Question about Mitsubishi SL4SU ColorView Multimedia Projector
Yellow spot the projector image has a big yellow spot in the middle of the screen the place i bought it from says that i have to replace the main circuit board
  • Anonymous Dec 02, 2008
    Exactly as described above.
  • quiver Jan 11, 2009
    Not sure what you call these items, but they are mounted internal on each side of the lens assembly. The one associated with the blue side has a large "brown" square in the center of it and a small distorted area. We noticed a "yellow" box when the projector was turned on and it also turned all displayed white items yellow. I have dis-assembled the projector and found these "sliders" that screw down and need to replace all three of them. I'm not sure if they are suppose to look the same, but they don't. One's a light to medium gray(RED SIDE), ones has a slight redish/pink color(GREEN SIDE) nad the one I mentioned earlier which is pinkish also(BLUE SIDE), but has the brown square in the middle. Trying to find a dealer or parts place to get these parts
    Champion:
  • Mitsubishi Expert
  • 225 Answers
Http://youtu.be/A_wgbnArcu8
The Polarizer should be available through Mitsubishi. 150 for all three. here is a video of dis-assembly.
Posted on Mar 13, 2013
    Problem Solver:
  • 5 Answers
The problem is in the light path starting with the blue input polarizer then the blue lcd hopefully its just the input polarizer. worst case you will have to replace the LCD block witch is expensive to do. the polarizer ia a speacialy tinted glass designed to help with the LCD's temp.
Posted on Feb 03, 2009
Panasonic PT-AE2000U yellow spot
I believe your referring to a lens flare...if so, you must smoothly sand the lens with the finest sand paper and then buff it to perfection
Jan 04, 2012 | Panasonic PT-AE2000U Projector
I have a big yellow circle in the middle of my projected video. Can this be reset?
no you cannot remove, you have to change the screen inside the monitor. the spot cause burn on the screen picture.
Aug 29, 2011 | Sony VPL-HS51A / VPL-HS60 Multimedia...
How can i fix the yellow spot that comes up in the middle of the screen and when there is no video connected i see a blue screen
Yellow spot is mainly due to lense stain , so clean your lense from inside. it will solve your problem.
I think it helps. let me know.
Dec 28, 2010 | 3M X75 Multimedia Projector
Having a big yellow spot background in the middle of the picture.
Hi , it seems you are experimenting a light engine problem.Here's how your tv works: http://www.youtube.com/watch?v=ZLLHnQ4y-wo Basically there's 3 LCD chips that create the colors and image by blending together.When these chips start to melt you will get those blue spots, pixilation even vertical lines.You will need to replace the light engine. Have a blessed one!
Apr 09, 2010 | Hitachi 50VS69 50" Projection HDTV
My 3m s20 projector has a big yellow spot in the middle of the screen even without a video signal. changing lamps did not help.
the polarizer on the blue lcd panel is fried due to excessive dust and heat. you may have to replace the whole optical engine.
Nov 23, 2009 | 3M S20 Multimedia Projector
Green spot in middle of image as though a spot light was shinning on the screen. I've replaced the lamp
Welcome to LCD 101, the blue device is dying in the projector. Replace product with dlp brand and it will last a lifetime. good luck
Apr 14, 2009 | Epson PowerLite® 1700c LCD Projector
Big yellow spot in the middle of the screen
the lcd panel for the blue is bad normally you would have to replace the engine but i know a place where you can get it rebuilted for a price cheaper than the engine go to
N-home tvservice.com for some answers
Mar 02, 2009 | Hitachi 55VS69 55" Projection HDTV
Hitachi projector model CP X260 projects yellow spot on screen
This is probably the polarizing filter. It will need to be replaced. It should not cost very much to fix.
Jan 07, 2009 | Office Equipment & Supplies
Image has big yellow
Hi Zenmast
This is a burnt LCD that will need replacement. If the circle is yellow on a white screen , then it is your blue LCD that will need replacement.
Apr 22, 2008 | SharpVision XV-Z1U Multimedia Projector
YELLOW SPOT ON SCREEN
There may be a dust fleck on one of the LCD screens inside your projector. I had a similar problem and managed to clean it. But it requires you to dissassemble the entire projector !!!. If you are not technical, don't do this yourself. !!!
Feb 16, 2008 | Sony VPL CS5 Multimedia Projector
Mitsubishi SL4SU ColorView Multimedia Projector Logo
1,379 people viewed this question
Top Mitsubishi Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Mitsubishi Office Equipment and Supply Expert? Answer questions, earn points and help others
