Question about Hoover UH30010COM Bagged Vacuum
My vaccum cleaner, hoover model uh30010 stop after one minute
It stopped after one minute and the power button has flashing button
SOURCE: leaking
My machine leaked badly BUT it was my own fault. There is a one-time only setup procedure where you squeeze the trigger and push the Clean-Surge button to lock a rod into place. Push the Clean-Surge button VERY HARD. There will be a loud SNAP which sounds like you broke something, but you didn't. I didn't push hard enough initially, all I got was a click which I thought was enough. My machine leaked so I called the help line. They told me to push the button harder, and sure enough, they were right. Until you get that snap, the Clean-Surge (which releases a little extra water-cleaner solution) is on all the time, hence the leaking
Posted on Nov 02, 2007
SOURCE: Hoover self prpelled wind tunnel model U6423-900
Clean the filter and bag
Posted on Dec 27, 2007
reddevil6
  • 1673 Answers
SOURCE: Problems with the Hoover Steam vac Heated carpet cleaner
This happens when the filter on the inside of the lid for the dirty water tank is pushed all of the way up. You need to leave a 1/4 in. gap from the top to the top of the filter.
Posted on Jan 10, 2008
reddevil6
  • 1673 Answers
SOURCE: changing bell on a hoover turbo power 6200
Most Hoovers if you turn the vac over, remove the plate covering the brush roll, then you can get to the belt and brushroll.
Posted on Jan 15, 2008
SOURCE: Brushes on My Hoover Steam cleaner will not spin
We had same problem,Had to have bearings replaced at hoover store/service center. If you bought it within the last year it is under warranty and you wont be charged.
Posted on Nov 25, 2008
Uh30010. Why does it start and stop continually?
Have the same issue. Ever find out why??
Oct 28, 2015 | Hoover Vacuums
Light keeps blinking
http://www.searspartsdirect.com/partsdirect/user-manuals/uh30010com-hoover-parts-vacuum-manual
WARNING: TO REDUCE RISK OF PERSONAL INJURY - UNPLUG CLEANER BEFORE SERVICING
PROBLEM POSSIBLE REASON POSSIBLE SOLUTION
2. Blown fuse or tripped breaker.
4. Thermal protector activated. (power
light is flashing)
1. Disposable bag is full. ("Check Bag"
indicator illumJnated red)
1. Disposable bag not installed correctly.
3. Brushroll is worn out.
2. Check fuse or breaker in home. Replace fuse/reset breaker.
4. Turn the cleaner off and disconnect it from the electrical
outlet. Then allow cleaner to cool for 30 minutes. If the
thermal protector continues to activate see Needs Service
solution #5.
1. Replace disposable bag - Pg. 9.
1. Review disposable bag removal and replacement - Pg. 9.
3. Replace brushroll - Pg. 10.
Mar 11, 2014 | Hoover UH30010COM Bagged Vacuum
I have uh30010 hoover that stops and flashes when handle tilted
I had one in doing this last week. I replaced the upper handle and it acted normally again. Maybe just a bad connection where the handle plugs in?
This is the part I'm speaking of:
http://www.vacuummedic.com/product.php?id=389
Good Luck
Feb 11, 2013 | Hoover UH30010COM Bagged Vacuum
Brush Bar Randomly Stops Turning
There are numerous things that could cause this. It would be best to find a qualified Dyson repair person to determine the cause of your DC28.
Nov 30, 2017 | Dyson DC28 Animal Bagless Upright Vacuum
Demonstration of how to use hoover vaccum cleaner u5759-906
Hi
What happened to the manual?
Online you can find MANUALSONLINE.COM see if you can find the Hoover manual there.
all the best
Kolbrun
Mar 07, 2012 | Hoover Vacuums
I can not get alarm to work on Constant elite colour change LCD alarm clock
Underneath clock there is 4 buttons, 2 of which are marked (m) & (s) and the other 2 buttons marked with arrows for (up) & (down). depending if you have the clock, alarm or date showing press down on the (s) button for about 3 seconds and the hour digit will start flashing, use the (up) & (down) arrows to set your hour. Then press the (s) button again just briefly and the minute digit will flash and use arrow (up) & (down) buttons to set this also. Press the (s) button again and all will stop flashing and Alarm or Time or Date will be set. Hope this helps as i had same problem but figured it all out in about 2 minutes as i couldn't find my manual lol,.
Jan 27, 2011 | Vacuums
I have a westclox 70034 and I need to know how to set the alarms
Push the alm1 alm2 button until your desired alarm number shows. Then hold the alm1 alm2 button for approx 3 seconds. The alarm time will flash. push the ADJ button until you reach the time hour you want. Then push the alm1 alm2 button to set the minutes. push ADL until you find the desired minutes. The push alm1 alm2 button and alrm will stop flashing. Your alarm is now set...... I to lost the manual and had to figure it out myself.
Dec 14, 2010 | Vacuums
Hoover UH30010COM Bagged Vacuum Logo
123 people viewed this question
Top Hoover Vacuums Experts
Jim Parker
Jim Parker
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
