Question about GE Profile CustomStyle PSC23MGSWW 36" 22.7 Cu. Ft. Side-by-Side Refrigerator w/ CustomStyle Configur...
Ge profile PSS23MGTA WW temprature too high
My GE profile side-by-side frige tempratue setting is 37 and 0 for the freezer but the actual temprature is 43 and 25 degrees respectively.
SOURCE: Profile refrigerator section not cooling
We are not sure what precipitated the temperature swing up; however, within about an hour of emptying quite a lot of foodstuffs from top and bottom sections of the unit, I felt the cold air start to flow out of the rear vent. Within two hours, the upper section had dropped to about 50 degrees and by the next morning to 36. The freezer seemed to recoved on its own too, having risen to almost 8 degrees and then recovering to 0. Just patience and a smaller food payload?
Posted on Oct 02, 2008
Krames
  • 18 Answers
SOURCE: Freezer side cold, frige side warm
Defrost heater is open behind back wall. order new heater #wr55x10101 remove 4 screws 2 bottom, 2 top behind light shield, defrost freezer so ice is off of evap, replace heater with new one.
Posted on Nov 15, 2008
  • 531 Answers
SOURCE: Ge model PSC25MSTASS digital refrigerator setting
check for frost in the freezer back wall
Posted on Apr 01, 2009
  • 61 Answers
SOURCE: Refrigerator does not maintain 37 degrees
i have seen this problem before its the control board in the back the board is about 150 dollars and it goes every DING DING 5 years lol horrible design of the one that comes on the fridge every ge side by side has this problem  its very easy to replace but have to "ground" yourself before you touch the new control board meaning rub you hands on plumbing pipes, not pvc or copper
good luck if you got questoins let me know
Posted on Jun 08, 2009
beamerguy740
  • 65 Answers
SOURCE: The refrigerator part of the side by side is 25
Check the thermostat Knob. Turn it to off then back to c or 3 let it run for 12 hours and recheck.
Posted on Nov 04, 2009
GE fridge freezer profile
the fridge needs servicing....if you still have waranty use it.
Nov 12, 2007 | GE Profile PSI23NCR Side by Side...
My Ge side by side freezer was thawing now it
Might just be a freezer thermostat gone bad by sticking in an open position. If that's the case you will be out of control in temp settings. Hope this has helped!!BB
Dec 15, 2009 | GE Profile PSS26NGS Side by Side...
Ge armoire style condensation on freezer door
the condensation is due to a small amount of cold freezer air getting past the gasket. Warm the entire gasket up for a few minutes with a hair dryer and then close the door and keep it closed for 30 minutes. That will reshape your gasket and solve your problem.
please rate this answer as a fixya!
Mar 04, 2009 | GE Profile PSW26P Stainless Steel Side by...
Ice maker not making ice. Water disp inside frig disp water.
the line that gives water to the ice maker, every time the water comes down it lives a drip of water that turns to ice blocking the line, get some hot water and a towel and place the hot wet towel on top of the line intel it melts the ice in side the line. it happens to my frige at list once a year. if that is not the problem the valve that supplies water tho the ice maker needs replacing, it's behind the frige at the bottom, where the line coming from the house meets the frige.
Dec 10, 2008 | GE Profile PSW26P Stainless Steel Side by...
WATER DOES NOT DISPENSE, EVEN THOUGH ICEMAKER WORKS
the way you test that is by going behind the frige and taking the bottom panel and find the water connection as the line connects to the frige there is one line coming to it from the wall and 2 goin out in to the frige 1 goes to the ice maker and the other to the water at the door. disconnect one first and try getting water from the door, one of those lines is going to pas water when you do that, if no one passes water with this test replace that water valve.
Dec 09, 2008 | GE Profile 26.6 cu. ft. Side-by-Side...
Nov 13, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Ge profile side by side fridge
THIS IS CAUSED MORE COMMONLY BY A FAILURE TO THE MAIN PROCESSING BOARD NOT SENDING PWR TO THE DISPENSER RELY BOARD
May 29, 2008 | GE GSH22JSRSS Stainless Steel Side by Side...
GE Profile CustomStyle PSC23MGSWW 36" 22.7 Cu. Ft. Side-by-Side Refrigerator w/ CustomStyle Configur... Logo
47 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
Lawrence Oravetz
okcchemist
Level 1 Expert
