Question about Bissell 6594 PowerForce Bagless Upright Vacuum
Frozen Beater Bar
My beater bar will not turn on my vacuum. I took everything apart and cleaned it. I bought a new vacuum belt even though the old one was still in tact. It burns rubber when I turn the vacuum on, and the brushes don't move at all. I'm wondering how to take apart the beater bar itself. The end caps do not appear to come off for cleaning. But it's just frozen in place. Not even the new stronger belt can move it. Any help?
  • millerhammon
    millerhammon Feb 11, 2012
    OK, I figured out how to take apart the beater... the ends pop off if you hit em just right with a hammer. :) I got one side unfrozen and greased up with WD 40, but the other side is just plain givin me troubles. it wont budge at all. Not sure what to do about that... :P
  • 206 Answers
I expect the brushes/bar are removable. the man manufacturers can come up with some realyy ingenious ways of putting thier machines together!
Posted on Jun 19, 2017
  • 1673 Answers
SOURCE: Bissell Lift-Off(R) Revolution(R) Turbo Upright.
If you have a rubber smell, then the belt is slipping, does the brush roll turn freely while holding the ends? If not then replace it, part #2036619, if it is ok, then the belt has strectched and is slipping under load, part # 2106679, Style 8.
Posted on Jan 21, 2008
SOURCE: Bissell Beater brush sporadic
I was having the same problem with my Healthy Home vac and happened to read a solution to another question on this site posted by someone with the user name "9008". I followed his suggestion and my vac works great again. There is a screw on the back of the handle near the cord holders that can loosen up over time. When this screw is loose, the brush switch (and therefore the brushes) do not work properly. I'm not sure why this little screw causes such a big problem, but it does. To find this screw, look on the back of the handle, it's on the edge, kind of behind the hose. You should see a triangle with a Phillips screw-head symbol embossed in the plastic. Tighten this screw gently (careful not to over-tighten and strip it!). Also, not a bad idea to tighten the other screws...I found many of mine to be quite loose. Hope this helps!!
Posted on Sep 05, 2009
  • 3 Answers
SOURCE: beater bar brush won't turn and seems to be seized
I removed the pump and sprayed silicone spray on it.
Posted on Feb 22, 2010
  • 4088 Answers
SOURCE: beater bar is not coming on- belt is on, canister
Remove the beater bar and clean the debris from the bar and the end bearings. Remove the belt (remember how it is installed) and check it for any damaged areas. Make sure the bar turns freely before the belt is attached to the motor drive. Hope this helps!
Posted on Mar 15, 2010
  • 276 Answers
SOURCE: Beater brush
Note: The brush will not rotate when the machine is locked in the upright position, because an internal micro-switch turns the brush motor off.
- Make sure brush switch on the handle is on.
- Check the belt through the clear brush cover. If this appears damaged or broken, take your machine to a local BISSELL Authorized Service Center to have it replaced. If the belt is intact, please continue checking the following:
- Ensure both power switches are turned on when you check for brush rotation.
- Unplug the power cord and remove the handle completely. Slide handle back into the lower section of handle, ensuring the screw is in tight. If the handle is not aligned properly, this will affect the power of the brush motor.
- Look for debris wrapped around the brush (i.e. string, hair, fibers, etc.). When the machine is unplugged, cut away any visible hair, fibers or debris from the brush roller. This brush is NOT removable from the machine.
- If something has become lodged in the foot and the brush shuts off, turn off the vacuum and unplug this from the outlet. You can now remove the obstruction. The brush will automatically reset when the vacuum is plugged in and turned back on.
Posted on Jun 15, 2010
I have an Eureka Altima Model 2961AVZ vacuum that suddenly stopped picking up. I have taken it apart, checked the belt which was fine, replaced the hepa filter, and checked for clogs in all the hoses
Is the beater bar actually turning when the power is turned on? Sometimes the belt is fine, but something is jammed and keeping the beater bar from turning. What about the section behind the beater bar, but before the hose upright. I've found large pieces of paper jammed in here and then hair gets caught, ultimately blocking the whole system. Usually you have to turn it over, remove some screws and disconnect the belt and beater bar to get underneath. Just reassemble it in the reverse order to how you took it apart. Double check the hoses and run a "unwound" metal coat hanger through to unclog anything. Does the vacuum " suck" with the hose or tube up to it disconnected? If not you may have a motor that somehow got junk pulled into it. You can open this up as well and clean this out. Of course unplug it all before doing anything.
