Question about Gateway 505GR PC Desktop
Replacing a mother board for gateway 506gr
Wiring schematic
SOURCE: replacing a mother board for a gateway 505gr
First off find out what form factor the tower will support. most new mob will tell you what form factor they are.
Posted on Dec 31, 2007
  • 4 Answers
SOURCE: I replacement fan
They sell some things that you can put on the fan so it can run quietly without making any noise.
Posted on Oct 28, 2008
Sutibun
  • 186 Answers
SOURCE: gateway 506GR motherboard configuration
Item Description Item Description A Rear Panel I/O Ports M Front Chassis Fan Connector B Auxiliary 12-V ATX Connector N Serial ATA Interfaces C CPU Socket O Front Panel Header D CPU Fan Header P Front USB Connector E Memory Slots Q Front USB Connector F Standby Power Indicator LED R Front Panel IEEE-1394a Connectors G Floppy Disk Drive Connector S Speaker H ATX Power Connector T PCI Express x1 Connector I Parallel ATA IDE Interface U Front Panel Audio Connector J Battery V PCI Slots K Intrusion Switch Header W Rear Chassis Fan Connector L BIOS Configuration Jumper
Posted on Aug 21, 2009
  • 1738 Answers
SOURCE: wires off graphics card into mother board?
The computer won't boot if there is no graphic present. If you did hook it up right and there is a fan on the graphics card, it should be turning.
Posted on Oct 17, 2009
Testimonial: "Yes this was helpful I wouldnt have thought to look at the fan since it was on the down side."
joelwilcox
  • 1274 Answers
SOURCE: replacing a mother board for gateway 506gr
make sure you install both connectors (8 pin and 4 pin) also make sure you didn't accidently flip the on/off switch on the actual power supply to off while you were working on it.
If you need further help, reach me via phone at https://www.6ya.com/expert/joel_63c670a84e9f6a97
Posted on Feb 12, 2012
Feb 11, 2012 | Gateway 505GR PC Desktop
I nee the manual for wiring diagram for mother
Go to the link below pick your product and download manual or motherboard diagram also called schematic
http://support.gateway.com/support/supinfo/index.asp?cmpid=topnav
If this helps you leave feedback please rate the help
Jan 30, 2010 | Gateway GT5654 Desktop PC
Pc won't power up replaced power supply. Green light illuminated on mother board and ps
remove all components like hard drive, cd/dvd ,memory and video card.
start system if you get beeps then the motherboard is responding.
add the memory and start system again. If it starts add hard drive.
What we are doing is testing to see which hardware here has failed.
Jan 13, 2010 | Gateway 506GR PC Desktop
Is there a video controller driver for the 506GR model when running windows 7? the gateway web site does not support.
The 506GR has an old Intel (Augsburg) motherboard, and onboard video. The hardware is from 2005, and has no support for Windows 7. Unfortunately, you will need to upgrade.
Jan 05, 2010 | Gateway 506GR PC Desktop
Gateway 506GR Front Panel
did you replace the motherboard? if you did with a non gateway replacement there is a good chance you will have to re-wire the buttons.
if not, just look for an oddly shaped "gateway" plug that plugs into the receiving socket on the MB. If you dont own a multi meter and soldering iron now is a good time to invest. also get some wire strippers and cutters.
Aug 24, 2009 | Gateway 506GR PC Desktop
Troubleshooting
frist change smps and start your computer then you came to no smps problem 2/ you may be done mistake look information on mother bord where which wire can be added. and also u can get information from wire ledwhere to pluge,3 look your cpu fan is working properly? some time bad fan creat this type problem.
Jun 19, 2009 | Gateway 506GR PC Desktop
506GR motherboard battery
looks like a large watch battery, it will either be in a holder flat on the board or standing sideways, some are soldered to the board if it dont look like it will pop out it is soldered and dont break anything trying to remove it.
Jul 01, 2008 | Gateway 506GR PC Desktop
Computer wont start
replace your bios battery
Jun 14, 2008 | Gateway 506GR PC Desktop
No Sound
Install the sound driver, (which can be found in the mother board's companion CD)
make sure in the "volume control" window of control panel that the mic volume and other volume indicators are full before trying to record.
Apr 12, 2008 | Gateway 506GR PC Desktop
Gateway 505GR PC Desktop Logo
125 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
