Question about Gateway 505GR PC Desktop
Replacing a mother board for gateway 506gr
I replaced my mother board but there is no power
    Genius:
  • Gateway Master
  • 1,274 Answers
Make sure you install both connectors (8 pin and 4 pin) also make sure you didn't accidently flip the on/off switch on the actual power supply to off while you were working on it.
Posted on Feb 12, 2012
SOURCE: replacing a mother board for a gateway 505gr
First off find out what form factor the tower will support. most new mob will tell you what form factor they are.
Posted on Dec 31, 2007
  • 4 Answers
SOURCE: I replacement fan
They sell some things that you can put on the fan so it can run quietly without making any noise.
Posted on Oct 28, 2008
ericbrunswic
  • 88 Answers
SOURCE: signal to monitor goes in and out, mostly out
Hopefully, it is just the on board video that has gone bad, and not the motherboard. When you install a video card on a PC, that has on board or integrated video, you will need to access the BIOS screen on start up and disable the on board video. That way the video signal will come from the new video card and not the on board video.
I hope this helps,
Eric
Posted on Jan 18, 2009
byteguy
  • 2229 Answers
SOURCE: my gateway 503gr will not
This could have a bad power supply (in this case I would try a new one just in case).
All other things being normal, I would guess a bad motherboard.
The best thing to do is disconnect everything but the CPU and memory and try to start it.
If it starts, then start connecting stuff until it doesn't start--this will tell you what is bad.
Posted on Apr 13, 2011
SOURCE: gateway 825gm wont tun on.
Make sure the small cable from the switch to the mother board hasn't come loose. It comes loose fairly easily when reinstalling the cooling fan plenum. Its happened to me twice. Its even possible to plug it in the wrong place. Doesn't hurt to double check.
Posted on Apr 22, 2011
Pc won't power up replaced power supply. Green light illuminated on mother board and ps
remove all components like hard drive, cd/dvd ,memory and video card.
start system if you get beeps then the motherboard is responding.
add the memory and start system again. If it starts add hard drive.
What we are doing is testing to see which hardware here has failed.
Jan 13, 2010 | Gateway 506GR PC Desktop
Gateway 506GR Front Panel
did you replace the motherboard? if you did with a non gateway replacement there is a good chance you will have to re-wire the buttons.
if not, just look for an oddly shaped "gateway" plug that plugs into the receiving socket on the MB. If you dont own a multi meter and soldering iron now is a good time to invest. also get some wire strippers and cutters.
Aug 24, 2009 | Gateway 506GR PC Desktop
Troubleshooting
frist change smps and start your computer then you came to no smps problem 2/ you may be done mistake look information on mother bord where which wire can be added. and also u can get information from wire ledwhere to pluge,3 look your cpu fan is working properly? some time bad fan creat this type problem.
Jun 19, 2009 | Gateway 506GR PC Desktop
I replacement fan
Oct 28, 2008 | Gateway 506GR PC Desktop
Gateway 505gr motherboard replacement
not powering up does not mean the mother board is bad , the power supply going bad is more likely to be the problem . But your tower is considered to be a mini tower ive got the same one that I replaced the mother board on . dont mess up and get the wrong size board , it will not fit!
Jul 17, 2008 | Gateway 505GR PC Desktop
Computer wont start
replace your bios battery
Jun 14, 2008 | Gateway 506GR PC Desktop
No signal, Gateway 506GR
Start by disconnecting the new DVD writer and verify all power supply connections are not shorted.
May 01, 2008 | Gateway 506GR PC Desktop
No Sound
Install the sound driver, (which can be found in the mother board's companion CD)
make sure in the "volume control" window of control panel that the mic volume and other volume indicators are full before trying to record.
Apr 12, 2008 | Gateway 506GR PC Desktop
Gateway 505GR PC Desktop Logo
64 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Matthew Spark
Matthew Spark
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
