Question about Garmin GPS 76 GPS Receiver
My 4 year old Garmin 76 keeps shutting off.
After turming on the unit it will only stay on for a few minuites (regardless of physical location). Also The trip computer will not reset.
Tried several sets of known good batteries. Every now and then it will stay on a while longer and seems to be accurate (speed, tides etc.).
  • garyreno Nov 05, 2008
    Mine is doing the same thing Except I can reset the trip computer if
    I do it fast enough before it shuts off. Also I get a vertical thin line on the screen after it shuts off. I have to remove battery's and replace so it can work 30 seconds or so.
Problem solved. Last Fall the FAA updated the WAAS satellites, changing the broadcast signal the satellites transmitted at. With this update in effect, it affected how they communicated with some devices that are enabled with the WAAS feature.
A software update has been released to fix this issue.Connect your device to the computer and run the Garmin Web Updater to update the software on your device.
Here is the link to download the program Garmin Web Updater.
http://www8.garmin.com/support/collection.jsp?product=999-99999-27
Posted on Nov 10, 2008
I have the exact same problem as garyreno. This is a remanufactured unit they sent me after my first one failed. Not sure if I want another pc of junk.....
My tankless water heater keeps giving out, and returns when it wants to. It. Continuously blinks 76 all day and night. Taking a shower is a game of luck, the water heats up then the unit shuts off. What...
Get it professionally service by a maker approved agent. They should be serviced every year. If it links 76, then it has a fault. Did you check the installation manual for fault codes at the back of the document under 'Trouble Shooting'?
Make and model if you want to COMMENT under my post.
Oct 01, 2017 | Water Heaters
Garmin nuvi 200 keeps shutting down
You may need a new power cord, I have the nuvi 250w and the cord is getting bad after a year. The battery will only run it for a short time.
Sep 16, 2009 | Garmin nuvi 200W GPS Receiver
5yr old Garmin 76s shuts off
KUDOS! Others with the same problem informed me that it is a softwear problem and to download the 4.0 version free on the Garmin web site....l'll do it ASAP and write again if it doesn't work...RG
Jul 19, 2009 | Garmin GPSMAP 76 GPS Receiver
76 C8 error display on control board
Call Paloma and they will send you a new circuit board. We had the same problem. Our heater is a little over 2 years old. They said the error "76" is a circuit board issue where the tank is not communicating properly with the remote. The other solution they told us was to disconnect the remote and just let the heater run on the default.
Jul 12, 2009 | Rheem Paloma PTG-74PVN / RTG-74PVN...
Garmin GPSmap 76 goes to vertical line
before you throw it away try vchanging to new battery
Jul 05, 2009 | Garmin GPSMAP 76 GPS Receiver
Unit shut down
I have run into the same problem and it may be related to the WAAS (Wide Area Augmentation System) feature. Try disabling this feature (under MAIN MENU / Setup). I used this receiver overseas (Asia and Europe) last year for 35 days straight with no problems. During this time WAAS was disabled as none of these satellites are visible overseas. The problem occurred intermittently prior to the overseas trip, and has reoccurred after returning. I was running into the same problem this past weekend and noticed the screen blanking out (with the vertical line) shortly after differential corrections were applied to the GPS signals. I disabled the WAAS and let the receiver run for over an hour. The problem did not return. Hope this helps.
Sep 25, 2008 | Garmin GPSMAP 76 GPS Receiver
Garmin c330 GPS
Hello, I have had 7 Garmin units and 4 of them where streetpilots like yours.
You can try a reset of the unit. This will restore the unit and you might loose any favorites etc that you have stored. Here's how you do a reset.
"With the unit off, place your thumbnail in the groove located under the Garmin logo on the face plate, gently pull off the face place. Press the reset button and turn the unit back on."
Try this and see how the unit works. If it still gives you the same problem then your unit needs repair. I have sent in at least 2 units to Garmin for repair in the last 2 years.
Thanks
Feb 19, 2008 | Garmin StreetPilot C330 GPS Receiver
Garmin GPS 76 GPS Receiver Logo
103 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
