Question about Car APS921 Remote Starter - Keyless Entry
APS2K4saw remotestarter-keyless entry
Bought 95suburban not shure how it works
ADDING KEYLESS ENTRY OPTION TO 2002 CHEVROLET IMPALA
If it is built without it then all you can do is this: http://www.bulldogsecurity.com/Products/453055507-model-ke1702-vehicle-keyless-entry-system.aspx If it is built with it then the ones you bought will not work. you will have to goto the dealer and get them programmed for the car. you cannot do it yourself
Mar 12, 2014 | 2002 Chevrolet Impala
Keyless remote wont work
Many times if you purchase a used vehicle, the car lot only provides the key because they do not want to spend the money to purchase a key fob. A 2006 Lancer either has a 2 or 3 button keyless entry remote which you can find here: http://replacemyremote.com/
Keyless Entry Remote Fob Replacement
Feb 08, 2014 | Mitsubishi Cars & Trucks
I had a 5301 installed this week in a 07 Nissan Pathfinder. Everything seems to work fine except that when the vehicle starts the heater & fan does not come on. Did the installer miss a...
Sounds like the tech didnt hook up to the heater acc. wire located at the ignition cylinder. The color of the wire in the car is green\ yellow tracer.... Color of the wire from remotestart is orange. So find where the orange wire from the starter is and hook it up to the green\ yellow wire.
Jan 07, 2011 | 5301 Responder LE 2Way Remote Start and...
Cannot get keyless entry to work. Bought new keyp...
That keypad should work with your opener. I suspect the keypad is bad if you have other remotes that work. If not it could be the logic board.
May 21, 2010 | Sears Craftsman LiftMaster Chamberlain...
94 nissan altima GXE keyless option
Any vehicle can have keyless entry installed as long as the car has power door locks.I would recommend the viper aftermarket keyless entry. It works very well.
May 14, 2009 | DEI Python 1400XP Remote Start/Keyless...
Keyless entry on honda civic 2006 not working
The keyless entry is designed to work with the doors closed (closed - not locked). If the door ajar sensor thinks the door is open the keyless entry is disabled. When you manually lock the door it might tighten the door just enough to activate the keyless entry. I would try slamming all the doors closed and then see if the keyless entry works. If it still wont work have the wiring checked on the front door lock.
May 12, 2009 | 2006 Honda Civic Hybrid
Intall Remote Keyless Entry System in an 02 Honda Accord
You got the Wrong Information! Go to Wal Mart and Purchase a "Bulldog Security Keyless Entry" System for your Car. It will cost you a Quarter of the Price and is Just asw Reliable as the Factory Unit! Got one on My Truck with Remote Start also and it works GREAT! Should cost about $50.00 Bucks or so.
Jan 22, 2009 | 2002 Honda Accord
Keyless entry code
They normally stamp the Keyless entry code in the trunk and if not I belive the Computer that controls this is located behind the Glove box and they normally have the code printed on it.
Jan 11, 2009 | 1987 Lincoln Mark VII
Keyless entry not working
the keyless entry system is tied into the computer system and needs to reprogramed by the dealership
Nov 30, 2008 | 2004 Jeep Grand Cherokee
Car APS921 Remote Starter - Keyless Entry Logo
61 people viewed this question
Top Audiovox Vehicle Parts & Accessories Experts
xxxxxx xxx
Glen Weitzdoerfer
Are you an Audiovox Vehicle Part and Accessory Expert? Answer questions, earn points and help others
