Question about Toshiba Satellite A105 Notebook
I can not get my computer up.
The toshiba logo comes across and I am trying to use the recovery disk, however I followed the direction and it gives me an error has occured, error 0800000000 Partition creation failed. What is wrong?
  • Anonymous Dec 17, 2008
    When I power up my Toshiba laptop, I hear a beeping that doesn't stop. When I tried to reformate with the recovery disks that are provided by Toshiba, I get a "Partition Creation failed" error. Error 0800000000:
    I purchased a new hard drive about 3 months ago, so I don't think that this is the problem.
  • 108 Answers
Partition creation is referring to the hard drive.
Does the laptop make any different noises, clicking sounds...
Do to my experience with laptops over the years. Hard drives are the 1st to go.
I would say that your hard has gone bad and the recovery CD cannot install to it. You can get a replacement Hard drive from a local computer store for around 50 bucks. Of course it depends on the size you need.
G'luck
Posted on Oct 24, 2008
Restore factory settings
Many Toshiba laptops come with the factory software recovery image stored in a special (hidden) area on the hard disk. From this special hidden system recovery image, you can restore your computer to its factory-fresh software condition by following these steps:
  1. Make sure the computer is turned off ("Shut-down" from the Windows Start menu)
  2. Remove any peripherals such an external mouse, keyboard, monitor, USB flash drive etc.
  3. Make sure the AC Adapter is plugged in and working.
  4. Press and hold down the 0 (zero) key on the keyboard while powering on the computer. Release it when the recovery warning screen appears.
  5. If the recovery process offers a choice of Operating Systems, select the appropriate one for you.
  6. A warning screen appears, stating that when the recovery is executed all data will be deleted and rewritten.
  7. Click Yes to continue.
  8. When the Toshiba Recovery Wizard opens select "Recovery of Factory Software" or the appropriate option for your needs.
  9. Continue to follow the directions restarting as necessary.
For laptops equipped with Windows 8, "Reset" returns your computer to its out-of-box, factory default conditions (removes your personal files and apps as well reset all settings to defaults) similar to a "System Recovery."
Please note that the process may vary slightly from machine to machine, that you may be asked to insert disks (multi-disk packages) and that the process may take one to two hours to complete. The recovery process will restart your computer several times.
As you use the recovery process you will have several options. One of these may be to create a custom size partition. Follow the directions on screen for this and other options as prompted. When in doubt, it's usually best to accept the default, or pre-selected option.
Nov 30, 2013 | Toshiba Satellite A45-S150 Notebook
How can I restore my laptop to original settings?
If you machine didn't come with recovery disks you need to make them. In your user guide (http://www.helpowl.com/manuals/Toshiba/SatelliteL650/167019) it gives the steps. Normally you should just have to go into windows back up/restore and follow directions.
Also on that site you can download your manual free if you don't have it already.
Some systems are setup so that when your computer starts to boot you press F10 and it will go into a recovery partition.
Good luck
Dec 31, 2012 | Toshiba Satellite L650-BT2N23 Notebook
Toshiba qosmo g10
Information:
Please note that the process may vary slightly from machine to machine, that you may be asked to insert disks (multi-disk packages) and that the process may take one to two hours to complete. The recovery process will require you to restart your computer several times.
Aug 27, 2012 | Toshiba Computers & Internet
How do you go about to format a toshiba l650 and reinstall windows 7
Hi! If you have the Windows 7 disc just insert it restart the computer. It will boot directly from the disc. Then follow the step by step instructions here.
If you don't have the Windows 7 disc, you have two ways to reformat your Toshiba computer.
Using Toshiba HDD Recovery Utility from the recovery partition
In case of a hard disk drive failure, you may be able to restore the drive to the factory default state using the on-disk Toshiba HDD Recovery Utility (in a special partition on the hard disk drive).
You can select restoring the entire hard disk drive to the factory default state, or restoring only the C: drive -- without affecting other partitions (for example, a D: drive) -- or changing the size allocated to your C: drive, and then restore it.