Nov 03, 2014 | Vacuums
Windtunnel first one used 6 times beater bar stopped working, took apart cleaned and belt was fine. this one had a reset switch for beater bar. had insurance at best buy so returned for a new one. used...
Sorry, you feel like that. I have rentals and 6 windtunnel's (I prefer the bagged ones) and have never had a problem such as you have described. I think Hoover makes a great vacuum.
Sep 14, 2011 | Hoover U6630-900 WindTunnel Bagless...
The beater bar won't spin
Even though the belt is intact it can still be stretched and if it is it won't turn the brush roll when it's on the carpet. Here is a link to the belt you need and to a manual you can view:
Rainbow Replacement Belts and Manual
Nov 27, 2009 | Rainbow E series Canister Wet/Dry Vacuum
Vacuum won't pick up any dirt - there's no roller marks when vacuuming carpet. Roller does turn and filters are clean.
When you turn the roller, you should feel some resistance from the belt. Remove the base blate that surrounds the beater bar. Check the belt. Take care in removing the beater bar, so you can get it back in the same way it comes out. Clean the beater bar while you have the bottom open. If you remove the beater bar to replace the belt, take the time to inspect the cavity behind the beater bar where the vacuum picks up. That is where vacuums usually stop up. Reassemble the vacuum. If necessary, slip the belt over the motor shaft and then slide the roller undre the belt. Install the beater bar back in the sockets and replace the base plate.
Best regards,
Aug 12, 2009 | Dyson DC14 Bagless Upright Cyclonic Vacuum
With the vacuum unplugged, turn the machine beater bar side up. Locate the clips or screws that hold the plate over the beater bar and remove the plate. The beater bar sits in sockets just inside. Be careful in removing it; take your time and note how it comes out...this will make reassembly easier. Clean the debris while you have tha bar off and remove any debris thet you see in the vacuum hose area behind the bar....The new belt slips over the motor shaft behind the beater bar (further up in the cavity behind the b/b), then you slip it back onto the beater bar as you place the bar back nto the sockets. Test your work by revolving the bar a bit to make sure that everything is back in place. Replace the plate.
Jul 12, 2009 | Dirt Devil M088910 Swivel Glide Vision...
Power bar makes loud groweling sound when turning?
Ours has been doing the same thing...the beater bar end plates, black thins, and the little groove area they go into are worn of the front and rear surfaces. You could buy a new beater bar but the wear on the housing would require quite a bit of work to replace that hole piece.
You will also notice that the belt is loose due to this wear.
Solution....duct tape to the rescue!
I took out the beater bar and took a strip of duct tape about 1-1½ inches long and folded that over to be a long narrow pad that fits in the groove that the beater bars end plate slides into...the groove to the rear of the beater bar.
Then I took a piece of duct tape and taped the little pad/shim I made to the rear edge of the beater bar so the pad will be in the groove when the bar is installed.
Put the bar back in carefully and no more noise and the belt is now tight again.
The fact that these 2 parts wear on each other and this affects the tension of the belt is what causes the noise...the sloppy belt will get so bad it will start jumping over the teeth and soon after it will break.
My wife was impressed...hope it works for you too...
Would make sense to make a more permanent solution but I just did this a couple days ago and we have vacuum the whole 2500 sq. ft. house with no extra noise...I have time to figure out better...maybe a harder plastic cut to fit in there...
Apr 25, 2009 | Dyson DC17 Animal Bagless Upright Cyclonic...
Dyson vacuum cleaner-brush bar is frozen
Hi If your Dyson has a brush protection design - i.e. roller bar on the top of the hood on the left hand side then the DYson can't be repaired by you- serviceman or professional care can replace it.
However if the Dyson doesn't have the roller bar on top of the hood, flip the machine over so that the beater brush is facing upwards, locate three/four screw heads that can be undone with a coin and remove the sole plate assembly. This should give you a clean view of the brush bar, drive belt and dirt channel. Ensure everything is clean espcially if the brush bar has lots of hair or threads tightly corded around. Then locate the drive belt and check to see if it has snapped. Grasp the beater bar gently upwards and the belt and brush can then be removed. Fit a new belt on carefully and check the tension as it will be tight.
Apr 05, 2009 | Dyson DC14 All floors Bagless Upright...
Bissell 6594 PowerForce Bagless Upright Vacuum Logo
281 people viewed this question
Top Bissell Vacuums Experts
Jim Thurston
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
