Question about GE Refrigerators
How can i attach a lock on my refrigerator
Top door freezer single bottom frig.
  • 4 Answers
Here is an easy way. Buy a lock hasp from a local hardware store. Mount it to the right or left side, depending on which way it opens by holding it up so that the entire lock hasp covers the opening of the door seal width, but allows you enough room to drill the holes into your refrigerator sheet metal. If too small then buy a larger or if to big buy a smaller hasp. Use common sense and your best judgment. Once you have found one the correct size, you will need to mark the position of the holes that you will have to drill through the sheet metal. Once the holes are marked they will have to be drilled. You are going to permanently mount this hasp to the refrigerator with a pop rivet gun, so ensure you want to do this before you drill any holes. You will also want to buy a hasp that has holes no larger than 1/4" to make it a solid mount. Once you buy the pop rivets that fit through the holes in the hasp and are long enough to grab the sheet metal of the refrigerator, use the recommended drill bit size for the rivet. That info is on the rivet box. Once all holes are lined up and the door and hasp will allow you to put a small padlock on it use a pop rivet gun to permanently install the hasp to the side of your refrigerator. After it is installed, simply close the door and put your padlock on it and snap it shut to lock it. I learned how to do this, because sadly I lived with someone that had an eating disorder and the food had to be locked up. I pray you aren't going through the same thing, but this works!
Posted on Feb 11, 2012
I have whirlpool A CLASS fridge how do i reverse the door
  • I cannot confirm weather your fridge had reversible doors as you listed no model but the standard for fridges that can reverse the door swing are changed by doing this -
  1. You will see little plastic covers on the opposite side where the hinges and handles are currently located now.
  2. There are some little clips that hinge the screws on the top and bottom of each handle.
  3. Remove these little covers with a small flathead screwdriver.
  4. Now remove the screws holding the freezer and refrigerator handles on.
  5. Now pop the screw hole covers on the side of the frig/freezer you will using.
  6. Now place and fasten with screws the handles on the other side of the frig/freezer door.
  7. Now remove the top freezer hinge first by removing the 3 screws on top.
  8. Now pull up on the hinge (save the spacer).
  9. Now pull up on the freezer door.
  10. Now remove the screws on the middle hinge.
  11. Now pull up and remove the middle hinge while holding the frig door steady (save the spacer).
  12. Now pull up on the frig door and set to the side.
  13. Now remove the screws on the bottom hinge (save the spacer).
  14. Now put the screw hole covers you removed from the other side in the screw hole exposed from the screws you just removed.
  • The switch
  1. Start with the bottom hinge and place it on the opposite side (don't forget the spacer).
  2. Place the frig door on the bottom hinge and the place the middle hinge in the hole at the top of the frig door.
  3. Fasten the middle hinge.
  4. Place freezer door on the middle hinge.
  5. Put the freezer door in it's natural position to make putting the top hinge on possible.
  6. Screw the top hinge in.
  7. Job complete.
Regards, Tony
Apr 30, 2011 | Whirlpool Refrigerators
Every time the top frig door is closed the bottom freezer door opens sometimes only 10 or 15mm so that the alarm does not detonate. The reverse also happens, ie top door opens when the bottom door is...
There is an air duct that connects the fridge to the freezer. When the opposite door is closed air is trapped and forced out the other door pushing it open.
The door seals contain a magnetic strip that hold the door to the fridge, these magnetic strips have lost their strength, to test this use a shhet of paper. Open the door, place the sheet of paper across where the door closes, shut the door, then slide the paper out. If the paper comes out without any resistance then the door seal needs to be replaced.
Mar 31, 2011 | Fisher and Paykel E522BRXFD Stainless...
Freezer door opens when fridge door closes
if you are worried that the freezer is empty....fill it with plastic bottles of water...remember tho,don't fill the bottles completely as frozen water expands.
Jul 20, 2010 | Amana ATB1832AR Top Freezer Refrigerator
Side by side frig/freezer. Freezer auto defrost
Here is a tip that will tell you where the water is coming from and how to fix it. The drain hole has froze shut and the water from the defrost will not drain out.
Water Running in Refrigerator from Freezer
http://www.fixya.com/support/r3780310-water_running_in_refrigerator_from
heatman101
Jul 03, 2010 | Kenmore 20.6 cu. ft. Top Freezer...
Replace door on Kitchenaid bottom freezer 2 top door model
Switch from white to red wines and drink at room temperature, or buy a new single door cooler that suits your fancy. The bolts may line up because of a single door model that shares the same chassis, but the cost and trouble of getting a matching door may not be worth the trouble.
Feb 14, 2010 | KitchenAid KFCS22EVMS Stainless Steel ...
Freezer is working fine, but frig is warm,
Look for the return vent near the bottom probably behind the crisper. You'll have to remove it to see the vent. There may be an adjustable flap in to to adjust the meat keeper area. Make sure it's open.
Aug 22, 2009 | Kenmore 53642 / 53644 Side by Side...
Side by side Maytag frig that is warm on top, not bottom
You can turn the thermostat off for now to let the ice thaw out, if a door was left open there might not be anything wrong, but if it freezes up again sounds like you might have a bad defrost heater or defrost limit. Hope this helps
Apr 25, 2009 | Maytag MSD2756G Side by Side Refrigerator
Water on btm of glass shelves and water in bottom of frig
sounds like you have a gap in the door seal, which results in condensation forming inside unit. Use a blow dryer to heat the seal around the door and ensure that the fit is tight.
Jan 07, 2009 | Kenmore 72073 Top Freezer Refrigerator
Kenmore Elite Bottom Freezer - only top does not work
i would check to see if you hear a an blowing in the freezer sect when the door is opened, if you cant hear the fan blowing then there is yout issue, not circulating air up to refrig compartment
Nov 11, 2008 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Refrigerators Logo
748 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
dweatherby
