Question about Bosch 24 in. SHE44C02UC / SHE44C06UC / SHE44C07UC Built-in Dishwasher
Bosch service manual for SHE66C06UC/40 dishwasher or error codes
Want to press the right buttons, get error codes to point out bad parts. This dishwasher keeps running for hours
  • 213 Answers
SOURCE: Electronic controls don't count down properly
you have to replaced the main control resoldering wont fix it because the relay itself has gone bad replacing the board will solve the problem
Posted on Nov 20, 2007
  • 338 Answers
SOURCE: Bosch dishwasher---water filling from the bottom when off?
i would replace the inlet valve. it sounds like it is not closing all the way
Posted on Dec 29, 2008
SOURCE: Bosch dishwasher cleans but will not drain.
Remove the drain hose where it attaches to the disposal. This area often clogs and will prevent any d/w from draining.
Posted on Feb 15, 2009
dragonsthatk
  • 547 Answers
SOURCE: SHU4302UC/U06 runs for hours. What's the fix?
timer
Posted on Feb 18, 2009
SolutionGuy
  • 331 Answers
SOURCE: bosch dishwasher motor keeps running no water
Hola Lewis!
This is such an easy repair, you'll be shocked and surprised! The reason this is happening is that the computer or timer has detected a "flood" condition and has permanently energized the drain pump to clear the "flood".
What you'll need to fix it...
1.) Shop-Vac (for vacuuming water) with a crevice tool (like one of these)
2.) T20 Torx bit with a driver. Torx sizing here. (You can get a set at Home Depot or Lowes)
All you gotta do now is get down on the floor and remove the kick panel. Then remove the screws holding the water valve and lift it up out of its' plastic holding. Now your shop-vac w/ crevice tool can be used. Stick the crevice tool in there (about 10") and vacuum up all the water that's been trapped in the basin. (you may need a flashlight to see what's going on back in there...) After the water is gone, your DW will work fine.
Here's how it works... About 10" behind the inlet valve is a "float" made of styrofoam. When water gets into the basin, the float rises and eventually trips a "flood condition" switch. This switch shuts the unit down and will only allow the drain pump to operate. So what you want to do is get the water out of the basin.
There may be a reason for the basin flooding, though. Suds (caused by too much (or the wrong) detergent), an actual water leak from the valve, etc... So after you get the water out of there and the unit is working again, you may want to monitor it (like, only run it when someone is home) for a while just to make sure that a real flood does not occur.
Hope this helps.
SG
Posted on Mar 23, 2009
I have a dishwasher bosch model SHE3AR55UC/07. I press the ON button to turn dishwasher on. And when I press START button, the dishwasher does not start.
Many Bosch dishwashers have a design flaw...the door will not fully close and pops out after you start it. When this happens the D/W will not run. You can go to the Bosch website to order the part to fix this and no they will not reimburse you nor acknowledge your email to customer service.
Aug 27, 2016 | Bosch Dishwashers
What is E22 error message on Bosch dishwasher
Hi Darlene, The link below is a bosh dishwasher error code AND how to fix, I hope this helped..........CHEERS..
Bosch Dishwasher Error Code E22
Fault Condition: Residual water in sump
Repair or Check: Check for a blocked pump, a dirty filter, or grease build up.
Parts Required: Pump or clean filter
Bosch Dishwasher Error Codes How To Clear What To Check
Apr 24, 2016 | Bosch Dishwashers
Bosch Dishwasher fault E 15 explain
Bosch Dishwasher Error Code E15
Fault Condition:No water in dishwasher or not sensing water.
Repair or Check: Tilt dishwasher back and the error code should disappear. While you tilt it press off button to clear. Stand it back to normal turn back on and dishwasher should run normally.
Parts Required:Tilting machine
Hi i found this answer on this link, scroll down the page and it's the 3rd error code (in red) Hope it helps...
https://removeandreplace.com/2015/10/09/bosch-dishwasher-error-codes-how-to-clear-what-to-check/
Mar 16, 2016 | Bosch Dishwashers
How do we put it through a test mode?
Here you go, both answers :>)
Bosch Dishwasher Troubleshooting Your Bosch dishwasher can run a test cycle which will quickly go through each stage of a wash programme in order to find out at what point a fault is occurring. It will only give you a general idea of where the problem lies but is a useful first step in diagnosing the issue.
