Question about GE GSL25JFPBS Side by Side Refrigerator
Water disperser not working GE model GSL25JFPD
The ice maker works fine, but the water does not. I read online to take off the kick-plate on the front and disconnect the water line from the connector and test to see if the water would run when I hit the button, IT DOES. With the water line disconnected from the coupler, when I hit the botton water spews out.
  • David Davlin Feb 11, 2012
    Nevermind, I fixed it... I took apart the coupler behind the kick-plate. When I pressed the button water would spew out... So I knew I had power... I opened the freezer door and got a hair-dryer and blew on the water dispenser to heat it up. I left the freezer door open with the hair-dryer on the water spicket for about 20 min. plugged everything back together and BAM, water works. The line had frozen up in the door. I looked and the freezer setting was set on 9(highest) so that was the problem. I will back it down to about 5 and see what happens.
    fixed
4 Suggested Answers
SOURCE: ge sis by side
Howdy do!,,,this happened to my GE side-by-side,,,I found that the water line in the door was frozen,,,I lowered the temp in the freezer by just one number,,,then warmed up the door with a hair dryer,,,,when the water line thawed out enough to work a small piece of ice came out of the line and went in my glass. Good Luck!,,,,Pete.
Posted on Sep 23, 2008
  • 34 Answers
SOURCE: Ge ice marker no 120v to seloniod water valve
It sounds like the plug-in for the solenoid valve is not making contact with the terminals on the solenoid . You can either buy a new connector or cut the plug for the solenoid and crimp 1/4 inch sta-cons (insulated type) to the wires.
Posted on Sep 10, 2009
milten1
  • 1304 Answers
SOURCE: I own a GE side-by-side model # GSS25LGMF CC; my
ive seen this before on this model, what is happening is the water line in the door is freezing and clogging up
the best thing you can doo here is disconnect that tube and try to get it defrosted
i usually suggest to turn the unit off
and open the freezer door let the inside come up to room temp
and drain from the coupler
Posted on Oct 17, 2009
Ge gss22 where is the ice maker supply valve
Pull the refrigerator out and follow the water line to the back. It will go to a double valve solenoid. One half is for your water dispenser, the other for the ice maker. It is possible that this solenoid has failed. You can order the part online and replace it pretty cheaply. Just remember to turn off the water supply (usually under the sink) and unplug the refrigerator before hand and have a towel ready to catch water that will drain from the lines.
To order the new part get the full model number of your refrigerator and go to the GE website and look up their replacement parts page. You should be able to search for that model and all of its related replacement parts there.
Mar 08, 2012 | GE GSS25WSTSS 25.4 Cu. Ft. Side-by-Side...
My refrigerator won't dispense ice cubes or crushed ice or water at the front door, I was wondering if it could be the Touch pad control panel on the front of the refrigerator. If it is can you give...
The front touch pad board /panel which you are referring is called dispenser board.To access the dispenser board assembly, click this link below:---
http://howtobyme.blogspot.com/2011/06/ge-side-by-side-refrigerator-will-not.html ------------ The dispenser board removal procedure is mentioned at the last on the link instructions.-------- -------------- But the engineer at your place has pointed you to right direction.The main control board is most probably the cause of problem.One more important thing.There are many other users too facing same problem with there ge side by side refrigerators.This problem occurs in many ge model refrigerators. There was service letter released by Ge for this problem.Click this link, to read the letter:--- http://howtobyme.blogspot.com/2011/07/ge-side-by-side-refrigerator-wont.html -----------
You can get required parts from online sites like: --- www.repairclinic.com or from searspartsdirect online site.
----------- This should help. Thanks.Helpmech.
Jul 28, 2011 | Refrigerators
To much water into ice maker leaks into freezer
this is most likely caused by a faulty water fill valve. Refrigerators that have ice/water in the door have two fill valves, one for the ice maker, one for the water dispenser. They are usually located on the back of the refrigerator about 6 inches or so off the floor. Some are located in the front behind the kick plate. They are not difficult to replace. You can order them online. Be sure to turn the water valve behind the refrigerator off before you disconnect anything. it is also a good idea to unplug the refrigerator. As long as you plug it back in within 30-40 minutes the food should be fine.
Feb 25, 2011 | GE Adora (DSF25KGTBG) Side by Side...
My icemaker has stopped receiving water
it sounds like your water valve is bad. you have a double water valve - one side operates the ice maker and the other side operates the water dispenser. the ice maker side of the valve is bad.
you can manually pour a little water in the ice maker ice mold and wait an hour or so - if it dumps the ice then you know for sure that the ice maker is cycling and water is not getting to the ice maker from the water valved
May 25, 2010 | GE GSS20IEP Side by Side Refrigerator
The ice maker on our GE refrigerator does not make ice
1 -Ice maker arm must be down(on position)2-Make sure the water supply line is connected to the fridge3Check if the ice maker is plugged in4The freezer must be working fine for the ice maker to produce ice. After the ice maker stars and calls for water and doesn't get any , the water valve is bad.And if everything above is ok the ice maker needs to be replaced.
Apr 26, 2009 | GE Refrigerators
Water dispenser not working, ice is working
The mother boards go all the time on these from what I read. I had the same problem. It is located under the silver plate in the back of the frigerator.
Mar 23, 2009 | GE GSL25JFPBS Side by Side Refrigerator
Water, ice and crushed ice dispenser doesn't work properly
you need to replace the board in the dispenser front housing on the front of the freezer door / larry
Mar 16, 2009 | Refrigerators
Ge sis by side
Sep 20, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Ice maker and water dispenser front panel lost power
Check the power connection for the door.. It is either under the hinge cover on the top or under the kick plate in the bottom.. Just un plug and re plug if it seems like the wires are fine
Good luck
Feb 24, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
GE GSL25JFPBS Side by Side Refrigerator Logo
126 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
Charles T Nevin
Charles T Nevin
RepairNinja
RepairNinja
