SOURCE: How to Unlock Passcode on Ipod touch
Hey
I've written the solution to this problem on this page
http://www.fixya.com/support/r977231-disabled_or_code_forgotten
let me know if you need anything else.
SOURCE: I have an ipod touch and forgot the passcode how
if it is the first generation ipod touch try to connect it to the computer open itunes and the restore ur ipod touch that might solve your problem
SOURCE: forgot my passcode
Using the Restore function for your iPod touch is part of standard troubleshooting procedure. Restoring your device will erase all data from your iPod touch, including songs, videos, contacts, photos, calendar information, and any other data. All iPod touch settings are restored to their factory condition.
Whenever you restore your iPod touch, Apple highly recommends that you perform a sync prior to restoring in order to back up any changes since your last sync. If you have movie rentals on the device, see this document before restoring.
Use the following steps to restore your iPod touch:
Make sure you have the latest version of iTunes installed and running before attempting to update.
Connect your iPod touch to your computer.
Select your iPod touch when it appears in iTunes under Devices.
Select the Summary tab.
Select the Restore option.
When prompted to back up your iPod touch's settings before restoring, select the Back Up option. If have just backed up the device, it is not necessary to create another.
Select the Restore option when iTunes prompts you (As long as you've backed up your device, you should not have to worry about restoring your iPod touch).
Once the restore process has completed the iPod touch restarts and displays the Apple logo while starting up
SOURCE: my ipod touch has a restriction passcode and i
If i remember right, you need to plug it in to your computer and when itunes opens up go to the ipod thing where it shows all the setting and info for the ipod and it should be resettable somewhere in there.
SOURCE: please help reset passcode - forgot the code iPod touch
You can connect your iPOd on the computer which you primarily use with your iPOD, then open Itunes when you disconnect from it it will be no longer locked.
