Question about Compaq Presario Notebook
CQ61 SATA Laptop AD-7561S DVD/RW CD/RW Driver
Laptop is not recognizing the driver plus getting Code 39 error plus getting Catalyst Control Host Application Not Working error. HOW DO I FIX ALL OF THIS!
    Genius:
  • Compaq Master
  • 1,274 Answers
Reinstall your catalyst drivers from the ati website, there is also a M$ fixit for your CD/DVD drive located here http://support.microsoft.com/gp/cd_dvd_drive_problems good luck!
Posted on Feb 12, 2012
Can't get my cd/dvd rw drivers to work? Can't read the CD/DVD RW Tray?
Description of Code 10-related errors that Device Manager generates in Windows-based computers
Try this - Control Panel - Device Manager - CD/DVD - double click the device - Driver's Tab - then RIGHT CLICK the drive - UNINSTALL - REBOOT
this will refresh the default driver stack.
if this not work, replace the device with a new one.
Mar 03, 2015 | Acer 15.6 Inch LCD Screen Panel for Aspire...
How to change faceplate on LightScribe SuperMulti 8X DVD R/RW with Double Layer Support in hp pavilion
Why would you want to remove the faceplate?
If you have a dvd or cd stuck in the drive straighten out a gem clip (paper clip) and stick it into the hole that is on the faceplate (drive drawer that holds the cd or dvd) and push it while you press the eject button.
May 10, 2012 | HP Computers & Internet
DVD RW AD-7561S recongizes some CD's but not all....and not DVD's at all. Should I re-install or is their a setting I can change ?
Click start control panel,administrive tools,computer management,device manager scroll to cd/dvd rom drives right click properties then properties again then tick enable cd digital cd audio for this cd rom device or scroll to dvd regions select the no _ for your specific area
If this does not fix the problem you might try
you might have to physically unplug the leads for this cd-rom then plug them back in this should activate the found new hardware wizard or
you might have to uninstall then reinstall your DVD/CD or uninstall the driver then reinstall for this device
click start control panel admistrive tools,computer management,device manager scroll down cd dvd rom drives right click you will see options to update driver,roll back driver,or
select properties general troubleshoot, select driver click to reinstall drivers click update driver or uninstall then reinstall
make sure that the cd-dvd burner is getting enough power test all leads that are attached to the dvd drive including electrical extensions and make sure they have a secure connection or just replace them there might be bad/faulty or
if this does not fix the problem it might be a registry problem
Close all open programs
Click on Start, Run, and type regedit and press Enter
Click on the plus signs (+) next to the following folders
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
{4D36E965-E325-11CE-BFC1-08002BE10318}
This folder is the DVD/CD-ROM Drive Class Description in the registry. Look for any of the following names in the right hand column.
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
If any of the above keys shown in step 4 are listed, right-click on them and choose Delete
After deleting the keys, close the registry editor
Reboot your computer
Open My Computer and check to see if your CD or DVD drives have returned. You may also want to open Device Manager and verify that the yellow exclamation and error code on the CD or DVD drive is gone.
hope this helps
Sep 14, 2011 | Computers & Internet
My optiarc dvd rw drive isn't recognizing blank new dvd's to burn videos on
click start control panel administrive tools,computer management,device manager scroll down cd dvd rom drives right click you can you can update driver,roll back driver,or
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
hope this helps
May 09, 2011 | AGPtek Sony Optiarc AD-7560A CD DVD RW...
Hp dvd rw AD-7561S ATA, its only reading dvds.t
Guess your lens is bad... Clean it properly or better still, buy an external cd rom.
Feb 14, 2010 | HP Pavilion Dv3-1075us Notebook
My optiarc AD-7561s not working with Windows 7
If it worked a few times then maybe the burner is defective. Also try downloading the latest firmware for the burner from the manufacturer's support site.
May 19, 2017 | Sony Computers & Internet
Compaq Presario Notebook Logo
106 people viewed this question
Top Compaq Computers & Internet Experts
pankaj rautela
pankaj rautela
Alun Cox
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