The steps to start the test cycle vary depending on what model you have but the basic method is similar across the range. It might be that your dishwasher doesn't have the same button labelling as described in the steps below. In that case try holding down the buttons which have similar names. After a little trial and error you'll find the right combination.
  • Make sure the dishwasher is switched off.
  • Press and hold the Power Scrub Plus and Regular Wash buttons.
  • Turn on the dishwasher, then release the two buttons.
  • The light above each of these buttons should flash.
  • Start the test cycle by pressing the Power Scrub Plus and Regular Wash buttons again.
  • The test programme will begin and an error code will be displayed at the end of the cycle if a fault has been detected.
You can find a list of Bosch dishwasher error codes and their definitions here.
Error Codes are also here;
http://www.ukwhitegoods.co.uk/help/fix-it-yourself/fault-codes/dishwasher-fault-codes/3058-bosch-sms-series-dishwasher-fault-codes.html
Sep 30, 2015 | Bosch Dishwashers
How to run self test on bosche dishwasher
Here is an excerpt from "Bosch Dishwasher Troublesoooting".
Running a Test Cycle
Bosch dishwashers have a test cycle which can be run as a troubleshooting measure. The method to run this test cycle is similar across the Bosch dishwasher range so if your dishwasher features seems different from those described below then try experimenting, as the process is fairly straight forward and will be very similar. Bosch dishwasher model numbers are usually found around the top or lip of the door. One of the most common differences between dishwasher models is simply the names of the buttons. For example in the first example below, POWER SCRUB PLUS and REGULAR WASH may be called WASH and ECO depending on your dishwasher model and the country you are in. The other key difference is whether your dishwasher has a display panel (which can display error codes) or not (in which case a program light will illuminate to tell you the fault.
To run the test cycle hold down the POWER SCRUB PLUS and REGULAR WASH buttons. Whilst held down press the ON/OFF button. The lights above them should flash. Now you can check the status of each dishwasher program by pressing its button. Now you can run the full test cycle = Press the POWER SCRUB PLUS and REGULAR WASH buttons again. The dishwasher will start up and when the cycle has ended one, if you have no display panel on your dishwasher model the indicator lights will illuminate if a malfunction was detected as follows -
CLEAN - A temperature sensor fault. If this is the case then the test cycle will be very short as the dishwasher will terminate the test once it's been detected.
RINSE/DRY - A water sensor/filling fault. If this is the problem then the test cycle will not complete as the dishwasher cannot detect the right level of water, the dishwasher will just keep filling and draining again.
WASH - A heating fault. Check your heating element.
If you do have a display panel on your Bosch dishwasher then after the cycle is complete an error code will be shown if a fault has been detected. The error codes are as follows -
0 - No errors have been detected.
1 - A water sensor/filling fault.
2 - A heating fault.
4 - A water filling fault. This can also appear as F on the display during a normal cycle.
8 - A temperature sensor fault.
When troubleshooting your Bosch dishwasher, running the above test cycle is a good start in diagnosing the problem and should give you an idea of where the problem lies with your Bosch dishwasher and what fixes and repair are in order. Our general troubleshooting page will give you some ideas on other things to check on your dishwasher. Good luck!
Mar 29, 2013 | Bosch 24 in. SHU5305UC Built-in Dishwasher
My Bosch Water Heater keeps going off. I reset it and then A7 keeps coming up. We had a power outage for about 6 days. I do not have the manual. Do you know what it is and how to fix it? Thank...
Questions might be asking for a manual, and asks what error A7 means, and asks how to fix error problem, but model number of Bosch heater is not given.
Error codes are start-point for troubleshooting, and can include multiple causes.
So following answer provides general do-it-yourself resources, without saying that problem can be 100% diagnosed or fixed by homeowner.
1) Error code A7 is outlet temperature sensor fault.
Problems include: need for descaling, dirty inlet water filter, debris in faucet aerators, dirty wiring terminals, bad wiring harness, or bad temperature sensor.
http://waterheatertimer.org/pdf/Bosch-GWH2400ES-error-codes.pdf
2) Before calling service technician who can test failed parts and catch tankless up on yearly maintenance, open following links for Bosch resources including error codes, phone number, possible manual, and descaling instructions, and cleaning inlet filter:
http://waterheatertimer.org/Troubleshoot-Bosch-Tankless-water-heater.html
http://waterheatertimer.org/pdf/Rheem-De-lime-tankless.pdf
http://www.boschhotwater.com/Portals/7/TechBulletins/TWH-G1-12_Cleaning_inlet_filter.pdf
3) Product manual: Question posted under model 125HX-LP
Open following link for possible manual:
http://www.boschhotwater.com/HelpfulResources/TechnicalSupport/BoschAquaStarModels/125HXTechSupport/InstallationManuals/tabid/542/Default.aspx
4) Do it yourself service bullitens for 125HX-LP
http://www.boschhotwater.com/HelpfulResources/TechnicalSupport/BoschAquaStarModels/125HXTechSupport/ServiceBulletins/tabid/548/Default.aspx
5) Take a moment and rate answer:
And take advantage of fixya expert assistance live.
