Question about Philips Magnavox 51MP392H Rear Projection Television
Convergence on my magnavox is wrong - Philips Magnavox 51MP392H Rear Projection Television
  • Philips Master
  • 3,459 Answers
Projection TV sets have two very common problems. One is convergence ( 3D/Warped video) the other is CRT fluid ( Dull Video). Below are more details for both items. Also, complete repair kits with instructions and repair support are avail from site such as www.TvRepairKits.com
Common Problem #1) Convergence has gone out
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
This is a very common failure on these projection sets and a fairly simple DIY fix. All projection sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
Common Symptoms include....
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
  • TV shuts off after powering on. The power light will blink. TV may also make a chirping noise.
Here are some pics of convergence problems.
e87380c.jpg69189a5.pngSOLUTION #1
What you will need to do is convergence. You can get a repair kit from TvRepairKits.com . It includes replacement parts,step by step instructions, support, etc.
Common Problem #2) CRT Fluid is Cloudy
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
Picturconvergence on my magnavox is wrong - 578ba6c.jpgset that needs the fluid changed.
TV sconvergence on my magnavox is wrong - 69189a5.pnguid change
69189a5.pngSOLUTION
What you will need to do is replace the coolant and clean the crt. You can get a repair kit from TvRepairKits.com . It includes replacement coolant,step by step instructions, support, etc.
Posted on Mar 09, 2012
My Magnavox Projection Tv has the 3D appearance for awhile and now it has no picture at all...only sound. what is wrong with it?
Sounds like your convergence IC's need replaced for starters. Not sure if that is causing your no picture though. More than likely you have some resistors out as well as a fuse or 2 in the convergence line. If you have a meter I would start there.
Apr 12, 2011 | Philips Magnavox 51MP392H Rear Projection...
My big screen tv shows only red green and blue. the colors are separated. what is wrong with it
the convergence circuit needs repair. You can get the convergence repair kit from www.tvrepairworld.com which contain the parts and the CD with instructions.
Sep 22, 2010 | Philips Magnavox 9P6034C 60" Rear...
The picture on my phillips rear projection tv is red and I can't change it by adjusting colors. What is wrong and how can I fix it?
Tv have colors lines R,G,B mis alignment any colors,shadows colors, 3D pictures,the tv have a problems known as a convergence problems.The tv convergence board is dead.The 2 STK Convergence ICS and some or all it resistors are dead too.Must replaced these parts to solved convergence problems.The shop will cost $300-350 for parts and labors.
Aug 05, 2010 | Philips Magnavox 51MP392H Rear Projection...
My magnavox 51mp392h has a convergence issue. the
Convergence is dead.Know how to solders? Must replaced the 2 convergence ICS and all it resistors.Tries Tv repair World.com,Tvrepairkit.com to buy a convergence kit to repair it ur self.The shop will $300 for the parts and labors.
Feb 03, 2010 | Philips Magnavox 51MP392H Rear Projection...
I have a 51 inch magnavox projection tv, the color started with a blue tint but now the red and green has gotten weird also. the screen is starting to have half circle or look bent also on top and bottom...
Ur convergence it dead,Know how to solders?Can buy a convergence kit,replaced what in the kit.Tries websites.Tv repair World.com,Tvrepairkits.com.To repair ur self.Cost u about $300 to repair by the the shop.
Dec 15, 2009 | Philips Magnavox 51MP392H Rear Projection...
I have a magnavox 52 inch tv the picture got a mirred look to it then went black but can still hear te sound can you tell me what's wrong
This is a very common failure on Projection sets. Its called a convergence problem.
You may have one or more of the following symptoms.
  • Screen looks 3D
  • No Audio / No Video - Makes Chirping Sounds
You can see some examples and find a fix here...
http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Oct 17, 2009 | Philips Magnavox 51MP392H Rear Projection...
Colors dont align
This is a common problem. Your convergence has gone out.
Common symptoms are...
1) 3D Video
2) Warped Video
3) Convergence menu does not adjust the red or blue correctly.
Go here for a solution...
http://www.fixya.com/support/r2861627-updated_convergence_problems_amp
Sep 06, 2009 | Philips Magnavox 51MP392H Rear Projection...
Magnavox rear projection
If the red converge will not line up, then there the convergence chips are actually bad - the repair will cost around $700 if you go through a Magnavox authorized service center. I would look at posts by Slinteriors in the Philips or Magnavox rear projection sections - he has some ideas on generic chips that might be had for cheaper.
Jul 06, 2008 | Toshiba 55H70 55" Rear Projection...
Convergence settings don't stay set
are you choosing the "Save Multipoint" option after you set the convergence?
Jan 28, 2008 | Philips Magnavox 51MP392H Rear Projection...
Blue is blurry
take it apart turn blue lamp until it is clear. A napkin over the green and red lights during this step is very helpful
Oct 27, 2007 | Philips Magnavox 51MP392H Rear Projection...
Philips Magnavox 51MP392H Rear Projection Television Logo
352 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
