Question about Rowenta Professional DE871 Iron
What kind a water do you use for steam? How do you remove the removable water tank?
2 Suggested Answers
  • 3 Answers
SOURCE: how can I remove mould from the water tank of my
Same problem with my iron
Posted on Sep 22, 2011
Model gh3000 spool will not release for removal
follow this steps and fix it. God bless you
Clean an iron:
  1. Unplug the iron and make sure it is cool before cleaning.
  2. Use a toothpick or pipe cleaner to remove buildup in the steam vents, making sure the debris doesn't fall into the vents.
  3. Use a fine sewing needle to carefully clean the spray nozzle of mineral deposits.
  4. To flush sediment from a steam iron, pour 1/2 cup water and 1/2 cup vinegar into the water tank. Place the iron on a rack over a broiling pan and set the iron to steam until the tank runs dry. Repeat if necessary. Or follow the instructions for using a commercial iron cleaner.
Service the steam and spray mechanism:
  1. Unplug the iron.
  2. Use a fine sewing needle to unclog the steam valve assembly. Also, check the valve spring and replace it if it is broken or has lost tension.
  3. If the spray pump is accessible, remove it and check for leaks by placing the spray tube in water and squirting the pump. Clean or replace as needed.
Oct 09, 2013 | Irons
My stream iron generator tefal and problem some parts outstanding on base of iron , and stream can not get out , how to remove PARTS.
Clean an iron:
  1. Unplug the iron.
Clean a metal soleplate:
  1. Unplug the iron.
  2. Use a sponge and commercial soleplate cleaner or baking soda and water to remove dirt buildup on the soleplate. Rinse well with water and dry. Don't use harsh abrasives or immerse an electric iron in water.
  3. Use very fine steel wool (0000) or an emery cloth to remove scratches and burns on the soleplate, then clean the soleplate.
Oct 02, 2013 | Tefal Irons
WATER HOSE PERISH
Clean an iron:
  1. Unplug the iron.
  1. Unplug the iron.
Oct 01, 2013 | Irons
My steam cleaner was working, then when i refilled it, it didnt heat up. its a multipurpose with different attachments. could it be element gone?
Clean an iron:
  1. Unplug the iron.
  1. Unplug the iron.
Sep 30, 2013 | Conair Compact Garment Steamer Iron
How to open a steam iron severin
follow this principle.God bless you
Clean an iron:
  1. Unplug the iron.
  1. Unplug the iron.
Jul 20, 2013 | Severin Steam Iron, 2500 Watt, White...
The steam button is stuck on (pushed in) but there's no steam.
follow this steps. God bless you
Clean an iron:
  1. Unplug the iron.
  1. Unplug the iron.
Nov 15, 2012 | Black & Decker Irons
Water is leaking out of the bottom of my philli[s GC 9240
see the next steps and fix it. God bless you
Clean an iron:
  1. Unplug the iron.
  1. Unplug the iron.
Nov 14, 2012 | Irons
As the steam builds up it constantly comes out of the the blow off pressure valve under the iron. steam will come out of the sole plate when the button is pressed
see this causes and fix it. God bless you
Clean an iron:
  1. Unplug the iron.
  1. Unplug the iron.
Oct 02, 2012 | Irons
Lost steam pressure
see this causes and fix it.God bless you
Inspect the steam vents from the outside, and use a pipe cleaner or other small utensil to remove any excess buildup that is blocking the vents. Be careful not to let the buildup fall down into the steam vents.
  • 3 Clean the steam iron's directional spray tip. Minerals and other debris can build up on the nozzle over time and will greatly hinder the use of your steam iron.
  • 4 Pour equal parts vinegar and water into the steam iron's water supply tank. Put the steam iron above an empty pot, and turn the iron on. Let it steam the solution until all the water/vinegar solution is gone
    Sep 23, 2012 | Tefal UltraGlide Easycord FV4256 Iron
    Rowenta DA75 - Won't Steam
    Can you remove the steam button if you can fill with water heat to maximum and holding over sink remove steam button rod this will clean the steam traks but be careful this gets very hot.
    Thanks J
    Feb 10, 2008 | Rowenta Steam 'n Press DA75 Iron
    Irons Logo
    43 people viewed this question
    Top Rowenta Irons Experts
    Joseph Hoffmann
    Are you a Rowenta Iron Expert? Answer questions, earn points and help others
