Question about Samsung HL-S7178W 71 in. HDTV Television
How to I get to fan 2 in Samsung DLP TV - Samsung HL-S7178W 71 in. HDTV Television
4 Suggested Answers
tvtek
  • 1284 Answers
SOURCE: Own a Samsung DLP TV 42 inch and white dots have
The random whit dots you are seeing is more than not the DMD or million little mirrors board. The white spots represent some of the mirrors that are sticking in the on position. In that case they are always reflecting white light from the lamp. I don't concider the DMD board a do it yourself repair since on the older DLP set it requires mechanical alignment as well. The best thing to do is contact a techincian and see what they might charge to repair the TV for you. Please take a few moments to rate my answer...Thanks..
Posted on Nov 22, 2009
easyab
  • 132 Answers
SOURCE: NEED TO KNW HOW TO REPLACE NO 2 FAN ON A SAMSUNG
Here is Fan part# BP31-00024A. Search google, find it at various places.
Light engine assembly has to be removed. This involves unplugging various connectors between processing/control chassis on the left side and engine assembly on the right side. Mounting screws on the top and bottom of engine assembly. Then remove light engine assembly completely from the TV. Fan#2 is the lamp cooling fan and is located beside the lamp assembly.
It is not too complicated if you draw a picture of where all the plugs are removed from. If one plug is not put back correctly, unit will not work. Usually a tight fight sliding out the engine. Plastic cable tie-down between the 2 assemblies can be cut and discarded, this makes re-installing light engine considerably easier.
Cheat the cabinet safety switch with tape or stretch connecting wire across it to hold it in "on" position for test after reassembly.
Service cost may be $150-$200 if you don't do it yourself. We do it in most Canada cities.
easyab
Posted on Apr 23, 2010
  • 20 Answers
SOURCE: My samsung dlp tv model#hln617w keeps turning off.
It could be the temp sensor going bad. This sensor sits on top of the metal housing which the bulb assembly slides into. The bulb assembly will have a hole on top and this is where the sensor is above. There is a small blue and white wire that plugs into it. If you pull the wire out and put a paper clip or wire in the coupling you will basically bypass the sensor connecting the blue and white wire. If your tv turns on then that is your problem. Its cheap too. Here were my symptoms..1] Turn tv on 2] Bulb would light up..(which eliminates the ballast) regular picture would show up (which eliminates the bulb and color wheel) 3] 30 seconds later tv would shut down with 3 flashing lights. After bypass the tv turned on as always and hasnt shut down yet. Always un plug tv first. Get the replacement part to avoid overheating and possible fire
Posted on Aug 11, 2011
Is there a manual for samsung dlp tv 5687- location of fan#2
http://www.manualslib.com/manual/510316/Samsung-Hl-S5687w.html
Oct 17, 2015 | Samsung Televison & Video
Where is "fan #2" in Samsung dlp hl-r5656w?
I don't know which is fan #2 but if you take the back off, you will see one fan right in front of you. The other is harder to get to. It's the black box inside the silver covering with the holes (in left lower part).
My TV was acting up by having only one color showing until I let it cool down then it would work fine. I cut a hole in the plastic back cover and mounted a bigger computer fan. Just spliced it in the wires of the little fan. Fixed the problem
Jan 26, 2013 | Samsung HL-R5656W 56" DLP HDTV
#2 fan
you need to replace fan #2 , is located next to the lamp is a big fan compared to the other fan you can buy this fans from any electronics place
Nov 12, 2011 | Samsung DLP HL-P5663W 56" TV
I have a Samsung DLP 50" HDTV HLS5086w, and I need to know how to find and remove fan # 2 from inside the TV so I can replace it but when I open up the back I can't see it anywhere. Only fan 1 is...
Fan #2 is the fan that blows air accross the lamp itself. It sits in the far upper right corner covered by a shroud. The ONLY way to remove the fan is to remove the complete light engine itself. I would recommend a technician to do so : )
Jul 27, 2011 | Samsung HL-S5087W DLP TV
#2 fan is not working
search google and ebay
Apr 13, 2010 | Samsung HL-S5087W DLP TV
Samsung dlp hl-r5667w
This Tv make a lot problems with the color wheel and fan thermostat, lamp cool. Need be check the color wheel first. I am suggested dont have nothing on the back cover ( make hot or not ventilation). More information parts at tritronicsinc.com Thank you
Aug 12, 2008 | Samsung DLP HL-P5663W 56" TV
The tv says 'check fan #2. samsung dlp model # hln437w/xaa
Everything you need to know is right Here
http://www.jangro.com/a/2006/09/29/samsung-dlp-how-to-replace-fan-2/
Jul 06, 2008 | Televison & Video
Samsung 50" DLP TV
Since the lamp generates a lot of heat, the fans are continuously monitored for correct function. The owner's manual should show you the location of the fans. Make sure that the grills covering the fans are clear of dust and that the fans are clean. Sometimes dirt can cause the fan blades to slow down enough to trigger the safety alert.
Keep us posted.
Dan
Jun 27, 2008 | Samsung DLP HL-P5663W 56" TV
Samsung HL-S7178W 71 in. HDTV Television Logo
149 people viewed this question
Jerry Greenberg
Jerry Greenberg