For a price, expert works with you while you work on water heater or any do-it-yourself project.
Fixya is always less expensive than a service call.
Sep 07, 2011 | Bosch AquaStar Propane Tankless Water...
Fon the dishwasher
Hi, welcome to Fixya.
Based on the info you've provided, the dishwasher is indicating a error during the "fill" stage, hence the "F" being displayed on the Bosch machines.
Here's how to perform a test or diagnostic...
Make sure the power button is in the off position ( open & closing of the door will activate the "auto shut off" ).
Once certain it is "off" press and hold both the regular button and rinse & hold button, then turn the unit "on" while continuing to depress those 2 buttons. Initially, control module version # will display ( i.e. "20" = version "0" without jumper...not important for this ).
When the buttons are now released, the lights above them will flash. To start testing, press both the "regular wash" and "rinse & hold" a second time.
Let the test follow through, ( grab a coffee and observe, this will take a while )
When testing has ended, the display will show an error using codes as follows...
"0" = no error.
"1" = aqua sensor fault.
"2" = heating fault.
"4" = filling fault. and finally.
"8" = NTC ( temperature sensor ) fault.
The "F" code will not appear in test mode, only during wash. If you have a failed level switch for instance the test will display "4" and will continually fill and drain and test won't complete until you press the "on/off" button.
If the test complete's without and error or won't fill, replace the water valve. Original part Part # 425458 at "searspartsdirect.com", "apwagner.com" or #1105846 at "repairclinic.com" ( they use there own numbers ) or you can check locally by your model number & serial number.
Let me know if I can assist you further. Hope you found this helpful and if so please allow for a positive rating.
Thank you for choosing "fixya" and good luck.
macmarkus :)
Jul 07, 2010 | Bosch 24 in. SHU43 Built-in Dishwasher
Replace cover on Bosch Dish washer> Now a C6 code is displayed in the window
I had the same problem after replacing the white panel on my Bosch SHE45M02UC with a stainless panel. I got the C6 error code. I called Bosch customer service twice and neither rep was helpful. One guy told me he didn't know what the C6 code meant. He suggested that I call a local appliance repair guy and he would know what the code meant. I replied, you mean to tell me you work for the manufacturer of the dishwasher and don't know what the error code stands for but a local repair guy that doesn't work for Bosch does?
After all this frustration, I took the panels off and tested the dishwasher with no buttons. It worked fine! Turns out, each identical button isn't identical. Each one is labeled A-G. After putting it back together, no more C6 code! On a side note, try reseting the dishwasher. With the dishwasher on and door closed, hold down the cancel/reset buttons for 5 seconds and release. The disher should drain and reset.
Mar 27, 2010 | Bosch 24 in. SHU43 Built-in Dishwasher
I have a 13 month old Bosch SHE58c dishwasher. The pump runs constantly and will not refill the tank. There are no error codes thrown on the control panel, but not sure there are error codes for this model...
I have exactly the same problem. Turn on the machine and it just pumps and pumps, door controls do nothing. According to the technician who came and looked at it the problem is a bad control board. He ordered the part and we are waiting on it.
Jan 09, 2010 | Bosch Evolution 800 SHE58C05UC Stainless...
Error code 2H
The control panel needs to be replaced (indicated by the "2H" error code displayed at the start of the cycle).
BTW - The number 1 displayed at the end of the cycle indicates the cycle has timed out (i.e., it doesn't mean 1 minute remaining). Hence the continued running of the unit. Until you replace the control panel, you'll have to manually cancel the cycle at this point.
Oct 08, 2008 | Bosch 24 in. SHU53 Built-in Dishwasher
Bosch 24 in. SHE44C02UC / SHE44C06UC / SHE44C07UC Built-in Dishwasher Logo
172 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
