SOURCE: Ink System Failure HP C5180
this type of error message is related both with the printer and the ink cartridge. You may need to change your ink cartridge that you have purchased. Or you can reset the printer. I will give you instructions on how to make a reset on the printer if changing the ink cartridge will not resolve the problem
SOURCE: hp photosmart 3200 all in one ink system failure
I know this sounds crazy but I did this and others have too, it worked. Hold down four buttons at the same time ( OK, Cancel, Black , Color ) and turn the power off. Note: I figured out how to hold the 4 keys down with one hand and push the on/off switch at the same time. Once you power the printer back up is will take a few minutes to go through maintenance. Then it will “hopefully” go back to normal. I did this 2x’s. HP gives you a procedure that doesn't work! They just want to make money off fixing it every 6 months. They are in the service, repair and “ink business” not printer manufacturing.
SOURCE: Ink System Failure code appears on Hp Photosmart D7360 printer
Hi ok try
I found this I know your error not in here but it may work for
It worth a try nothing to lose and it may work.
I know your error code is not in this but it some times it clean the error with this type of error number you can gave it a go try not harm it
Error code: 0xc18a0201, 0xc18a0206, 0xc18a0306, 0xc18a030a, 0xd0620130, 0x887dd03a, 0xd05d010d, 0xf0af8004, 0xc19ac3ff, 0xc18a050...
Reset the product:
1. Without turning off the product, disconnect the USB cable from the rear of the product.
2. Remove the cartridges from the product.
3. Wait for the 'Insert Cartridges ' message to display on the control panel.
4. Disconnect the power cord from the back of the product.
5. Wait 60 seconds.
6. Reconnect the power cord. If the product does not automatically turn on, press the Power button ( ).
7. Reinsert the cartridges, and then close any open doors on the product.
8. If you receive a prompt to print a calibration page, do so.
9. Reconnect the USB cable to the rear of the product, and then try printing again.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
SOURCE: Hi i got a Hp photosmart 3100 Series and its not
Hi there
Solution 1:
- Hold down the "OK", "Cancel", "Black", and "Color" buttons at the same time and turn the printer off.
- Keep holding the buttons down until the printer shuts off and turn it back on.
- Turn the printer off twice and then it will recalibrate.
- Make sure there are new cartridges in the printer so that it can reset.
Solution 2:
- Remove the cartridges from the product.
- Wait for the 'Insert Cartridges ' message to display on the control panel.
- Disconnect the power cord from the back of the product.
- Wait 60 seconds.
- Reconnect the power cord. If the product does not automatically turn on, press the Power button.
- Reinsert the cartridges, and then close any open doors on the product.
- If you receive a prompt to print a calibration page, do so.
- Reconnect the USB cable to the rear of the product, and then try printing again.