To recover your hard disk drive from a system failure using the utilities stored on your computers HDD, follow these steps:
  1. If the computer is running, shut it down -- by clicking Start, Shut Down, and again Shut Down.
  2. Press and hold the 0 (zero) key on your keyboard and then press the computers power switch. When the computer turns on, the Toshiba HDD Recovery Utility screen will appear, presenting three options:
Sample TOSHIBA HDD Recovery Utility screen
Restore Original Factory Image (Recommended)
CAUTION:
Restoring a hard disk drive to its factory default state deletes all partitions on the hard disk drive and all data stored on those partitions. All of your files and information will be lost! Be sure to back up all important files first.
  1. Press 1 to restore your hard disk drive to its original factory default state. A confirmation message will appear, indicating that all data will be overwritten and lost during the restore process. Be sure to back up all important files before proceeding.
  2. Click Yes to begin the recovery. A message will appear once the operation is finished, indicating the HDD has been restored.
  3. Press any key to restart the computer.
* The options 2 & 3 are for advanced users.
Hard Disk Drive Recovery using Recovery CDs or DVDs
You may also wish to to run the Toshiba HDD Recovery Utility from Recovery CDs or DVDs that you have created.
Insert the first Recovery CD or DVD into your CD/DVD drive, and turn on the computer. Once the computer is running, the TOSHIBA HDD Recovery Utility screen will appear, presenting the same three options above. Again Press 1 to
restore your hard disk drive to its original factory default state. Click Yes to begin the recovery. Press any key to restart the computer.
Installing Drivers and Applications
The TOSHIBA Application Installer allows you to reinstall the drivers and applications that were originally bundled with your computer.
To reinstall drivers and applications:
  1. Double-click the "Toshiba Application Installer" icon on the Windows desktop. This utility may also be launched by clicking Start -->All Programs --> Hard Disk Recovery Utilities.
  2. Click "Next".
  3. Click the item(s) you wish to install. To select multiple items, hold down the Ctrl key as you click your selections.
  4. Click "Install".
  5. Follow the on-screen prompts to complete the installation process.
Hope this helps.
Jun 19, 2011 | Toshiba Computers & Internet
Hi...my sony vaio is always restart then its hard to start again. what can i do? tnx.
try to reinstall your os.. if you have a recovery disk on you laptop (to know if you have a recovery disk, right click on my computer icon, click properties, click system protection, in a protection setting see recovery), follow these step
turn on your laptop, when the vaio logo appears press f10 it will automatically direct you to reinstall your os, follow the next instruction.
but if you didn't have a recovery disk, you need to reinstall it with a genuine windows disk, restart your laptop, insert a windows disk, press f11, then follwo the instruction..
hope it will help you
May 17, 2011 | Sony Computers & Internet
I need to know how to restore the factory settings on my toshiba satellite a85 without a cd
If you computer didn't come with a recovery disk, then its probraly installed on a partition drive. You can see if you have this option when first powering up your computer, In the postscreen usually with the toshiba logo, there should be a F key or a key input to press prompting you for recovery, setup etc. Press the button that prompts you for recovery. Then follow directions. If you dont see one, which lately toshiba new laptop, they don't come with a recoery partition or cd and you need to make one yourself using the toshiba recovery managment provide in the operating system. If you see this program or a program similar, then you must make your own recovery cd disc, after making it.... then you can use it.
Jan 23, 2011 | Computers & Internet
Reset toshiba satellite A100-TA2 to factory settings
try this link, at appears as if u can download the disks here
http://www.user-guides.co.uk/toshiba/toshibarecovery/toshiba.asp?keywords=toshiba+satellite+a100+ta2+recovery+discs+downloads&recor=121
Mar 18, 2010 | Toshiba Satellite A100-S8111TD Notebook
Recently crashed. reloaded with original recovery
After you restore your computer, you must also reinstall the drivers for things like your wireless receiver. This is found on the Drivers disk, also gotten with your computer. Follow directions to recover all drivers are found on the disk.
Dec 13, 2009 | Toshiba Satellite A60 Notebook
Need recovery and/or setup disk
You can try calling Toshiba direct and hope the have them available. (800) 457-7777. If not you'll need to buy a copy of Windows and install all the drivers from Toshiba's web site.
May 31, 2008 | Toshiba Satellite A15-S157 Notebook
Restore Problem
Press F2 to check BIOS. Use bootable windows and recovery disk.
May 15, 2008 | Toshiba A15-S1292 Notebook
Toshiba Satellite A105 Notebook Logo
400 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
