Question about Sony Jetflash 128 MB MP3 Player
My mp3 player won't start up
My song mp3 player does not show the music files in it. any time i put it on it shows starting but jams there.pls tell me what to do.
SOURCE: mp3 player has no music
The player has a Recorder Mode and an MP3 mode. The player defaults to recorder mode for some reason, this is probably why you cannot see the songs. To switch to MP3 mode you have to hold down the MODE button for more than 2 seconds. Then you should be able to see the songs.
Posted on May 24, 2007
  • 242 Answers
I have posted a solution for this problem here.
It seems you are not the only one with this problem.
If you have questions about it, or encounter other problems, feel free to post a comment on this question.
Posted on May 21, 2008
SOURCE: help me with my sony nwwm mem aad2 mp3 player.......
i have music on my sony NWWM MEM AAD2 and it says no data!
but when i plug it into my laptop and search my computer the files
are do i get the drivers into the mp3 so i can hear tha
Posted on Nov 20, 2008
SOURCE: sony NW-S205F mp3 player " NO DATABASE" don't play music files
tengo problemas que no puedo ver las musicas que hay en mi mp3 donde me sale NO DATA q pudiera hacer para poder recuperar los datos
Posted on Jan 27, 2009
SOURCE: I have a Sony NW-E005F
yaah i had solution for this
u shouldnt format as regular pendrive
u should format throu mp3 play er only
u r having an option home button,press dat button
go to menu option
in dat goto advanced menu
in dat go to initialize
u will have an option format use dat option n format ur player
then u will apper a message COMPLETE
Posted on May 25, 2009
  • 496 Answers
SOURCE: HELP ME PLEASE with my "sony walkman NWZ-B105F MP3 PLAYER."
make sure your downloading it to the right folder on the mp3 player its usualy the music folder or you can try and use windows media player here are some instructions for that option.
--**Windows Media Player**--
If you have a large playlist to transfer, you may prefer to do it from your media player, such as Windows Media Player. Once your MP3 player is connected to the computer, open Windows Media Player. Click on the "Sync Music" tab. Drag songs that you want from your Windows Media Library over to the "Sync Music" column to create a playlist. Click the "Begin Sync" tab at the bottom once you have all of the songs on your playlist. This action will sync all of the songs to your MP3 player with one click. Disconnect your device once songs have been transferred by clicking on the "Safely Remove Hardware" icon in the bottom-right side of the desktop tray.
Posted on Oct 07, 2009
0 characters
1 Points
Comment mettre de la musique sur mp3 gb
google translated
how to put music on mp3 gb
Install Windows Media Player if the program is not on the computer.
Out there, it's only you and your music. No time for games. Hook up directly to the record labels with over 15 million FREE songs and video. 100% legal. 100% safe.
Put music into your Windows Music Player library. Click "File" in the top left of the program. Highlight and select "Add to Library." A window will appear.
Select the "Add" button.
Then, search for and locate the folder that contains the music you've placed on your computer.
Choose this folder and then click "OK." Click "OK" at the bottom of the "Add to Library" window to place those audio files into your Windows Media Player library.
Click "Sync" at the top of the program.
Plug the MP3 player into the computer.
Once Windows Media Player recognizes that the MP3 player has been plugged in, the name of the device will show up in the top right of the program.
Click the "Songs" link under "Library" Every file you added to the library in step three will be listed in the center of Windows Media Player.
Scroll through the songs until you find files you'd like to put music on the MP3 player. Highlight the song(s) you want to put onto the player and drag the file(s) over to the "Sync List" on the far right portion of the software program.
Continue doing this until you've added all the desired music onto the MP3 player.
Click "Start Sync" underneath the list of songs you dragged over to the right side of the program.
The music will be added to the MP3 player.
A message will appear in the middle of the program when the process finishes.
You can then disconnect your MP3 player.
hope this helps
Sep 22, 2012 | Kobian Hip Street Digital Media Player
How do i download music to my mp3
MP3 players can only play music files in mp3 file format. You can download mp3 music files onto your computer and then copy them to your MP3 player.
For CD disks you need to convert your CDs to mp3 music files onto yourcomputer or download them from the Internet and then copy them to your MP3player.
You can do this using Windows Media player and Rip the CDs - Media Player willcreate a MP3 music file for each music track.
Click on this link for instruction on converting music files to mp3 file format:-
Jul 02, 2011 | Sylvania MP3 & Digital Media Players
If we add songs to mp 3 player it won`t show songs when it on
MP3 players can only play music files that have been converted to mp3 file format. For instructions on converting music file, please click on this link and follow my instructions :-
Nov 08, 2010 | Sony NW-E405 MP3 Player
Deleting songs.
Your DB might be corrupt. Folow the delete procedure one more time:
Delete Music Files
1) Connect your Sansa to the computer.
2) Select Open device to view files using Windows Explorer on initial
3) Select the place where you want to delete music files from
4) Highlight and delete the music file/s or folder from My Computer\Sansa
folder. (You can also select from a variety of music
software programs to transfer/synchronize your files).
If that fails, go ahead and update the firmware - it will delete everything, and allow you to start over from scratch among other things.
-Tha Mp3 Doctor
Feb 16, 2009 | SanDisk Sansa E280 MP3 Player
I've downloaded songs but they don't show up on my player
Each mp3 player can only play songs in certain formats. A Philips GoGear, for instance, can't read iTunes format. Some players cannot read DRM-encrypted WMA files, which is what most music services use. When you load a song in the wrong format to an mp3 player, the song appears to transfer, but the mp3 player won't actually play it. The best workaround for this problem is to only load songs that are in true mp3 format - they are accepted by 99% of digital audio players. If you give us your manufacvturer/model #, and music service name, we can tell you exactly which formats your player plays.
-Tha Mp3 Doctor
Jan 02, 2009 | MP3 & Digital Media Players
Need help deleting songs from my Sony MP3 player
Try reflashing the firmware for your device you can find the latest firmware and flashing utilities from the manufacturer?s website. Make sure that you back your music up first because when you do this you are setting it back to factory settings.
Dec 02, 2008 | Sony Network Walkman NW-E005 MP3 Player
The songs that you are syncing may not be in the right format for this particular Mp3 player. Where did you get the songs?
Q: What type of files can I play?
A: Mp3 and WMA files. DRM protected WMA files, such as those purchased from many online music services, must be copied to the player via Windows Media Player or the music management software compatible with your online music store.
The player does not support AAC file playback.
(i.e: iTunes will not work)
May 23, 2008 | Siren Edge MP3 Player
Corrupted files
all i can say is try to format the mp3
Aug 06, 2007 | SanDisk Sansa e250 MP3 Player
Many times, MP3 players will play music from an "Audio" folder. Try naming the folder "Audio".
Jun 12, 2007 | Sony NW-E103 MP3 Player
Song Names show up incorrectly on ILO Mp3 player. Wrong format?
The funny~.mp3 names are usually because the title field is not filled in in the mp3 property tags, so it uses the DOS version of the filename for the title. Under windows, right click the song and select properties->summary->advanced, and make sure that the title field under "description" has what you want in it. I don't think even the makers of Ilo know how it organizes the files.
Apr 17, 2007 | iLO (2 GB) MP3 Player
Sony Jetflash 128 MB MP3 Player Logo
15 people viewed this question
Top Sony MP3 & Digital Media Players Experts
 Mike M
Mike M
Lawrence Oravetz
Are you a Sony MP3 and Digital Media Player Expert? Answer questions, earn points and help others
