Question about Panasonic Navigon 5100
Navigon 5100 gps
Hello sir
my navigon 5100 gps works good but when i put on car charger ,gps stop working and on screen an icon comes of charging mode so what should i do to work my gps continue while charging
  • Anonymous Nov 28, 2008
    I'm having a problem getting it to turn on or off. Hold for 6 seconds but takes several tries. Any ideas?
  • Anonymous Dec 05, 2008
    when i plug the charger in the gps stop working what can i do
  • 728 Answers
Try turning it off and turning it back on while it is still plugged in and see if that works.
Posted on Oct 23, 2008
How do I give my brand new Navigon 3300 a good overnight charge
if you have a pc, you can use the usb to mini jack and it will charge
Mar 09, 2010 | Navigon 3300 Max Car GPS Receiver
Can my NVG5100 be used for navigation when charging
it should be able to. i have a garmin and it will work while plugged in.
Dec 03, 2009 | Panasonic Navigon 5100
My navigon 5100 gps wont charge while in use
Switch it on and let it totally discharge - the battery could have established a memory and thinks that it is fully charged -the wonderful world of electronics where nothing is what it seems.
Once discharged put it to OFF position and recahrge it.
Good Luck
Sep 13, 2009 | Panasonic Navigon 5100
Navigon 2100 displays the computer symbol when connected to charg
Wiring diagram pinout for Navigon GPS charge and concurrent use Pin Pin
Name Description 1 +5V 5 Volts Direct Current 2 Data floating/Not connected 3 Data floating/Not connected X Ident Conneted to Pin 4 (GND) as pure short, no resistor 4 Ground Ground, shorted to pin "X" Use of standard mini-b will place unit in Data Exchange/Synchronization mode. Use of mini-b with a 4-x pure short will allow use of Navigation software and concurrent charging. USB power source must be 1000 ma or above.
Sep 13, 2009 | Navigon 2100 Portable GPS Receiver
Navigon 5100 When connected to charger, computer icon comes up
you are not using a charger with the right voltage- you need 5 volts 1.2 amps radio shack has a gps charger that will work
Jul 15, 2009 | Panasonic Navigon 5100
Navigon 5100 does not connect with GPS
NAVIGATION IS NOT WORKING. THE SCREEN IS " NAVIGON AND THE WORLD IS YOURS"
WHAT IS THE SOLUTION.
Jan 10, 2009 | Navigon 5100 GPS Navigator Handheld GPS...
Plug in car charger and it shows navigon connected to computer
The problem lies with the fact that a standard mini usb pin-out has + voltage on pin 1 and ground on pin 5. The navigon is programmed to recognize this as a computer. The navigon charger however has + voltage on pin 4 and ground on pin 5. The reason for navigon doing this as opposed to following the standard pin-out is due to the unit requiring a stronger power supply to charge the battery. USB current output on a computer does not have the capacity to do this. As a consequence, you will have to find a charger that has the right pin-out for this device ( + on pin 4 and - on pin 5 ). The tough thing is, there is no way to tell one from the other, they look identical. However, I have found that chargers with a capacity of 1000 ma or greater are pinned-out like above ( + on pin 4 and - on pin 5 ). Other than using a multimeter to verify the pins, the only thing to do, would be to plug it in and see if it works. Hope this helps.
Dec 28, 2008 | Navigon 2100 Portable GPS Receiver
Navigon 5100 won't turn on when battery is charged.
try holding the power button down for 15 to 20 seconds - that worked for mine!
Hope that helps
Nov 29, 2008 | Panasonic Navigon 5100
Panasonic Navigon 5100 Logo
328 people viewed this question
Top Panasonic GPS Experts
Richard Foster
Richard Foster
Will Halftowaite
Are you a Panasonic GPS Expert? Answer questions, earn points and help others
