2) remove the float bowl fastener. This is the main jet
3) carefully remove the float bowl, the rubber o-ring/gasket will not be able to be used if it is removed, you WILL have to replace it
4) using a spray 'carb cleaner'
spray up thru the center of the carburetor
spray and clean the main jet with cleaner and 'tag' wire
(tag wire is very thin, and can be used to clean the hole in the center of the main jet)
5) clean any debris from inside the bowl or carb body
6) re-install bowl and center bolt, air filter assembly
*if you need gaskets, your local lawn & garden dealer can supply. The kit is cheaper than individual gaskets, and all the parts needed to finish the above repair are in the kit.
I’m happy to assist further over the phone at https://www.6ya.com/expert/rolandw_c013176d62ee17ae
Posted on Nov 26, 2009
  • 454 Answers
SOURCE: Briggs and stratton lawn tractor. misses under load after warm up
check air filter, may be very dirty causing it to run too rich
Posted on Jul 30, 2010
Where is the solenoid located on a briggs and stratton engine model number 282H07/0334
Mary Jo, solenoid is not normally on engine, follow the positive battery cable from battery to where it bolts to a small double terminal device(this is the solenoid) the other bolt has cable attached that goes to battery.
Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Mower Starter Solenoid Replacement Craftsman Riding Lawn Mower Repair Part...
Replacing Solenoid on Craftsman Lawn Mower or Tractor
Mar 24, 2016 | Briggs & Stratton Garden
This is a Craftsman Lawn Tractor 18.5 HP Model # 917.275760
Are you sure the battery is good and fully charged and are the battery cables clean and tight both ends?
Oct 19, 2015 | Craftsman Garden
Craftsman lawn tractor blade lever won't disengage
you either have a broken or missing spring that retracts the engage pulley or there is dirt or debris under the arm on top of the deck that the pulley is attached to.
Jun 14, 2014 | Craftsman 20 Hp 42" Deck Lawn Tractor
Our LT1000 will not start, not even turn over. Made a circle around the yard, cut it off to talk to someone. Then tried to start back and now it will not start. Even the next day still will not turn over....
remover the starter and bench test it with a battery charger or a battery to see if it works still. Maybe the starter solenoid is at fault only. Were the battery cable attaches to the starter bolt is positive and the starters housing is the ground. Connect the wires correctly to test this starter. The armature sounds like it is against the field casing keeping it from moving. It can be from a wormn armature shaft bushing if the starter seemed to operate just fine the time it started last
Jul 03, 2011 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
I have a Craftsman lawn tractor model number 917270821 and I can't get the starter off of it, I must be missing a step. I disconnected the power from the battery and unscrewed 2 bolts and got the outer...
Either pull down hard on the starter to remove it from the engine block and/or give it a few good blows with a rubber mallet. It should break loose for removal.
Feb 04, 2011 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
I lost the bolt that holds the motor in place. How do I find a replacement bolt?
should be four bolts take another bolt out goto hardware store have them match one up those bolts are pretty common or lawnmower shop
Apr 15, 2010 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Replacing starter on Craftsman 917.270824 lawn tractor. It appears I have to remove the flywheel to replace the starter. Do I have to remove the flywheel to complete this task? If so, how do I remove it...
Its not THAT bad.
First disconnect the ground wire from the battery.
2. REmove the battery cable from the starter. Be careful that the inside nut on the post does not turn.
3 remove the plastic starter cover from flywheel shroud.
4 there are 2 vertical bolts that mount the starter to the crankcase. The outside bolt is fairly accesible. The inside bolt seems concealed. Remove the bolts. The inside one can be removed with a box end wrench. It is long winded and takes a minute. Once the bolt is unthreaded the starter and the bolt can be removed together.
Assembly is the same in reverse. The inside bolt should be placed in the starter housing first then slid into place.
Dec 30, 2009 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
Instructions to replace starter on JD RX75 lawn mower engine
DID YOU TAKE THE TOP COVER OFF THE MOTOR? AND THERE IS ONLY ONE WAY THE STARTER GOES OTHERWISE IT HITS THE SIDE OF THE ENGINE.. i REPLACED MY STARTER FEW MONTHS AGO.. tHE STARTER WIRE HAS TO BE ON THE OUTSIDE TOWARDS THE OUTSIDE BODY....
Sep 05, 2009 | Garden
Craftsman GT3000 Lawn Tractor
Searsparts.com has all the parts you need.
Jun 21, 2009 | Garden
Garden Logo
63 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Jim Parker
Jim Parker
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
