Question about Echo Garden
Replaced a bad coil in my echo cs 3000 what is the air gap between the coil and the fly wheel ingnitiongap
What is the gap between the fly wheel and the coil
  • 76 Answers
SOURCE: please advise oil/petrol ratio...air gap ...plug
Hi
follow the link there are several manuals there for Echo chain saws
http://lawnandgarden.owneriq.net/manuals/mfg/echo/echo_chainsaw_product_list.html
http://www.echo-usa.com/pdf/documentation/CS300034003450efT1E_060402_1.pdf
on page 4 it says the types of oil and petrol
hope it helps
appreciate some rating form you.
thanks
Posted on Jul 18, 2009
dontbother10
  • 2220 Answers
SOURCE: How do I change the primer bulb on my Echo CS-3000
The IPL for an Echo CS-3000 is here:
http://www.echo-usa.com/pdf/documentation/CS3000T1T1E_081303.pdf
See page 8. There is no shop manual offered, you will need to interpret the pictures. Didn't look to difficult. GL
Lou
Posted on Sep 07, 2009
Testimonial: "Having the parts list helped me to understand how the primer bulb was installed. A great help. Thanks, Ed"
dontbother10
  • 2220 Answers
SOURCE: dropped my echo cs-3000 ignition coil wires came
EchoUSA
http://www.echo-usa.com/faqs.asp
#2,
then line 2 "Operator's Manuals/Parts Catalogs/etc."
Click "CS3000"
Toward the botom is the "Parts Catalog", choose the "Ignition, Starter Assembly" detail.
Item 4 connects between the coil and the on/off switch.
HTH
Lou
Posted on Nov 19, 2009
  • 277 Answers
SOURCE: how do I replace the purge pump on thr Echo chain
take side cover off and remove screws that hold the pump bulb in place and remove the gas lines make sure you put the right one back on each side.the one that sucks goes to carb. and other goes to gas tank.
Posted on Jun 21, 2010
dontbother10
  • 2220 Answers
SOURCE: I am replacing a bad
Ignition module gap
Place a business or index card between the fly wheel and coil, rotate until the magnetic attraction pulls everything tight together. Tighten the coil screws, rotate the flywheel until the attraction abates and remove the card. Ensure nothing contacts when the flywheel is rotated.
If you have more questions or need additional help please reply below and I will get back to you. HTH
Posted on Aug 06, 2010
What iscoil gap on gx160 honda5.5
Call a small equipment dealer & ask
for the specs
Jul 14, 2014 | Honda Quincy 17 - Gallon Air Compressor...
Have a ECHO gas trimmer SRM 2100 wont start. coulld it be the fly wheel
no not fly wheel maybe coil if not sparking check switch fist is on for sure or bad plug coil expessive try squrying some starting fluid in the carb check compression has to be above 90lb to start check and see if carbon has block exhaust port do all this first
Jan 20, 2013 | Echo 2-Cycle 28.1 cc Straight Shaft Gas...
What is the gap for the fly wheel to cdi on a 4600 echo chain saw
The easy way is to put a piece of sand paper between the coil and magnet.Put it in tighten the coil and pull out the paper.
Feb 26, 2011 | Echo Garden
Echo cs-3400 wont start . no spark. what are the primary and secondary coil readings?
if you have no spark
check for faulty plug 1st, then pull kill wire off at kill switch, then check for grounding ht lead ,
then pull kill wire off at armature , if still no spark most likley faulty ignition armature
i suspect the part number you need if its type 1 is 15662639130
replace it and set air gap and reassemble and test
here is web site for parts
http://www.ereplacementparts.com/echo-cs3400-type-chainsaw-parts-c-35043_35970_36021.html
or you could try www.partstree.com , go to echo saws , then find your model
cheers hope it helps
pauly 46
Jan 28, 2011 | Echo 30.1CC Chainsaw With a 14 In.bar and...
Igntion coil on echo trimmer went bad, replaced with echo blower coil . there is a small difference in design but now have ignition. Engine still won't start.
Make sure the air-gap between your used blower coil module and the magnets on the Echo's flywheel is about the thickness of a regular business card. That is about .010"-.016". The gap HAS to be present in order for the module to produce the spark.
Oct 01, 2010 | Echo Rapid Loader, Trimmer Head
I am replacing a bad coil in my Echo SMR 2100. I need to know the air gap between the coil and the flywheel.
Ignition module gap
Aug 06, 2010 | Echo Garden
Model TB320BV 2-cycle blower.
there is no set gap realy what i do is put a thin bit of carbord inbetween the coil and fly wheel so there is say 25th of an inch of gap dont set it so tight that the fly wheel hit's the coil or it will distroy it there needs to be a very small gap and it will work just fine,,ok?
Jul 27, 2010 | Troy-Bilt 31cc 2-Cycle Gas Powered...
This engine is an old 8horse on a snowblower. it has no spark and the plug is good. so is the coil bad and is the coil the piece that sits above fly wheel,and does the fly wheel need to come off to connect...
doesn't mean coil is bad, may just need points and condensor. They get old and wear, old b/s part no. 299061 , these are under flywheel , and points cover. either replace points and condensor or try cleaning them with flex file.(temp. repair) points gap is .020. not sure of air gap of coil to flywheel. coil can be tested at most shops, You will be able to see if points are burnt visually. hope this helps.
Jan 13, 2010 | Briggs & Stratton Ignition Kit 2-8 HP...
Echo SRM 1501 trimmer has minimal fire. Feels very slight, will not fire thru plug
If this is a solid state ignition ( black box mounted right next to the fly wheel)check for rust on fly wheel and coil/ignition.Sand with light grit sand paper if nessesary. Make sure to reistall with the same gap between the two parts.note the gap at this point could also be wrong.Also check to see if the clip inside the boot where the spark plug conects is not bent and that it is conecting properly. If this is a points ignition system then its basicaly the same steps.Clean contact pionts check plug boot for good contact. Or could be bad coil.Be sure you are using a plug with the propor heat range.
Jun 07, 2009 | Echo Garden
Open Questions:
Garden Logo
Top Echo Garden Experts
Jim Parker
Jim Parker
colesmowers
Phil Walker
Phil Walker
Are you an Echo Garden Expert? Answer questions, earn points and help others
