Question about Canon imageRUNNER 5570 Copier
E804-0002 is ir5075 what is this ? - Canon imageRUNNER 5570 Copier
Ir5075 E804-002
Posted on Jun 18, 2013
  • roshni Jun 18, 2013
    IR5075 E804-0002
Canon ir5075 error code E00014-000
ese are all list of error code in Canon iR5075
  • n cause: the main thermistor (TH1) has poor contact or an open circuit.The thermal switch (TP1) has an open circuit.The fixing heater has an open circuit.The SSR is faulty.The DC controller PCB faulty.Mode of detection: 0000 after the main power switch is turned on,the temperature detected by the main thermistor does not reach 70?C.
Caution: The error must be be reset in service mode (COPIER>FUNCTION>CLEAR>ERR)
  • E001
Main cause: The main thermistor (TH1) has a short circuit.The sub thermistor (TH2) has detected overheating.The SSR is faulty.The DC controller PCB is faulty.Mode of detection:0001 The main thermistor or the sub thermistor has detected about 230?C or higher for 2 sec.0002 The main thermistor has detected 230?C or higher (hard circuit detection)0003 The sub thermistor has detected about 236?C or higher. Caution: The error must be be reset in service mode (COPIER>FUNCTION>CLEAR>ERR)
Dec 12, 2013 | Canon imageRUNNER 3300 All-In-One Laser...
Kertas f4 di ir5075
not available for minolta 4000
Nov 07, 2013 | Minolta EP4000/5000 CS/PRO Copier
Canon ir5075 error code e100-001
laser scanner error. needs a new laser
Sep 11, 2013 | Canon Office Equipment & Supplies
Memory full message canon ir5075
Some cases :
- mailbox is full. (delete all file on mailbox) or
- enter to service mode then clear memory (R-Con)
Mar 04, 2013 | Canon Office Equipment & Supplies
Error 061 canon ir5075
Hi you should check the lower corona block cleaning motor or the cleaner got stuck
Jan 03, 2013 | Ricoh Aficio 1035 Copier
E202 code in IR5075 what that it means?
E202 0001 The scanner home position sensor does not go OFF when the scanner is moved forward by 40 mm 0002 The scanner home position sensor does not go ON when the scanner is moved reverse 450 mm
Dec 16, 2010 | Canon Office Equipment & Supplies
I have a copier IR5075 with code E202 what is that?
Dec 16, 2010 | Office Equipment & Supplies
Can somebody help me what this mean? Error Code: E100 0001- E100 0002 it is a canon LBP5000
Symptom
  • E061-0001 (Potential ON)
  • E061-0002 (Potential OFF)
  • E100-0001
  • E227-0004
Cause
  • The pin is broken on the Primary Fan 2 Duct. The Laser Shutter is activated by the pin on the Primary Fan Duct Assembly. The linkage is pinched not allowing the laser shutter to be fully actuated (may also indicate E227-0004). Faulty Laser Scanner Assembly.
  • Defective DC Controller PCB Assembly.
Action
  1. Check the shutter operation and the pin on the Primary Fan Duct Assembly. If the pin is broken replace the Primary Fan 2 Duct (iR6570 : FC6-3540-000 / iR5075 : FL2-5834-000) or the Primary Fan Duct Assembly (iR6570 : FM2-3074-000 / iR5075 : FM2-9694-000). If the Laser Scanner Assembly (iR6570 : FM2-3670-000 / iR5075 : FM2-9832-000) has been replaced and error codes E100-0001/ E227-0004 are intermittently indicated, proceed to the next step.
  2. Remove the Primary Fan Duct Assembly (this assembly has a pin on it that activates the laser shutter).
  3. Remove and reinstall the Laser Scanner Assembly.
  4. Install the Primary Fan Duct Assembly. This should free the linkage allowing the laser shutter to be fully actuated.
  5. Finally a DC Con clear resolved both of the intermittent issues (E100-0001/ E227-0004).
May 28, 2009 | Office Equipment & Supplies
Canon imageRUNNER 5570 Copier Logo
451 people viewed this question
old marine
old marine
