Ricoh mp5000 sc672 error
Sc672
2 Suggested Answers
  • 903 Answers
SOURCE: We've a Ricoh MP3500 that is displaying an error
sc672 is a communication error between the controller board and some other component. Did you switch the machine off using the orange power switch on the lower left side, or just the power button on the operation panel?
With the power completely off and the machine unplugged, pull the controller board out by removing the two screws holding it in on the rear left side of the machine. (It should slide right out the side.) Check all of the connections on the board and make sure everything is sitting securely, then reinstall the controller board.
Worst case scenario, you might have a bad memory stick, bad controller board, or another bad circuit board, but more than likely there is a connector somewhere that just needs to be set securely. You can also remove the operation panel (two screws on the top of the panel and possibly two screws underneath it as well) and check the harness that connects the op panel board to the machine.
Posted on Jul 17, 2010
Testimonial: "Thanks for the help...looks like we've got to replace the controller board :("
My ricoh aficio MP3351 machine has a error problem SC672, plz kindly tell me what i can do???
SC672 occured when controller-to-operation panel communication error at startup After powering on the machine, the communication circuit between the controller and the operation panel is not opened, or communication with controller is interrupted after a normal startup.
.Controller stalled
.Controller board installed
incorrectly
.Controller board defective
.Operation panel connector
loose or defective
Make sure that the MBU is seated correctly. If not, SC672 occurs look at the picture to see what im talking about.
Sep 29, 2017 | Ricoh Office Equipment & Supplies
My copier machine comes up with functional error code sc672. can anyone help
That error code appears to indicate 'Op panel to controller problem' see here http://multifunctionalcopier.blogspot.co.uk/2012/06/ricoh-error-code-list.html
Sep 05, 2015 | Ricoh Richo KR-5 with 35-70mm f3.5-4.5...
Ricoh mp5000 error code sc220?
1) The Copy Data Security Unit card not installed
2) The Copy Data Security Unit card is installed, but it is not the correct type for the machine.
Oct 02, 2013 | Ricoh MP5000
Sc819 trouble/error in ricoh aficio mp5000. any help? thank u
SC819: software error. upgrade controller to the latest version. Faulty RAM and ROM DIMMs also cause this problem.
Ricoh Errors
Jun 02, 2011 | Ricoh Office Equipment & Supplies
My 2022 shows an error code SC320 and also a error code SC672 what could be the problem
CS320 polygon motor (laser), you will need to replace it, it is not expensive!
CS672 control communication on start up, to many options, from circuit board to bad connection, you will need a tech for this.
Nov 23, 2010 | Ricoh Aficio 2022 All-In-One Laser Printer
Ricoh 1035
It says communication error to control panel at station.
Turn the copier off, wait 30 seconds, and turn it back on again.
It should go away. If it doesn't a technician needs to come out and look at the problem.
Jul 31, 2008 | Ricoh Aficio 1035 Copier
1,149 people viewed this question
jasbo
jasbo
