Kenmore Elite Ice & Water Trio Refrigerator
SOURCE: Kenmore refrig not making ice and top shelf area in refrig not cold
if you are having tempurature issues make sure the fan in the freezer is operating. it should be on when the compresor is running. this may explain both warm fridge and no ice.
SOURCE: Kenmore Refrigerator stopped dispensing water
Either your water tank in the fridge froze up, the waterline that goes up the freezer door from the bottom hinge froze, or the switch that your glass hits is damaged. Do you hear any humming or noises when you put your glass up to get water?
SOURCE: Kenmore elite (106.53606202) ice maker will not dispense ice
When you push the ice dispensing lever, you should be able to hear the micro-switch clicking. If no click, the switch is faulty. The auger motor which is activated by the lever could also be faulty. This is the motor that causes the auger in the ice bucket to rotate one way for crushed ice and the other way for cubes. The auger could also be jammed. Try switching between crushed and cubes to unjam the auger. Empty the ice bucket and start again.
SOURCE: kenmore side by side ice maker
There are as you can imagine many possible causes for you no ice condition. I will give you the most common problem for the year model you have. I hope this helps you.
You will need to remove the ice maker from the freezer compartment to check it. Once it is repaired if the following information does help, and you reinstall the ice maker, it should go through a cycle automatically within an hour of your reinstalling it in the freezer compartment.
Once you have the ice maker out of the freezer compartment you will need to remove the white cover on the end of the ice maker and look at the center of the large white gear. If the part inside the hole in the center of the gear is broken or looks twisted, you will need to replaced the module. The module is the part that has the large white gear and is held in the ice maker by 3 phillips head screws. It only comes as an assembly. You can't get just the little broken piece.
supertechks
Please don't forget to rate me
SOURCE: Kenmore Coldspot w/Ice Maker Not Making Ice
hi LOP7,
In most cases you can easily solve this problem.
step one would be to make sure your freezer is getting cold enough. If you have icecream in your freezer is it frozen solid or is it soft. Most icemakers cycle around 0 degrees and if your freezer is not getting to 0 then it will not cycle and it will not make ice.
Step two would be to make sure you icemake is cycling. To do this simply lift the little shut off arm on your icemaker and wait about an hour then go back to the icemaker and drop the arm down. The icemaker should start going through a cycle. You should notice the arm slowly begin to raise and the ice dispencer fingers will begin to turn. Then you will hear it call for water. You may hear a humm.
If the freezer is cold enough and the icemaker is cycling that only leaves the inlet valve. replace the valve and enjoy the ice.
If the freezer is cold enought and the icemaker does not cycle, then you have a bad icemaker. Simply replace the icemaker and viola.
Third if the freezer is not cold enought 0 defrees. Then you may have a defrost problem. In this case post more info and I will be happy to help. Good luck [email protected]
