Question about Garden
Replacing drive pulley craftsman 315.11715
How do you remove the large drive pulley on this belt sander. We need to replace it but cannot seem to remove the old one?
pappyld04
  • 36 Answers
SOURCE: Drive belt comes off the rear pulley.
If the bearings and pulleys are in good shape, alignment should be checked. Though with alignment problems you ran into bearing and even pulley problems also.
Posted on Nov 13, 2008
lester482529
  • 226 Answers
SOURCE: drive belt diagram for mtd rideon
hi;go to partstree.com.put in your model # and make.then click on deck assembly.it will be what your looking for.hope this helps.please rate this;Thank's
Posted on Jul 04, 2009
  • 148 Answers
SOURCE: i need to know the route of the drive belt around the pulley syst
go to www.searspartsdirect.com and you can look up the diagram on their website.
Also you can download a free owners manual at www.managemyhome.com.
Posted on Jul 22, 2009
  • 190 Answers
SOURCE: What is causing my drive belt to slip off the
Do you have enough tension on it or you may have a warped pulley.
Posted on Aug 15, 2009
Testimonial: "I was thinking of a warped pully, wonder if i can get a replacement?"
canbruce75
  • 1776 Answers
SOURCE: How to replace drive belt craftsman tractor
There is a video on YouTube that may help you somewhat with the belt replacement. You may want to check it out. Here is the link. Sure hope this helps and best wishes.
http://www.youtube.com/results?search_query=lawn+mower+belt+replacement&search_type=&aq=1&oq=lawn+mower+be
Posted on Aug 25, 2009
Testimonial: "Good, quick feedback - thanks --"
Why did Craftsman LT2000 stopped moving? Engine starts and blade engages fine.
The transmission drive belt is a separate one from the blade belt. The clutch pedal when released puts tension on the transmission drive belt so it tightens up and drives the gearbox pulley by way of a large spring. Make sure the spring is ok. The belts don't last forever and probably needs replacing looking at the age of the machine. That is a fun job as it is right up under the machine and runs from the engine pulley right back to the top of the transmission. You have to drop the deck right off and I usually find a tree with a large branch and haul the front up with a rope or winch so the mower is vertical. Makes it easier to work on. Drain petrol first though. Hope this helps otherwise get a mower shop to do it for you if you feel it's to much of a task. Good luck.
May 19, 2014 | Craftsman Garden
I just need to know how to remove and replace the drive pulley on the DeWalt 432 belt sander.
You need a Screwdriver (Phillips) and a pair of Pliers... Get the Pulley FIRST, Take the screws out and split the case, you will see the Pulley. Replace the Pulley and reassemble
Apr 08, 2013 | Tools & Hardware - Others
Removing the disc sander on an erbauer erb050bts to replace the belt
The drive belt is a toothed rubber belt, which will be 'thrown off' if there is too much resistance to rotation (pressing too hard, or sanding belt not correctly aligned and rubbing against the side).
To access this, it is not necessary to remove the sanding disc.
Remove the two allen bolts on the top which hold the disc belt assembly (NOT the one that clamps the belt drive disc). The whole assembly lifts off, giving access to the drive belt. It is a bit fiddly, but it can be hooked back on the pulleys and the bolts refitted. Good luck!
Dec 11, 2012 | Tools & Hardware - Others
Replace drive belt Bosch pbs7a
NEED A AUTO REPAIR SHOP TO RESET IT ONLY THERE COMPUTER CAN DO IT OK
Nov 14, 2012 | Bosch Belt Sander Drive Belt For Pbs 7a,...
Installing belt on sander
Remove table assembly.
Remove pointer and then slide cover up and out from dust reflector.
Release belt tension by pushing tension lever toward idler drums.
Note: there may be an arrow on the inside of the belt.
The arrow should point in the direction of belt travel to ensure that the splice in the belt will not come apart.
Slide new belt over the drive and idler drums; center belt on drums.
Push tension lever towards drive drum to tension belt.
Hope this helps.
Oct 04, 2009 | Tools & Hardware - Others
How do you replace the drive belt on a ryobi type be321
I tried the model number and can't find it on their site, but if this is a belt sander or planer you can "roll" the new belt in place without loosening anything. If this is another tool let me know and please give me all the information (tool type) and I will check further.
Aug 23, 2009 | Ryobi Tools & Hardware - Others
How to replace the drive belat on craftsman 917273280, 21hp, 48 in cut?
you remove shield from engine remove belt, remove deck from mower and remove pulley guards and install belt replace guards , reinstall deck, put belt on engine pulley replace guard
Jul 07, 2009 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
Drive pulley removal
ZGAZER
here is a parts breakdown. in center of picture is name of website where you can get a download. I cannot figure out if you are removing # 831 or 835 pulley. Either way its righty loosey on nut and you will have to hold opposite end to loosen.
Mar 08, 2009 | Bosch 1274DVS 3" x 21" Belt Sander
Motor runs but the drive drum that hold the sanding belt does not turn.
Instead of removing the drum, remove the belt and the cover over the gearbox. The gearbox cover is normaly fixed in place by screws around the drive pulley. There may be a couple of screws under the pulley, if so they can be accessed via holes in the pulley wheel itself. Check for worn or stripped gears. These gears can be replaced if need be, but if this is the case make sure you remove and clean out all the grease first and replace that aswell as it may contain bits of teeth that have come off the faulty gear. As far as I know belt sander drive rollers can not be removed without removing the drive inside the gearbox first.
Oct 27, 2008 | Dewalt Factory-Reconditioned DeWalt DW432R...
Garden Logo
41 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
