Question about Sanyo Televison & Video
Location of dp50710 tv fuses and capacitors - Sanyo Televison & Video
2 Suggested Answers
SOURCE: Sanyo DP50710 50'' plasma TV turns on power light then turns off/ on on its own. No picture. After checking all fuses and capacitors, we installed rand new power supply board. Still the sa
The set will need to be professionally diagnosed. There could be a # of things causing your problem. Playing the guessing game can get quite expensive.
Posted on Sep 24, 2012
Where are the fuses located?
Their location is usually by or on the power supply board. If they pop again after replacement you have a serious short situation - check the PS for burnt resistors, diodes, faulty capacitors.
Aug 24, 2015 | Sanyo Dp55441 TV
It will not come on
If the light comes on but the screen stays black it probably needs new capacitors, if there is no light try fuse and other socket.
Nov 07, 2013 | Apex Digital LD4088 LCD TV
Sanyo 50" Plasma DP50710 Remote will not work.
Try to synchronize the remote control with an other code to your TV brand.
Jan 23, 2013 | Sanyo Televison & Video
Sep 23, 2012 | Sanyo Televison & Video
My Sanyo tv Dp50710 will not turn on the green light will come on for a few seconds an then it shuts off.Someone help
Hello kewiluv03,
Welcome, and thank you for using FixYa!
To answer your question: Your issue is with the power supply board within your TV. This type of failure will have to be examined by someone with Electronics Repair training.
I would typically begin by examining the fuse(s) in the power supply area. If the fuse(s) is intact, then I would examine all of the capacitors on the power supply circuit. Capacitors are cheaper to replace than the power supply board is. Finally, if I cannot see bad capacitors, or fuses, I would replace the entire power supply board. This is a last result, but it is easier than trying to track down the 5V low and 5V high transistors these days.
Have a great day!
Sep 29, 2011 | Sanyo Televison & Video
Fuse location for fan motor/lights??
Unplug microwave, remove the top cover "several screws" fuse location under keypad and near the high voltage capacitor "silver and rectangle in shape" fuse is a ceramic type, must be replaced with identical fuse and rating, and don't forget to discharge capacitor with "long handle screwdriver"
Feb 06, 2011 | Frigidaire GLMV168K Microwave Oven
32 LCD tv pic went out suddenly, sound works, fuse is good, signal is good to tv
You have bad capacitors in this unit. Replace capacitor (location) 2074 which is a 25 volt 2200Mf at 105 degrees. Change capacitor (location) 2081 which is a 35 volt 1200 Mf at 105 degrees. Change capacitor (location) 2066 which is a 16 volt 10Mf at 105 degrees. And to complete final repairs change out surface mount capacitors (locations) 2H08 and 2H09. The part numbers for these two identical surface mount caps is..223886975478. And one should consider changing the color crystal, also a surface mount. The number for this crystal is 823827736071. If unable to do this yourself, find a TV tech and show them this repair instruction. Good luck and show a few hands of support.
Dec 25, 2010 | Philips 32MF231D Television
Televison & Video Logo
52 people viewed this question
Top Sanyo Televison & Video Experts
 Grubhead
Grubhead
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
