Question about Texas Instruments TI-84 Plus Silver Edition Graphic Calculator
I didn't make a backup to my ti-84
  • Texas Instru... Master
  • 7,993 Answers
What happened to it?
If you lost the preloaded applications, you can download them from the education.ti.com website. Here is the link.
Posted on Feb 12, 2012
  • oioioi Feb 12, 2012
    @k24674 thanks, it's working now
3 Suggested Answers
  • 7993 Answers
SOURCE: Change TI 84 OS to TI 89 OS??
And why, pray tell, would you do such a thing? You will ruin your Ti84 Plus Silver Edition and will not have a working TI89. Besides, TI connect will refuse to transfer it.
If you like the capabilities of the TI89 Titanium, buy a cheap or used one on e-bay or amazon.com and spare your TI84PLus SE.
Posted on Feb 14, 2010
walesarumi
  • 6993 Answers
SOURCE: my student's ti nspire won't
Put in new batteries and try again.
If new batteries did not solve the problem, the next thing to check would be the battery terminal.
If the battery terminal is rusty, the battery power won't contact and the calculator won't turn on. So, use a flat small screw drive to scratch the battery terminal so that there would be contact.
If the above is not the problem, the next to check would be the wire connecting the battery terminal to the the calculator's main board. There is a wire between the battery terminal and the calculator board. When the battery is inserted, the power from the battery goes from the terminal to the board through this wire. There is a possibility that this wire is cut in-between or is loosing contact. In this case, you need to get a small screw driver and carefully disassemble the calculator in order to check the wire.
If the wire is intact, use a light brush to brush the calculator board as there might be dust on the board.
If non of the above helps, then it means the calculator is dead and needs a replacement.
Regards.
Posted on Sep 13, 2011
Where is backup battery on ti-84
Open the battery compartment. Above the four AAA batteries you should see a small screw. Unscrew that to uncover the backup battery.
Jun 05, 2014 | Texas Instruments TI-83 Plus Calculator
Using a TI-84 Plus Silver Edition and the screen just went blank in the middle of a class. changed the batteries, didn't help. cleaned the connectors, didn't help. tried to change the resoluti
TI calculators have an annoying habit of dimming the screen when the batteries are changed so that it appears as if the calculator isn't turning on. Turn the calculator on (or at least press the ON key). Press and release the 2ND key. Press and hold the Up-arrow key for a few seconds and see whether the screen becomes legible.
What do you mean by "changed the resolution"?
Nov 15, 2012 | Texas Instruments TI-84 Plus Silver...
Xmit error message
Error in Xmit meaning one of the next options:
• The TI-84 Plus was unable to transmit an item. Check
to see that the cable is firmly connected to both units
and that the receiving unit is in receive mode
• You pressed ON to break during transmission
• You attempted to perform a backup from a TI-82 to a
TI-84 Plus
• You attempted to transfer data (other than L1 through
L6) from a TI-84 Plus to a TI-82
• You attempted to transfer L1 through L6 from a TI-84
Plus to a TI-82 without using 5:Lists to TI-82 on the
LINK SEND menu
Aug 02, 2012 | Texas Instruments TI-84 Plus Silver...
My ti 84 plus does not want to turn on, i thought it was battery problem so, i bought new batteries but i stil have a blank screen.
Could it be that your screen has been dimmed in error. Turn the calculator on & press the 2nd key and then the up arrow. This darkens the screen.
If this doesn't work, try taking out the backup battery. It is located in the battery compartment, behind a little door that you must take off with a phillips screwdriver. Leave it out for about 10 hours. If this doesn't work, try replacing the backup battery.
Hope this helps.
Jun 21, 2011 | Texas Instruments TI-84 Plus Calculator
TI-84 Plus will not turn on. Batteries have been replaced.
Try taking out the backup battery. It is located in the battery compartment, behind a little door that you must take off with a phillips screwdriver. Leave it out for about 10 hours. If this doesn't work, try replacing the backup battery.
Hope this helps.
Jun 11, 2011 | Texas Instruments TI-84 Plus Calculator
I did not reset or delete anything on my TI-84 calculator but after i changed my batteries i went into my programs but my programs were not there... do you know how to get my programs back?
You should not remove all the batteries ( AAA and backup) at the same time. Rather change the AAA batteries leaving the backup battery in. Then if you have to, change the backup battery while the AAA batteries are inserted.
If you do not take this precaution, you lose programs.
To reinstall programs that shipped in calculator (or additional apps) go to the education.ti.com page by clicking this link Download what you need and use the TI Connect software to transfer the APPS to your calculator.
Feb 17, 2011 | Texas Instruments TI-84 Plus Calculator
RAM CLEARED?
The most likely reason is that the backup battery is drained. Change the backup battery. When you get the Ram Cleared message, just press [CLEAR] to erase the message and start using the calculator.
Hope it helps.
Oct 28, 2009 | Texas Instruments TI-84 Plus Calculator
Frozen calculator
http://epsstore.ti.com/OA_HTML/csksxvm.jsp?nSetId=90524&nUsePub=NO&JServSessionIdrootdlek22=z6c2ohx3v1.n6LzoN8M/AzOnMTOogTxpQOUtxCLbx0Ka0--&jttst0=6_23871,23871,-1,0,&jtfm0=&etfm1=&jfn=ZGC5A4DDBCF3F0595853A68C079E5256B1556E2E93FB96ACB00A6AFBBC9B77BE7654B72492D9041952FB73A07FF7EFF0FB73
Here's a link to the troubleshooting thread from Texas Instruments about this particular problem, hope this helps!
Jul 10, 2009 | Texas Instruments TI-84 Plus Silver...
Texas Instruments TI-84 Plus Silver Edition Graphic Calculator Logo
76 people viewed this question
Top Texas Instruments Office Equipment & Supplies Experts
k24674
Stevan Milanovic
Are you a Texas Instruments Office Equipment and Supply Expert? Answer questions, earn points and help others
