Question about Tools & Hardware - Others
Need parts for framing nailer model 91053 help
Need safty head mecanesim
rowdy45176
  • 2176 Answers
SOURCE: Need cleaning instructions for ITW Paslode Impulse
I would recommend you go to Paslode.com and under support there is a section for cleaning of these tools. I can tell you how to do it but it is indepth. What kind of cleaning solution do you have? You can't just use anything to clean them. Also the red light on means a failure. Does the fan work? Does it have fire and it also means that the battery is weak. They also have a good troubleshooting section on the site. Let me know if I can help further.
Posted on Feb 17, 2009
jj505
  • 195 Answers
SOURCE: framing nailer not setting nails
Dear cjcoolair,
No need to replace any parts. There should be and allen screw type adjusment somewhere near the front plate where nails exit so as to adjust depth,may be black plate with arrows up or down depending ---loosen screw,push up/down as needed,tighten test and reset as needed.
Please rate.jj
Posted on Apr 05, 2009
comax
  • 154 Answers
SOURCE: Campbell Hausfeld NS2190MVRB 21 Degree Round Head
Remove any nails in the magazine, and you can carefully take a pin pinch of a size that fits into the nose (where the nails come out). Try to carefully tap the driver back into the gun.This will sometimes clear the jambed nail. If the driver is severely jambed you will have to dismantle the entire unit to separate the driver from the nose of the nailer.
Posted on Apr 15, 2009
efs_perpends
  • 1996 Answers
SOURCE: Framing nailer intermittently doesn't shoot the nail.
Make sure to blow out the magazine where the nails load, make sure the spring tension on the nail clip is working properly, make sure you're not holding the clip somehow with your off hand so the clip can't feed correctly.
Posted on Apr 20, 2009
rowdy45176
  • 2176 Answers
SOURCE: What is my framing nailer?
I would go to Campbellhausfeld.com and under products look at the couple nailers they list. They do have a 28deg nailer and also a 21deg, so you could be right in thinking that it is a 28deg, they also show how to find the model number if there is still a tag on the tool. This would be a start to identify your gun
Posted on Oct 08, 2009
Plunger extended and blowing air in framing nailer
Air leaking out of head and driver extended indicates that the cylinder seal is bad and or the head valve is sticking or stuck in the head. Easy to check by removing the head and looking at the large plastic seal on top of the cylinder. If seal looks good, pull out the head valve and lube with white grease. Parts are here :
Good luck
Jul 20, 2014 | Porter Cable FR350A Factory Reconditioned...
Need a manual for Ridgid R350CHD clipped head framing nailer
Manual can be found at the address below. Enter your model number in the search box. Good luck with your nailer.
https://www.gardnerinc.com/manuals/
I found manual at the above address for my ridgid full round head nailer.
Nov 08, 2012 | Ridgid FactoryReconditioned ZRR350CHA...
Dewalt D51850 framing nailer leaks air continuously
You could have broken internal parts but more likely you have broken or worn o-rings inside the nailer. You can go to the Dewalt service site at, http://servicenet.dewalt.com/, search for your model number and get a good breakdown of the nailer and order the parts you need to rebuild it. If you replace any o-rings, replace all of them.
May 25, 2012 | Dewalt D51850 Heavy Duty 20 Degree Full...
Driver is stuck in down position, Hitachi hc65ah nailer
did you try to flip the release on the driver head right above the safty
Jun 24, 2011 | Hitachi Parts- Nv65ah Nailer-driver...
My paslode impulse framing nailer fires intermitantly. New batt & fuel cell.
Here is a tip that I wrote about the Paslode nailers and the problems that can come up with them.
I also have a link to the Paslode manuals which contain Paslode cleaning and troubleshooting guides.
If you need parts for your Paslode, there also is a link for a site that sells the Paslode nailer parts.
Paslode Cordless Nailer Problems
heatman101
Oct 23, 2010 | Palmgren 91232 Full Head Framing Nailer
I cant get the head of my framing nailer back together
Go to Paslode website and get the parts breakdown/schematic. Making sure that everything is right way. This problem is a tad tricky. Trick is don't get mad or discouraged. The gun will win. Lemme know if you need anymore help. Pleas rate me.
May 26, 2009 | RTO PasLode 900420 Impulse Framing Nailer
Dewalt framing nailer
Dewalt makes a great line of nailers and has a good network of factory repair centers with helpful repair department. Their web address is www.dewalt.com . Click on service/support button then look for Instruction Manual button to download your manual. When search window appears enter your model number. You can also view a parts list and order parts. I have a very old dewalt nailer that was not listed on their website but my local service center made me a copy of theirs at no charge. Good luck.
Jan 20, 2009 | Dewalt D51850 Heavy Duty 20 Degree Full...
Stanley bostitch coil nailer gun
check the safty shaft and see if something could be under trigger safty causeing it to fire.
Jan 05, 2009 | Stanley Bostitch Coil Framing Nailer
Tools & Hardware - Others Logo
Top Tools & Hardware - Others Experts
john h
Are you a Tool and Hardware - Other Expert? Answer questions, earn points and help others
