Question about Honeywell Power Humidifier: Furnace Humidifier/ Humidifier
The LED diagnostic code says it could be any one of the following.
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;}Dear Gurus,
Thank you for you time and help in advance and as the temperaturecontinues to drops it is even more appreciated!!!
Lennox 80 UHG Furnace
The LED diagnostic code says it could be any one of the following. I am unsure which of the two LED went off, but it appears to me the “top”LED slowly flashed for a diagnostic code description of: “Flame sensed withoutgas value energized.”
Other wise my diagnostic code description is:
”Pressure switch open or has opened 5 times during a single call for heat; OR:Condensate line blocked; OR: Pressure switch closed prior to activation ofcombustion air blower.”
Any ideas? Anything I could try out before calling for service? I replaced thefilter and it didn't help. So if there's anything you can suggest, it'd bereally appreciated.
Kind regards,
  • Robotinner May 11, 2010
    when you reset furnace did it light up? Greg sunsetmech
3 Suggested Answers
vanni7
  • 163 Answers
SOURCE: furnace blower motor turns on with no flame burning
Hi!!! You might have a bad flame sensor its a single rod located in the burners its white..If the unit runs and then shuts off and on and off.change your flame sensor..Good luckk..
Posted on Jan 04, 2009
mrgrzz
  • 88 Answers
SOURCE: Pressure switch
Hi AB, I am mr.grzz,
thanks for your questions, well first off there is no fixing the pressure switch, it will have to be replaced, you will need your model and serial number on the furnace, make of furnace, to order a new one from a parts supplier, fairly easy to replace.first make sure the power is off to the furnace, undo the two wire leads on it, then the two screws holding it in place, remove the one or two small hoses attached to it, if you remove it before you go to look for a part, that would be best, there is a rating on it, just follow these steps in reverse to put in place, hope that helped ya, thanks again, mr.grzz
Posted on Jan 21, 2009
  • 189 Answers
SOURCE: Furnace blower blows cold air
It is possible that you did not set the new blower on the proper speed. Black wire is high. Blue is medium. Red is low. If the fan is operating to slow it can run to hot and trip the high limit control. Make sure the filters are clean. When the old motor went bad, the problem might not have been discovered rite away your high limit control might need to be changed.
Also anytime you work on a furnace you can kick up some dust. Always clean the flame sensor.
Good Luck
HVAC Teacher
Posted on Mar 08, 2009
Aprilaire 600 was leaking water from bottom of unit...subsequently filter pad replaced and all parts cleaned of residue; drain tube cleaned and is draining...The problem is that water is still dripping...
Sorry to read about your problem, I hope this helps you out.
you must have a defective water inlet valve, and its letting water in, just a little.. it maybe dirt in the valve, clogging it.
I tried to help you. Please help me and Rate/Vote on my response. We take the time to answer your question. take the time to rate us.Thanks and good luck
4 Thumbs - Very Helpful
3 Thumbs - Helpful
Jan 01, 2011 | Aprilaire 600 Humidifier
What is the saddle valve?
Your humidifier will have either a copper or plastic tubing attached to it. This tubing is the water tubing. If you follow that line to where it "taps" into a water line (near the water heater or a water line under your house), there should be a water shut-off valve. The water shut-off valve could be any type of valve but is normally a saddle valve. You could skip the step of shutting off this valve; however, it is good practice to shut the valve off for two reasons: 1. in the event of a water leak, you will be able to easily locate the valve to shut off the water. 2. if the valve is not "excercised" from time to time, the seals will dry rot and the valve will not be capable of doing it's job when the need arises.
Here is a video showing you how to trace your water line to your saddle valve. There is additional information on the video that you might find helpful as well.
May 07, 2010 | Aprilaire 550 Humidifier
Loud clicking and banging, A700 doesn`t work
You have a faulty humidistat
Greg Sunsetmech
Dec 13, 2009 | Aprilaire 700 Humidifier
Bionaire BCM 6000 tower leaking issue
Thank you for the follow up but there was a price at the end for my question so I decided to find out myself. I bought this product which is not the greatest and if on top of that I have to pay for a little information that's a bit far !
Regards,
Michel
Feb 02, 2009 | Bionaire BCM6010RCU 3.5 Gallon Tower...
Venta Airwasher Display Light Blinking...
This has happened to me. Check the contact points in the base of the machine. Ours had some corrosion on them. I took an emery board and filed the corrosion off to clean the contact points.
Jan 30, 2009 | Venta Airwasher VS370 2 Gallon Humidifier
Pressure switch
Jan 16, 2009 | Honeywell HE260A1010 Whole House...
Aprilaire 600 humidifier solonoid valve chattering in sync with d10 led
I fixed my problem by ordering a new control unit (model 56) from IAQSOURCE. Installing the control unit took a few mintues, and once the new control module was installed, I've had no more problems. The URL is as follows: http://www.iaqsource.com
Oct 12, 2007 | Aprilaire 600 Humidifier
Humidifiers Logo
145 people viewed this question
Top Honeywell Humidifiers Experts
Dennis
Ken Thomas
Brandon Berry
Brandon Berry
Are you a Honeywell Humidifier Expert? Answer questions, earn points and help others
