Question about Onkyo TX-SR804 7.1 Channels Receiver
ONKYO TX-SR804 . AT BOTTOMRIGHT NO.1690022265
    Filmmaker:
    Uploaded 5 video answers.
  • 76 Answers
Hi Arthur,
First of all, thank you for purchasing the Service/Repair Manual of Onkyo TX-SR804.
Please email me at mjsvillanueva23@yahoo.com I will send to you the copy. It is a PDF file format and can't be uploaded here.
Again thank you so much!
Take care and have a great day!
Ratings and feedback are highly appreciated!
Kind Regards,
mjsazon
Posted on Feb 11, 2012
  • mjsazon Feb 13, 2012
    I can't send to you the manual right now because I don't know where to send it via email. Email me at mjsvillanueva23@yahoo.com so that I will know where to send it.
Onkyo Reciever TX-SR806 Losing HDMI signal.
I had the same problem with my xbox 360. I was able to fix the problem by disabling the Display Discovery setting on the xbox.
Sep 10, 2009 | Onkyo TX-SR804 7.1 Channels Receiver
Tip
ONKYO TX SR804 DISPLAY, SUB VOLUME AND SUDDEN SHUTDOWN FIXES
The Mainboard on the TX SR804 is falty and i just fixed two units with this solution and it bullet prof un der the HDMI board you will find the mainboard stating up right with its back facing the preamp board and it has 3 screws that secure the mainboard to the system 2 on the middle top of the receiver and one on the right side just under the screw you removed for the HDMI board that secures it to the Audio processor board.
Once the screws have been removed pry the board back going from left to right and slowly disconecting the board. THE FIX. once infront of you clean all of the ribom connectors and the and bend the pins on the connector P954A, P959A , P2005A and P2004A THESE CONECTORS ARE THE REASON THE SYSTEM WILL SHUT DOWN SPECIALY THE FIRST TWO. I ALSO RECOMEND PUTING A INTERNAL FAN POINTING TO THIS BOARDS KEED THE HEAT DOWN. the reason the SUB is low or the HDMI does not seem to work well they are related to the SIF connectors on the the are 4 on this board and i used a thin bud hard plastic and inserted bering each sif cable to push the pins againt it. this is a 20 minute job and you amp will be fixed. i fixed many like this. Have a wonderfull holiday. Mvianna
on Dec 21, 2008 | Onkyo TX-SR804 7.1 Channels Receiver
Onkyo tx sr804 receiver turns on by itself
I have the same receiver and the way to fix is simple. in the main board of this unit there are 5 connectors and they slide into other components like Lego. the issue is the king of material they are made of it's cheap. if you reseat the mainboard it will fix it for a day or two, them it will start again. the easyway is to re seat the board and put a fan inside of the receiver between the transformer and the inside of the amp pointing down about 20 degrees connect the fan to a ajustible voltage adapter and connect it to the outlet in the back of the unit. so it comes on when you turn it on. this voltage adapter is cheap. the adapters people buy for phones and or MP3's at Radio shack or Best buy it goes from 1.5v to 12 volts/ this way you can control how loud the fan is in side the receiver. i find 4.5V does the trick. The connectors on this board start to loose contact with some of the pins when heated. the fan keeps it cool enouth to fix the issue. I fixed manny these ONKYO 804's this will fix it. you just have to do it. the main board is inder the HDMI board in a Vertical position running from one side to almost the Power supply. it has 2 screws also holding it in the inside middle back of the amp. Becarefull with these amps 75 V at 23amp's DC is no joje leave it off for a couple of hours to satart working on it. Good luck.
Aug 26, 2009 | Onkyo TX-SR804 7.1 Channels Receiver
The receiver thinks there are headphones connected
Onkyo directed me to return the unit to a service center. Apparently this is a known issue and after reading web postings I believe it. There were dozens of similar cases with a variety of Onkyo recievers. I was able to remove the ribon connector from the headphones and discovered it is not a shorted headphone detector. We will see what the service center does. I'm not looking forward to paying for shipping a 66 lb receiver.
Aug 04, 2009 | Onkyo TX-SR804 7.1 Channels Receiver
Need help hooking up a KRK powered subwoofer to an Onkyo 7.1 receiver
a single male rca spliting into 2 male rca's ....a signal splitter
Oct 30, 2008 | Onkyo TX-SR804 7.1 Channels Receiver
No Sound
Tell me in details how you connect your whole home theater system.Step by Step.Video and audio connection please.
I need to know does it happen only on certain component(ex. dvd player?)
solutiondoct
Oct 21, 2008 | Onkyo TX-SR804 7.1 Channels Receiver
Onkyo tx-sr804 ..problem with the remote
PRESS THE RECIVER BUTTON THIS SHOULD WORK THE AMP AGAIN.
HOPE THIS HELPS.
CABLE GUY.
Mar 26, 2008 | Onkyo TX-SR803 Receiver
Hum niose in my onkyo tx-sr804
Hi there, sounds like you have a ground loop happening there. Check out ground loops in google to get some tips. What you should try is use one wall plug for everything (with an adapter on it) and check that none of your other cables are damaged. try find new cables and put them in place of the old seemingly fine cables.
Sep 23, 2007 | Onkyo TX-SR803 Receiver
Onkyo TX-SR804 power supply
If you imply an AC voltage transformer by saying "power supply", I don't believe it will be difficult to find one. If you stay in Istanbul, I recommend that you go to "Dogubank". You can choose from a wide variety of options at that place. All you have to pay attention is that the AC frequency (Hz) of the transformer you're about to purchase. It must be around 50Hz to operate your amp.
May 05, 2007 | Onkyo TX-SR803 Receiver
Onkyo TX-SR804 7.1 Channels Receiver Logo
Top Onkyo Audio Players & Recorders Experts
 Grubhead
Grubhead
Electro Med Services...
Are you an Onkyo Audio Player and Recorder Expert? Answer questions, earn points and help others
