Question about Canon PIXMA MP160 All-In-One InkJet Printer
Printer alignment My printer will pull the paper in at an angle. It will not feed straight so that the paper will feed into the printer.
  • Anonymous Oct 26, 2008
    my canon printer pulls my paper in at an angle so i cannot print
  • 32 Answers
This problem is most commonly caused by the paper thickness adjustment. There is an adjustment gear internally on the rollers which align the rollers for parellel adjustment as well.
Owners manual generally gives instructions on adjustment of these, though often it is beyond user ability.
Often it involves removing covers, and should only be attempted if confident on this type of repair.
Let me know if you still have problems if you attempt this yourself.
Posted on Oct 24, 2008
Hi - having a paper issue. When paper feeds from the back it will not go in straight so everything prints at an angle. any suggestions
If you have previously had a paper jam, and it tore the paper, there could be a very tiny piece of paper stuck in the feed on the side...it only takes something very tiny to prevent the paper from feeding correctly...a child dropping a little piece of food, it could be anything...but I'd be about 90% sure that it's there. I found one once and it was so small it took forever to find it, and it was even harder to get out...you kind of have to work at it with some Q-tips, eyebrow tweezers, a paperclip, something that you can go in and attempt to clear the feed. If you dont/can't find it you may have to take it apart, and that's not fun, and runs the risk of it "never" aligning correctly...so be persistant.
Jun 15, 2010 | Lexmark X5470 All-In-One InkJet Printer
Paper feed not straight straight therefore printing an angle
it is problem transfer roller clean it then solve your problem
Nov 21, 2009 | Samsung CLP 300 Laser Printer
Why does my dell 1720dn print crooked?
The paper feed rollers are dirty and are pulling the paper in at an angle.
Could be from high % cotton paper or sticky label printing.
Clean the "pickup" rollers with eyeglass cleaner (not Windex).
Nov 06, 2009 | Dell 1720dn Laser Printer
Paper loading at angle annd now paper stuck inside
check behind your printer you wil see the cover pull and remove and jam paper, put off the printer before performing this task please
Jul 03, 2009 | Canon PIXMA iP4200 InkJet Photo Printer
The Paper is feeding in at an angle and is bending
Make sure the paper is feeding straight! As in manually be a guard. Just do this once and then you'll be fine.
Jun 27, 2009 | Canon PIXMA MP800R All-In-One InkJet...
Canon LBP 1120 Offset paper feed and subsequent jamming.
G'day, I pulled the whole printer down and gave it a clean and put it back together and set it to work. All good.
May 11, 2009 | Canon LBP 1120 Laser Printer
Epsonstylus DX4800 taking paper in at an angle and messing up
Possible printhead issue.
Please do head alignment using the driver.
Apr 19, 2009 | Epson Stylus DX4450 All-In-One InkJet...
Canon i450 uneven printing
The problem could be as simple as your paper not going through the tray straight, or just aligning the print cartridges. Make sure when your paper is pulled through the printer that it isn't getting pulled more quickly on one side than the other. Also, go into your printer control panel to find the 'alignment option' and follow the steps to complete a proper alignment. If that doesn't work, get back to me with more details about the problem. (is it on a slant, are half the sentences printing on a different angle etc.)
Apr 16, 2009 | Canon i450 - Printer - color - ink-jet -...
Paper feed problem
Normal 0 I suggest you get a sheet of Card Stock (Heavy paper) and place it in the feed way. Then press the print button applying a slight amount of pressure on the Card Stock so it will feed through the printer. The reason for this is in some cases I have been able to clear the paper track of debris that was deposited there over time.
Worth a try, as I have fixed a number of printers this way, saving costly repairs.
Hope this helps. Bud
Jan 04, 2009 | Office Equipment & Supplies
Brother HL 2040
Make sure the paper aligning slides are tight to the sides of the paper. In the case that they are spring loaded make sure there is not something preventing them from holding the paper properly aligned.
The print head could be 'off-track'...
If the text is properly aligned on the edge of the page, but appears crooked it is related to the print head assembly. If the text is not aligning to the edge of the page then the paper is not feeding straight and the paper aligning slides are at fault.
It is also possible that one of the paper feed rollers are not grasping the paper and it is forcing it to one side as it pulls it in.
Mar 10, 2008 | Brother HL-2040 Laser Printer
Canon PIXMA  MP160 All-In-One InkJet Printer Logo
106 people viewed this question
old marine
old marine
