Question about Frigidaire Washing Machines
Front load frigidaire model ftf2140fs1 door won't lock
Door won't lock
  • 641 Answers
SOURCE: Frigidaire Front Load Door Lock Broken and Noisy FWT449GF
Its looks like a lid switch issue. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washer to get to the switch. If it's defective, you need to replace it. Good luck!
Posted on Sep 08, 2007
  • 121 Answers
SOURCE: ge front loading washer door won't unlock
I had the same problem. I didn't want to spend the money or go to the trouble of replacing the whole latch assembly with the GE latch repair kit.
I found that the plastic latch piece screwed to the door had broken and one of the two latch "fingers" was stuck in one of the latch openings on the washer. I fixed the problem by removing the broken part from the washer and drilling and countersinking very small holes (1/16" I think) in the plastic latch piece on either side of the "latch finger". I then put the broken off piece back in place and drillled pilot holes for #4 sheet metal screws in the door where the latch is located. The door liner is plastic and I think I used a 1/32 inch drill bit. I reattached the broken latch piece with two 1/2 inch stainles steel #4 flat head phillips screws from Home Depot. The screws hold the broken latch piece in place as orinilally positioned.
The repair is working fine and the door now latches like it did before the latch part broke
Or: http://www.appliancepartspros.com/part_details.aspx?image=0&part_id=2045520&pn_=WH10X10002 Same part cost $200 direct from GE
Read more: http://forum.appliancepartspros.com/washer-repair/8379-ge-washer-front-loader-door-wont-stay-latched.html#ixzz1LmNUKfTN
Posted on May 08, 2011
  • 6277 Answers
SOURCE: My affinity front load washing machine stopped
There is likely to be a problem with either the door solenoid/lock or the 'door closed' sensor. Sorry but both require a service engineer's attention I suggest ;-0(
If this has assisted and/or clarified the situation for you please consider a 4 thumbs up on our rating.
Thanks and good luck!
John C
Posted on Jun 06, 2011
Jahn27
  • 1554 Answers
SOURCE: Front load washer - GE
With the door lock light turned on without the door being locked is an obvious indication that the door lock/switch assembly is in bad shape. The lock broken is stuck closed or the door lock switch contact are stuck closed or has welded together. Check for any of these conditions and address it accordingly. Gently flick the door lock/switch assembly repeatedly or tap it against a hard surface to possibly release any stuck component. Replace the door lock/switch assembly if the problem is not addressed.
The machine will not fill by not activating the water valve solenoids unless the door switch is activated the door strike and the door lock switch is activated as indicated by turned on of the door lock light. This is to prevent flooding your floor should someone attempts opening the door. Click on the link below for the detailed instructions in replacing the door lock/switch assembly. The instruction is for a Frigidaire front load washer but they are basically the same as they both use the same door lock/switch assembly.
Door Lock/Switch Replacement
You don't have to accept or reject this post in order to add comment or information. But accepting the solution should you find it helpful and/or informative will not stop you from posting comments or additional information. You can still communicate with the expert should you need further advice regarding the issue stated herein.
Posted on Jul 04, 2011
  • 6277 Answers
SOURCE: I have a Frigidaire washer model ftf2140fs1, the
There is likely to be a problem with either the door solenoid/lock or the 'door closed' sensor requiring a service engineer's attention I suggest ;-0(
John C
Posted on Jul 09, 2011
Why won't my door lock?
If the door lock will not engage, then the door lock will need to be replaced. Here is the lock to order.
Nov 18, 2012 | Frigidaire ATF6000ES Front Load Washer
Affinity frigidare front load washer won't start. It beeps with message flashing (DR)
Hello zabbster - Typically the DR or DO error code indicates that the door switch is not closed. Make sure that the door lock is completely closed. If the door is closed, make sure the door latch is not broken. If the latch is broken, you may possibly need to replace the door lock switch.
Sep 25, 2012 | Frigidaire Affinity ATF7000E Front Load...
Frigidaire front load washer model LTF7000ES0 got out of balance with a heavy pillow and we had to stop it. Now it won't do anything. Everytime I start it, the door light comes on as usual, then a
Check to see if the door sags at all and doesn't line up correctly with the door latch. Then check to see if the drum wobbles when you rotate it yourself when not in use.
Jul 30, 2012 | Frigidaire ATF6000ES Front Load Washer
I have a Frigidaire Front Load washer Model#ATF6000FS2 washer . It will not start and seems to be experiencing a problem with the door. There is 'DOOR LOCK' light that does not turn on and th
Sounds like the door is not latching correctly. Check the door for any sagging problems and then check the door latch itself for any damages, cracks, or issues with the door itself connecting to it.
Jul 21, 2012 | Frigidaire ATF6000ES Front Load Washer
I have a Frigidaire washer model ftf2140fs1, the door doesn't stay closed and if it's closed it's not washing but all the buttons light up but the door lock light doesn't turn on. please...
John C
Jul 09, 2011 | Frigidaire ATF6000ES Front Load Washer
My affinity front load washing machine stopped mid-cycle. The door won't lock so it won't run and it has water sitting in it. Is there anything we can try before calling a repair man?
John C
Jun 06, 2011 | Frigidaire ATF6000ES Front Load Washer
Fridgaire FTF530fs3 door lock buzzing and not locking, washer won't start
fit a new door lock as if it doesnt engage it wont allow the machine to start the washing cycle
May 31, 2011 | Frigidaire FTF530FS Front Load Washer
Frigidare Model # FTF2140FS1 problems with spin cycle
not a very sturdy pedestal, front loaders need concret solid base
Mar 13, 2009 | Frigidaire ATF6000ES Front Load Washer
Washing Machines Logo
Top Frigidaire Washing Machines Experts
Gerry Harvey
Gerry Harvey
Charles T Nevin
Charles T Nevin
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
